defroster light does not light on 2008 - Hyundai Forums : Hyundai Forum
post #1 of 22 (permalink) Old 12-09-2018, 11:37 PM Thread Starter
Quoted: 7 Post(s)
Remo2110 is an unknown quantity at this point
defroster light does not light on 2008, nor does defroster work(rear). I cannot find a fuse? I am considering just replacing climate control unit. Is there a fuse? Does anyone have an electrical diagram of the back of the control unit as to where a person could test the control unit?
Remo2110 is offline
post #2 of 22 (permalink) Old 12-10-2018, 12:38 AM
2009 Hyundai Sonata 2.4l GLS
Quoted: 9 Post(s)
Pi_User5 is an unknown quantity at this point
According to the manual, there's a 40 amp fusible link in the engine compartment for the defogger relay. I've attached a photo of it from the manual. It's labeled as RR HTD. Might be worth a look.
Last edited by Pi_User5; 12-10-2018 at 12:41 AM. Reason: Defogger, not a defrogger
Pi_User5 is offline
post #3 of 22 (permalink) Old 12-10-2018, 12:43 AM
Drive 2009 Azera TG, 2007 Accent MC, 2009 Sonata NF, 2010 Genesis BH,
Quoted: 183 Post(s)
wongpfh is an unknown quantity at this point
Check Fuse#36 [MIRR HTG Fuse 10A].
wongpfh is offline
post #4 of 22 (permalink) Old 12-10-2018, 04:33 AM
AUTOSPARK's Avatar
Quoted: 2335 Post(s)
Is there a fuse??
Yeah, but not fuse #36. It's the one out on the engine bay that Pi_User5 mentioned.
@wongpfh attached the circuit schematic, but what you really need is the AC control module connector pin out. He can't give you that though until you tell him what AC system your car is fitted with? Is it auto AC with the digital display, or is it manual AC with the three rotary controls?
AUTOSPARK is offline
post #5 of 22 (permalink) Old 12-13-2018, 12:26 AM Thread Starter
Quoted: 7 Post(s)
it is the manual AC with three rotary controls.
Remo2110 is offline
post #6 of 22 (permalink) Old 12-13-2018, 10:03 AM Thread Starter
Quoted: 7 Post(s)
I also replaced fuse in engine compartment. 40 amp. Actually switched it with another.
Remo2110 is offline
post #7 of 22 (permalink) Old 12-13-2018, 12:53 PM
Quoted: 183 Post(s)
A/C diagrams attached.
wongpfh is offline
post #8 of 22 (permalink) Old 12-18-2018, 12:44 PM Thread Starter
Quoted: 7 Post(s)
So I have even tried a different control module. Did not work. Which wires or how do I trace it to see if it works back to fuse?
or what do I do with the diagrams? I can use a multimeter. Do I test the rear defog pin on M22-2, number 23 with the ground Pin, and should get continuity? At a loss as to how to troubleshoot it. Any help would be nice.
Remo2110 is offline
post #9 of 22 (permalink) Old 12-18-2018, 06:07 PM
craigbrooks's Avatar
06 Sonata F24S of course. 01 Mustang GT convertible as well.
Quoted: 31 Post(s)
craigbrooks is an unknown quantity at this point
I'm going to go out on a limb and ask if you checked the connector to the rear window grid or looked for a broken grid?
craigbrooks is offline
post #10 of 22 (permalink) Old 12-18-2018, 09:53 PM
AUTOSPARK's Avatar
The very first thing I would do if I was troubleshooting the fault is check ALL the fuses(ignition on). Test them using a voltmeter or test light rather than removing them all from the fusebox and looking. That's a much quicker and easier way to test them.
The second thing I'd do is bypass the BCM and make sure the relay is able to switch on and supply power to the screen & tell tale light on the switch.
Referring to the defogger diagram you can see that the relay control wire enters the dashboard fusebox on terminal 8 of connector 'C' (blue wire). Locate that wire on the connector and back probe it using a pin (straightened out paper clip). With the connector still plugged into the fusebox, use a length of wire (or the ammeter in your multimeter) to connect the back probe pin to ground. When you ground the back probe you should hear the relay inside the fusebox click and the tell tale light on the switch should illuminate. If not, you'll need to check the relay power supply next, which is on terminal 2 of connector 'G' (heavy red wire).
BTW, a broken heater element/grid or a loose connection on the element power supply wiring shouldn't prevent the switch tell tale light from illuminating, according to the diagram at least.
Location of Fusebox Connector 'C'
