anyone had issues with aftermarket oil filters? - Hyundai Forums : Hyundai Forum
 6Likes
post #1 of 45 (permalink) Old 06-27-2012, 10:12 PM Thread Starter
aqua33V6
My last oil change, I used a Wix oil filter. Previously, I had always used OEM filters from the dealer parts counter. Today at lunch, I fired up the car and noticed a slight knocking sound for 2 to 3 seconds (identical to the sound you get at first start after doing an oil/filter change). Didn't think much of it. Car ran fine when I drove away.
When I got back from lunch, I saw a trail of motor oil on the ground behind my car. Let the car sit for 5 minutes, then checked the oil. It was exactly at the low mark on the dipstick. I had just checked the oil on Sunday, at it had been at the full mark, so this means the car has leaked about a quart of oil in 3 days. Looks like the leak is coming from the oil filter housing area, possibly where the housing connects to the engine underneath the intake plenum.
Anyone know if this leak can be caused by the Wix filter? Maybe an overpressure in the housing, leading to oil blowing by the housing gasket at the engine block? I'm gonna run down to the dealer and get an OEM gasket in the morning. Hopefully this fixes the issue, otherwise the labor would be pretty intensive getting to the leaking gasket.
aqua33V6 is offline
post #2 of 45 (permalink) Old 06-27-2012, 10:31 PM
Sonata NF 2006 3.3
pkbum
Do not use wix oil filter, I know from experience. The wix does not fit on the cap(it does not click when you put it together) and the oil will leak since the cap can not be tightened.
Use on OEM filter or STP. I have been using STP oil filter and it fits perfectly and I have no problem till now.
2006 Sonata 3.3L
Eibach pro kit 4240.140
KYB 341476, 349060
Sony Xplod XS-GT1627A
Kenwood KDC-MP342U
Future project
Bilstein B14 Coilover 47-146331
Double Din JVC Navigation Stereo
Spoiler
Borla Pro Xs Muffler
pkbum is offline
post #3 of 45 (permalink) Old 06-27-2012, 10:38 PM
Sonata NF 2006 3.3
pkbum
Also do not use fram,
f***ing
ruined
another
motor
Karaoke Kop likes this.
2006 Sonata 3.3L
KYB 341476, 349060
Kenwood KDC-MP342U
Future project
Spoiler
pkbum is offline
post #4 of 45 (permalink) Old 06-28-2012, 06:13 AM
2006 Sonata Lx 3.3l V6
bryancurit is an unknown quantity at this point
I had the same problem with the Wix filter, I think the cover o-ring is too small in diameter, and caused an oil leaked when the motor was cold. For the price, I only use OEM filters, plus they give you a new oil drain plug gasket.
bryancurit is offline
post #5 of 45 (permalink) Old 06-28-2012, 10:16 AM
Drives '06 Sonata LX 2015 Genesis 5.0L
Quoted: 7 Post(s)
kn5owa
See TSB 05-20-002 "Use of aftermarket oil filters causing engine knocking noise".
I suspect the O-rings - that's what they're there for - to make a seal. Make sure the new ones are positioned properly and lubed.
Around here the oem filters are priced the same as second source, so why go with stuff like Wix.
kn5owa is offline
post #6 of 45 (permalink) Old 06-28-2012, 10:41 AM
wymi's Avatar
Quoted: 18 Post(s)
I also had noticeable engine knock when using the Wix cartridge filter on my Santa Fe V6. I didn't have any leaking problems but I only left the filter in for about a week before throwing it away and putting an OE filter in. No noise at all during start up with OE filter. I bought 4 filters from my dealer so I have them on hand.
wymi is offline
post #7 of 45 (permalink) Old 06-28-2012, 11:19 AM Thread Starter
aqua33V6
Thanks for the replies everybody. I recall the larger gasket didn't slide onto the cap quite as snug as the OEM gasket. I'll be heading down to the dealer in a few minutes to pick up a filter kit. I happened to do my last oil change at my pops' house. The dealer up there closes early on Saturdays, so I went ahead and got the Wix filter at the local auto parts store. Figured Wix had always served our family well in the past. Guess they screwed up with this particular application though. I'll post an update after I change out the filter.
aqua33V6 is offline
post #8 of 45 (permalink) Old 06-28-2012, 11:47 AM
pare_john's Avatar
Quoted: 42 Post(s)
I always use OE filters. Aftermarket are usually garbage
himilcyclr likes this.
pare_john is offline
post #9 of 45 (permalink) Old 06-28-2012, 12:00 PM
v33sonata's Avatar
06 Hyundai Sonata V6, 85 AE86 20v BT, 02 GSF1200, 07 Toyota FJ Cruser, 94 Southwind
Quoted: 68 Post(s)
I have used wix with no issues so far. I always had issues with fram on my Sonata
v33sonata is offline
post #10 of 45 (permalink) Old 06-29-2012, 04:34 PM
hmr1979's Avatar
2006 Sonata - 3.3 L 2013 Genesis Sedan 2013 Genesis Sedan (Gray) 2006 Azera Ultimate
Quoted: 173 Post(s)
hmr1979 is an unknown quantity at this point
Genuine hyundai filters for like 6 bucks from ebay, just get a bunch of em at once and be done with it for the year or two.
hmr1979 is offline
