starter motor problem - Hyundai Forums : Hyundai Forum
post #1 of 14 (permalink) Old 02-14-2019, 07:17 AM Thread Starter
drives: 2006 Santa Fe (CM) black, 7 seats, usually really dirty
Quoted: 52 Post(s)
scoobykids is an unknown quantity at this point
Question starter motor problem
first post not about my santa fe! my neighbour lent me his really old bobcat to move some earth (3 cyl diesel). It started a few times (with difficulty, slow cranking and needed jumpers) but now it wont start at all even with 14v showing when its jumpered to my santa fe. All I get is a click from the starter solenoid. Ive tested the starter with a screwdriver directly on the starter motor contacts, here is the result:
Fat contacts: starter spins (does not engage obviously).
Solenoid contact: solenoid engages but starter doesnt spin.
I can turn the motor by hand with a wrench on the crank, so its not locked. When I turn it I hear the starter solenoid click back in place. Ive cleaned battery terminals and earth contacts on motor.
To me the symptoms are like its not getting enough juice but I have checked everything - i think!
Question: is it possible for the starter to spin, no load but still be bad?
thanks
2006 Santa Fe Mk II. 2.2 crdi sunroof, leather, 7 seats, manual. LHD. shiny topsides, lots of rust below
scoobykids is offline
post #2 of 14 (permalink) Old 02-14-2019, 02:18 PM
AUTOSPARK's Avatar
Quoted: 2297 Post(s)
Yeah that's a possibility.
But it might not necessarily be the starter motor itself that's faulty. The other thing that will cause your symptoms is burnt contacts inside the solenoid cap. If you can bridge all three terminals on the solenoid together see if than makes it crank. If so it's the contacts inside the solenoid cap that have failed. You can often buy a replacement cap which comes with new contacts. Failing that you'd need to replace the complete solenoid.
Typical Starter Solenoid Cap
AUTOSPARK is offline
post #3 of 14 (permalink) Old 02-14-2019, 04:42 PM Thread Starter
Quoted: 52 Post(s)
I don't think it's going to be possible to buy as solenoid alone. this is the starter https://rover.ebay.com/rover/0/0/0?m...2F113594278549
post #4 of 14 (permalink) Old 02-14-2019, 05:35 PM
grcauto's Avatar
Quoted: 1014 Post(s)
You need a new starter.
grcauto is offline
post #5 of 14 (permalink) Old 02-14-2019, 06:15 PM
AUTOSPARK's Avatar
That's looks like a Delco 5MT. You can buy replacement solenoids for those, and replacement caps too :
STARTER MOTOR SOLENOID - 12V DELCO REMY TYPE 5MT/22MT
Cargo 130497 - Delco 5MT Solenoid Cap
post #6 of 14 (permalink) Old 03-08-2019, 03:33 AM Thread Starter
Quoted: 52 Post(s)
starter porblem solved
ok, I replaced the starter and the bobcat starts now.
afterwards I disassembled the old one to see if I could find the cause of the problem. The high current contacts in the solenoid are operated by a large copper washer being pushed into them to close the circuit. This large copper washer was filthy dirty with oily grime. The contact were also dirty. I haven't cleaned/repaired/tested it yet but it matches the symptoms so I'm pretty sure its solved.
Thanks all for advice.
post #7 of 14 (permalink) Old 03-08-2019, 04:23 AM
AUTOSPARK's Avatar
Thanks for taking the time to post back and confirm my suspicions.
post #8 of 14 (permalink) Old 03-11-2019, 11:31 AM Thread Starter
Quoted: 52 Post(s)
bobcat slower and slower, stalls and wont start now :-(
1986 bobcat: starter fixed last week. worked for a while.
now it only runs 1/2 hour before the motor gets slower and slower, then stops.
Its a (ryobi?) 3 cylinder diesel with old fashioned fuel pump/discributor and gravity fed fuel tank.
Sometimes it starts after I let it sit 1/2 hour.
Any ideas gladly welcome?
post #9 of 14 (permalink) Old 03-11-2019, 12:11 PM
Location: Hiding from those who might be looking for me
Quoted: 2488 Post(s)
Venture fuel filter wont flow to keep up with fuel consumption
sbr711 is offline
post #10 of 14 (permalink) Old 03-11-2019, 12:19 PM
santa06's Avatar
Quoted: 193 Post(s)
Sounds like it’s running out of fuel.
Injector pump fuel filter on diesel are critical, any idea if it has been changed recently.
Is it running winter or summer diesel. Could try fresh diesel fuel.
santa06 is offline
