Engine Shuts off after 30mins - Hyundai Forums : Hyundai Forum
 3Likes
post #1 of 11 (permalink) Old 04-25-2019, 02:01 PM Thread Starter
Quoted: 2 Post(s)
Thedohnerparty is an unknown quantity at this point
All right, I need help! 2012 Hyundai Accent, automatic, direct injection.
Last week, my car jerk twice from the engine and then my rev counter shut off. Shortly after I returned from a trip to AutoZone because there was no check engine light but I hoped they could find a code anyway, when I parked my engine shut off. After waiting a few moments the car turned on just fine. The rev counter also return to normal.
The car has shut off several times, regardless of gear, but generally after at least 30 minutes of the engine running. No check engine lights have come on.
Currently it is at a shop where they are trying to diagnose it, because there are no check engine lights or codes coming from the car they are having a hard time. They said my relays look good and have no issues there, he does not necessarily think it is a sensor. He is convinced that it is is build up or deposits on the back of my intake valves.
Is anyone having a similar issue, and what did it turn out to be? We are going to try and clean the intake valves this weekend, but I was wondering if I should go ahead and replace a relay or maybe also replace some sensors as a precaution?
Thedohnerparty is offline
post #2 of 11 (permalink) Old 04-25-2019, 02:46 PM
DarrenBach's Avatar
Drives 2011 Sonata GLS 2.4L 2001 LaSabre 3.8L Once owned a new '90 Excel GL
Quoted: 447 Post(s)
DarrenBach is an unknown quantity at this point
When it shuts-down do you still have dash lights/instruments? Rev counter...never heard that one before?
"If a man says something in the woods, and a woman isn't there to hear it, is he still wrong?"
Miles on her 156,000
DarrenBach is online now
post #3 of 11 (permalink) Old 04-25-2019, 03:15 PM Thread Starter
Quoted: 2 Post(s)
Originally Posted by DarrenBach View Post
When it shuts-down do you still have dash lights/instruments? Rev counter...never heard that one before? <img src="https://www.hyundai-forums.com/images/smilies/blink.gif" border="0" alt="" title="" class="inlineimg" />
Yes, all lights remain, no check engine light, or codes in the computer.
If I wait a few minutes, it starts back up.
post #4 of 11 (permalink) Old 04-25-2019, 03:23 PM
DarrenBach's Avatar
Quoted: 447 Post(s)
The intake valve cleaning would be a waste of money at this point...
bdahl385 and jwt873 like this.
post #5 of 11 (permalink) Old 04-25-2019, 04:10 PM
Past racer's Avatar
2012 Accent GS Automatic
Quoted: 23 Post(s)
Past racer is an unknown quantity at this point
Originally Posted by Thedohnerparty View Post
......The car has shut off several times, regardless of gear, but generally after at least 30 minutes of the engine running. No check engine lights have come on......
If it was me, Id spend my money on crank sensor replacement. I would think buildup on intake vales would cause poor performance not a shutdown problem.
bdahl385 likes this.
Past racer is offline
post #6 of 11 (permalink) Old 04-25-2019, 05:01 PM
bdahl385's Avatar
Drives LF Sonata Hybrid Ltd 2016; MD Elantra 2013; MD Elantra Ltd. 2012; NF Sonata LX 2006 (Sold)
Quoted: 27 Post(s)
bdahl385 is an unknown quantity at this point
Rev counter = tachometer ??? I have read other posts where a faulty crankshaft sensor will kill the tachometer output. crank and / or camshaft sensors could be culprits at this point but should be setting the "check engine light".
bdahl385 is offline
post #7 of 11 (permalink) Old 04-25-2019, 07:14 PM
wfrpalm's Avatar
2015 Accent Hatchback
Quoted: 7 Post(s)
wfrpalm is an unknown quantity at this point
Can you explain what you mean by "engine shuts off". Does this mean the motor stops running or all the electrics stop working or something else. Does this happen while you are driving? This sounds like it could be pretty dangerous. Be careful and good luck.
wfrpalm is offline
post #8 of 11 (permalink) Old 04-25-2019, 07:25 PM Thread Starter
Quoted: 2 Post(s)
The engine turns off, the electrics remain on. If you wait a few moments you can start the car again.
post #9 of 11 (permalink) Old 04-25-2019, 07:27 PM Thread Starter
Quoted: 2 Post(s)
If it was me, I’d spend my money on crank sensor replacement. I would think buildup on intake vales would cause poor performance not a shutdown problem.
His theory seemed to be that of the engine wasn't performing properly, that the sensor may overheat and shut the engine off. When the sensor cools down, the car then starts up again.
The cleaning seemed simple and rather inexpensive, so we may give it a shot. No check engine lighrs, but may also replace both cam and crank sensors.
post #10 of 11 (permalink) Old 04-26-2019, 11:09 PM
misnblu's Avatar
Quoted: 33 Post(s)
misnblu is an unknown quantity at this point
Have them check your fuel pump or fuel filter depending on how many miles you have on the car.
Little to no fuel will do the same leaving no cel codes.
Had this happen to me in my hooptie Ford and Z24 race car. Both had bad fuel pumps.
Replaced them and all was fine.
Just a thought. &#x1f44d;
misnblu is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
tabasc99
