I've been having issues with my accent, most recently throwing DTC U0101. While driving, the RPM needle will free-fall almost to zero, but the engine seems to be running fine. CEL does NOT come on, but my code scanner shows a "pending error" of U0101. Not sure if I should be concerned or what I should do?
I had issues recently with my purge control valve that I just sorted out, and when I got my inspection in February, they had to weld an exhaust bracket and my radio is randomly cutting out (maybe some kind of stray voltage issue?)
