electrical gremlins - Hyundai Forums : Hyundai Forum
post #1 of 10 (permalink) Unread 04-16-2019, 09:03 PM Thread Starter
islander21's Avatar
2006 Sonata 1966 Corvette
islander21
electrical gremlins
Hey folks,
It's been a while since I posted, which is good news. But I guess I was overdue for a doozie. The car in question is a 2006 Sonata GLS V6 with 153K miles on it. I drove it for 12 years and it left me on the road only twice: once for the accelerator pedal recall (left us in limp mode in Key West) and for a dead alternator.
Then I gifted it to my mother 4 months ago and the fun has begun. She took it in for a suspension issue to a local-to-her shop and it came out with no reverse and no 4th or 5th gear. I could not prove that the car was messed up by them and the dealer was no help after paying $150 in a diagnostic fees only for them to tell me "the tranny, it's broken". So I installed a used tranny, a new radiator and a new serpentine belt. I saw no fluid leaks of any kind anywhere. She drove the car for two weeks without incident then tells me the battery light came on and the car died. The Interstate battery checked out fine, the alternator had died. I replaced that and she drove the car for three weeks, then the whopper came last week:
She says the ESC off light came on, then "all sorts of other lights flashed" and the car would not move or go in to drive. She had it towed to her house and I then moved it to my house to troubleshoot. The battery and alternator check out good. When I clear the codes I can drive the car for about ten seconds then the tranny locks and all the codes come back. The brakes work fine, BTW. Here are the 10 codes it spat out!!!
1- B2502 - passenger air bag warning lamp
2- B1102 - battery voltage low DTC < 8v
3- C1513 - brake switch circuit error
4- C1611 - controller area network timeout EMS
5- C1616 - CAN bus off
6- C1102 - battery voltage low BTC
7- C2402 - Faulty ABS Motor or Hydraulic Electronic Control Unit (HECU)
8- C1260 - Steering Angle Sensor Circuit-Signal
9- P0733 - gear 3 incorrect ratio (x2)
10- P0734 - gear 4 incorrect ratio (x2)
Has anyone seen this mess before? What's my next step here? Please don't tell me to go to the dealer, not happening. I can check fuses, look for loose ground straps, check for shorts, I can even swap tranny input and output sensors from a 2006 Elantra (they are identical). I just don't know what to do first. Any ideas?
islander21 is offline
post #2 of 10 (permalink) Unread 04-17-2019, 12:21 AM
santa06's Avatar
Quoted: 193 Post(s)
I would start with main body grounds, make sure super clean, even grind off paint for bare metal contact, then light dielectric grease.
Would have been distrurbed during tranny change probably.
Look for chewed main wire harness signs. Grab battery post connections with a glove and try to twist for movement, tighten if they can be moved.
santa06 is offline
post #3 of 10 (permalink) Unread 04-17-2019, 04:30 AM
AUTOSPARK's Avatar
Quoted: 2303 Post(s)
From the codes it certainly looks like you have an issue with a main power supply or ground.
The good news is it seems to be a permanent fault given that you can't drive it for more than 10secs, so it should be fairly easy to diagnose.
I think I've read on the forums here that one of the Sonata engines was known for developing high resistance in the alternator power supply wiring. Maybe @sbr711 can tell us if that effects the V6 engine you have.
AUTOSPARK is offline
post #4 of 10 (permalink) Unread 04-17-2019, 07:41 AM Thread Starter
islander21's Avatar
islander21
OK, I will start that this week-end. I'll put it up on the ramps and go through all the grounding points. Thanks!
post #5 of 10 (permalink) Unread 04-17-2019, 06:55 PM
craigbrooks's Avatar
06 Sonata F24S of course. 01 Mustang GT convertible as well.
Quoted: 31 Post(s)
craigbrooks is an unknown quantity at this point
The main ground to the body under the hood has been an issue. As preventive maint. I ground the paint off mine and reattached with the grease. Try that 1st.
craigbrooks is offline
post #6 of 10 (permalink) Unread 04-18-2019, 07:18 PM Thread Starter
islander21's Avatar
islander21
Will do, thanks!
post #7 of 10 (permalink) Unread 04-27-2019, 11:02 PM Thread Starter
islander21's Avatar
islander21
This is getting weirder. I added a ground from below the battery tray to the transmission. Sanded the paint off the body, cleaned all parts and coated them in dielectric grease. The voltage at the battery and any other points I connected my meter to was 12.8v with the car off. With the engine running it was 13.4v everywhere I checked, so no issues with grounds. Disconnected the battery for 1/2 hour. After I connected it I started the car and ran it for a while. No codes no engine light but both the ESC Off and ABS lights were, could not drive it as it's on jacks - maybe that's why I'm getting those lights, will find out tomorrow.
Came back a few minutes later, started it up and I got code P0160 - an O2 sensor, no data coming from it. I checked out the offending sensor (back behind the cat converter), cleaned the contact and replugged. Cleared the code, and it has stayed away. I also cleaned both ABS contacts in the front hubs, but the light's still on. Gotta research that here on the forum tonight.
Tomorrow I'l check the ABS fuses and the brake switch, and do whatever I find out I need to do to get the ESC Off/ABS light to get cleared.
post #8 of 10 (permalink) Unread Yesterday, 06:48 AM
AUTOSPARK's Avatar
I wouldn't waste any time on this ABS/ESC issue until you have driven the car.
If the front wheels are off the ground with the engine running the ABS/ESC lights should switch on. But they will likely switch off again after you've driven a short distance and the module is seeing plausible signals from all 4 wheels.
post #9 of 10 (permalink) Unread Yesterday, 06:21 PM Thread Starter
islander21's Avatar
islander21
That they did as soon as I dropped it from the jacks, as expected. So I drove the car in the neighborhood this morning and after about 30 seconds the engine light came on and the tranny hesitated for a bit and then it behaved like it was in neutral. I had the code reader handy and it spat out a P0733. I cleared it, the car went into gear for a few seconds and that was it. I had to push it home, had no reverse either. Now I actually have no codes. I'm going to check the tranny linkage to see if it shifted out of position. I have a set of input and output sensors that I can swap as well since I'm going to be in that area. Will inspect the ones I take out to see what condition they are in.
If neither of those work out the Sonata will be sold as is or parted out. Any suggestions either way?
post #10 of 10 (permalink) Unread Today, 03:08 AM
santa06's Avatar
Quoted: 193 Post(s)
May sound weird, but how is fluid level in the installed tranny. Some are really sensitive and a low level could create problems.
Warmed up in neutral, second level check is the valid reading.
Cant really look at the input/output turbine sensors and evaluate their condition.
Are you sure donor tranny was decent wrecker part ?
santa06 is offline
