After market DIY heated seat pads for 09 Sonata GLS - Hyundai Forums : Hyundai Forum
post #1 of 10 (permalink) Old 03-30-2019, 07:44 PM Thread Starter
Drives 2009 Sonata GLS Manual @ 81.5k miles <- Dis my first car!
Quoted: 3 Post(s)
mech_newb is an unknown quantity at this point
Newb here,
Was wondering if it is possible to install an aftermarket heated seat pads that are wired to the OEM heated seat switches?
I have the base model without those switches and looks like I need to buy the parts - switches, wire harness and heated pads.
So was wondering if this is something that I can DIY?
mech_newb is offline
post #2 of 10 (permalink) Old 03-31-2019, 12:14 AM
grcauto's Avatar
Quoted: 1004 Post(s)
Originally Posted by mech_newb View Post
Newb here,
If the wiring is not there.....well????
Best practices for requesting help:If you haven't done so fill in your vehicle info and profile page. At upper right corner under the search box click on user cp (it's your control panel)
This info will show up to the left under your user name and is very helpful.
BE SURE TO ADD YOUR LOCATION SO WE KNOW WHAT MARKET YOU ARE IN.
  • Be sure you are in the correct forum for your vehicle.
  • Do a search for your problem. A lot of stuff has been asked and answered.
  • Do not double post for the same problem.
  • Give the model year....Engine size...transmission type (auto or standard)
  • Take a single issue at a time. Posting multiple issues at once will get convoluted very quickly
  • VIN number can be very helpful
  • Vehicle history can be good. How many miles. If not bought new, how many have you put on it.
  • Describe the problem best you can. If a noise can you get a sound or video file
  • Tell us what has been done, if anything, thus far. If tests have been performed give actual results not OK or passed. If scanned for codes the actual code(s) not O2 sensor or MAF, Etc.
  • If the vehicle has been to a repair facility it would be nice if you could post a picture of that invoice/bill
  • If your vehicle is under warranty you should have the dealer check it out. If it's a problem they see many times they will generate a safety recall of TSB. This is how they know of the problem.
This information can save a lot of time and get you the answers you need much faster.
Thanks,
Welcome aboard.
grcauto is offline
post #3 of 10 (permalink) Old 03-31-2019, 02:31 AM
Valmorphanize's Avatar
Sonata 09 SE V6
Quoted: 3 Post(s)
Valmorphanize is an unknown quantity at this point
I recently put aftermarket heated seats in my car. I did this at the same time a put in and OEM leather seat kit for the whole car. The aftermarket kits come with a wiring harness and switch, I mounted it in the stock location as there is a hollow spot behind the trim to allows the switch to fit with out any other modification other than drilling a hole. I would skip the oem switch, probably not worth the cost and time, alot of the kits are have 2 heat levels, not sure how the OEM switch works but you maybe stuck with one heat setting. You can definitely DIY this but taking the seat apart is pretty time consuming and if you want a good install you will probably have to take the whole seat cover off. If you dont have leather look on Ebay you can still find OEM leather kits , i paid $350 for mine.
Valmorphanize is offline
post #4 of 10 (permalink) Old 03-31-2019, 08:24 AM
AUTOSPARK's Avatar
Quoted: 2287 Post(s)
It's really impossible for us to answer that when we don't know you from Adam. If your "switched on" enough there isn't any reason why you couldn't do the job DIY, but the fact your even asking the question makes me suspect your probably not too confident in your own abilities.
AUTOSPARK is offline
post #5 of 10 (permalink) Old 03-31-2019, 08:41 AM Thread Starter
Quoted: 3 Post(s)
Thanks for the reply Autospark! I can definitely do it and I'm starting out small as well - just changed the turning light bulbs, using smoorman's post on installing fog lights, I'll be installing the combination switch and steering wheel audio control both on the steering wheel and I've ordered them.
In terms of possibility, I don't mean in my abilities, but just in terms of sourcing the parts, the wiring, the console controls etc. esp given that my model is now an old one.
post #6 of 10 (permalink) Old 04-11-2019, 05:43 PM
2010 Sonata
fourwd1
What brand/model seat heaters did you get, and where ?
2010 Sonata GLS 4 cyl
1984 4Runner rock crawler
1989 4Runner stocker
fourwd1 is offline
post #7 of 10 (permalink) Old 04-11-2019, 06:21 PM
Sonata 09 SE V6
Quoted: 3 Post(s)
I got them off Amazon - WATERCARBON Carbon Fiber Seat Heater Kit Hi/Lo Setting
Been in the car for about 2 months, they work well no real complaints.
I chose these because of the pad size, it is bigger than some other brands and will heat the entire seat.
post #8 of 10 (permalink) Old 04-15-2019, 08:50 PM
2010 Sonata
fourwd1
Thanks, all that for $55 is unbelievable
Did you need/get hog rings and hog ring pliers too?
fourwd1 is offline
post #9 of 10 (permalink) Old 04-15-2019, 11:39 PM
Sonata 09 SE V6
Quoted: 3 Post(s)
I did get a set of hog ring pliers and a box of rings, probably good idea to get them. Dont cheap out on them and get a set with good reviews. I installed a leather kit for the car at the same time so i had to redo everything. If i remember correctly middle parts of the seat are held by Velcro and not the hog rings but i cant be sure, i think the install maybe difficult to do with out taking off the entire seat cover in which case you will need the hog rings. Also get a quality pair of diagonal cutters to cut the old rings. Knipex brand is among the best.
post #10 of 10 (permalink) Old Yesterday, 06:47 PM
2010 Sonata
fourwd1
Thanks, I figured they'd be needed.
fourwd1 is offline
