Engine went off while driving - Page 4 - Hyundai Forums : Hyundai Forum
 2Likes
post #31 of 36 (permalink) Old 04-23-2019, 08:33 PM
13 Accent SE (RB) with sunroof
Quoted: 18 Post(s)
az2008 is an unknown quantity at this point
Originally Posted by Jukeblam View Post
she switched off the engine while in a gas station, with the gear in D.
After driving about 13kms more, the car goes off while in motion and doesn't restart immediately. When it finally does, it shudders until finally stabilising.
Thanks!
I turned off my ignition while in D a few times lately (stoned, old, or both). No problems like you describe.
However, back in 2013 I installed my own Viper alarm system. While doing that, I had the *amazing* idea to put a toggle switch on the gas pump. I could disable my car using a hidden switch. Not the kill switch everyone knows about. It would take a thief months to find mine!
I forgot to turn that on at least 4 times. The experience was exactly what you describe. It would drive about a mile (at most), and then die. When I got it started, it would act very fluttery, stall, no power. It would take 10 miles before it came back. (I think it had something to do with the "brain." I think it makes decisions about how to react to the throttle based upon recent activity, fuel usage, etc. I got the impression it didn't have any lower boundary and "learned" to be starved. It took a few miles to relearn.).
It's a wonder I didn't mess my car up from that.
Anyway, that makes me think you got some bad fuel? Maybe the filter is clogged and you're having a similar behavior as the pump turned off. To me, the part about it taking awhile to get back sounds very familiar.
az2008 is offline
post #32 of 36 (permalink) Old 04-24-2019, 01:45 AM
AUTOSPARK's Avatar
Quoted: 2329 Post(s)
Originally Posted by Lannet Hackler View Post
If so I would like to know what the solution was.
More often than not a new crank position sensor is the solution. They tend to fail when they get hot causing the engine to quit and it wont restart again until the sensor cools down a little.
AUTOSPARK is offline
post #33 of 36 (permalink) Old 04-24-2019, 02:48 AM
Drives Hyundai I30 CRDI; 78 LB lancer heavily modified; Holden VR V8; Mitsubishi Starion; 67 Toyota
Quoted: 580 Post(s)
charlescrown is an unknown quantity at this point
Beat me to it scottie. Certainly sounds like that.
charlescrown is offline
post #34 of 36 (permalink) Old 04-24-2019, 10:23 AM
Quoted: 3 Post(s)
Lannet Hackler is an unknown quantity at this point
How long does it usually take for a crank position sensor to go from causing an occasional problem to no longer working at all and can it cause other problems by not replacing it right away?
Lannet Hackler is offline
post #35 of 36 (permalink) Old 04-24-2019, 11:41 AM
AUTOSPARK's Avatar
If you have a faulty crank sensor why would you not want to replace it right away?
I'd consider the engine randomly shutting down while your driving down the road a major safety concern.
az2008 likes this.
post #36 of 36 (permalink) Old 04-25-2019, 03:56 PM
Quoted: 3 Post(s)
Because I can't afford too yet.
