LED Intelligent System - Hyundai Forums : Hyundai Forum
post #1 of 29 (permalink) Old 12-19-2017, 08:57 PM Thread Starter
Quoted: 95 Post(s)
Ctrcbob is an unknown quantity at this point
I've been very disappointed with the headlights of my 2018 2.0T Limited. Here are the two problems with the LED "Dynamic Bending Light" headlights. (LED Intelligent System).
1. Biggest problem is that there is no Cornering Lights to light up those dark UNLIGHTED street corners, driveways, or when entering some expressways from a DARK feeder road. I've had cars with and without Cornering lamps and never had this problem. The problem could be caused by either the LED bulbs or more probably by the reflector.
2. Second problem is the amount of light put out by the LED bulb is not as good as the HID bulbs in my 2015 Sport 2.0T Limited. Also, the 2018's "Dynamic Bending Light " does not "bend" or if it does, it bends very little. (I've had other cars with this feature, that all worked correctly). Also, the LED Bulbs projection has a Black (unlighted) spot in the "cutoff" area. (I found that the black spot is common when I checked out bulbs for sale). Don't like the "Color Temperature" of the LED. Color Temp is much better with the HID. Also the "cutoff" is so sharp, that you can't see road signs on the side of road, or unlighted overhead signs. (FWIW, I liked Quarts QI/QH best - like H4 bulbs).
My favorite Hyundai Technician has checked the Hyundai Service Line and there is nothing in there to correct these problems on my 2018.
The HID's of the 2015, (bulb D3S 35w) although not perfect, are better than the LED's of the 2018.
Don't like driving the 2018 at night. Normally take the 2015 when dark.
I think it's time to report the DANGEROUS Sonata LED Intelligent System of the 2018 to the NHTSA.
Ctrcbob is offline
post #2 of 29 (permalink) Old 12-20-2017, 02:05 AM
2015 Sonata Sport 2.4
Quoted: 438 Post(s)
Grady Wilson is an unknown quantity at this point
You can report it but if the headlamps are within Federal specs that is nothing they can or will do about it.
There would have to be dozens of complaints before they even took a look at the headlights.
Grady Wilson is offline
post #3 of 29 (permalink) Old 12-20-2017, 08:41 AM
kocyk123's Avatar
Drives 2018 Sonata Limited + Ultimate Pkg and 2001 Audi A8L
Quoted: 91 Post(s)
kocyk123 is an unknown quantity at this point
I have the LED dynamic bending light and see no problem with them. I really enjoy driving them at night. I also have that black spot at the cutoff but it does not bother me. However, my headlights would not light up too much in front of me so I had to re-adjust them (raise them up a bit). Once I set them up properly, I can really see at night and they really give good light output in my opinion. I am also not having issues seeing road signs. But that is only me and my own experience.
My current rides:
2015 Genesis 3.8 AWD Ultimate 37k miles
Gone:
2018 Sonata Limited + Ultimate Package - 19000+ miles
kocyk123 is offline
post #4 of 29 (permalink) Old 12-20-2017, 10:15 AM
Thornleydf's Avatar
2018 Sonata Limited 2.4 L, 2017 Sonata Limited 2.4 L
Quoted: 24 Post(s)
Thornleydf is an unknown quantity at this point
I have the dynamic bending LED’s as well. No problems. Good range of movement on the bending.
Thornleydf is offline
post #5 of 29 (permalink) Old 12-20-2017, 12:48 PM
ratledge's Avatar
2015 Genesis Ultimate 3.8L 2018 Santa Fe Ultimate w/Tech
Quoted: 135 Post(s)
ratledge is an unknown quantity at this point
You do know that it (Dynamic Bending) only works when the lights are in the automatic mode, right?
Not going to happen if you turn them on manually, although self leveling works (if you have that).
'08 (Black on Black) Azera Limited / Ultimate 200K+
(just traded in for the MY18 SFSU+Tech)
'15 (Platinum w/Black) Genesis 3.8 Ultimate with fogs jacked on
' 18 (Red w/Beige) Santa Fe Sport Ultimate w/Tech pkg
ratledge is offline
post #6 of 29 (permalink) Old 12-20-2017, 02:09 PM Thread Starter
Quoted: 95 Post(s)
How do you raise them up a bit? Where are the adjustment screws? Do you use a screwdriver or a wrench?
Ctrcbob is offline
post #7 of 29 (permalink) Old 12-20-2017, 02:22 PM
kocyk123's Avatar
Quoted: 91 Post(s)
It is easy. Make sure you are on level surface. There is a black bolt behind each headlight that you can adjust using both short phillips screwdriver or a wrench. There might be two bolt, one controlling up and down an another controlling left right. Look at the indicators right by small holes on the plastic above the headlight.
My current rides:
Gone:
kocyk123 is offline
post #8 of 29 (permalink) Old 12-20-2017, 02:28 PM
Phych's Avatar
"CARDIS" 2015 Sonata 2.0T Limited Lakeside Blue
Quoted: 252 Post(s)
Phych is an unknown quantity at this point
Maybe everyone put up some videos of your headlights in action. That way, everyone can compare how their lights are operating compared to others.
Phych is offline
post #9 of 29 (permalink) Old 12-20-2017, 06:50 PM
kocyk123's Avatar
Quoted: 91 Post(s)
Here is short video of mine Dynamic Bending headlights:
My current rides:
Gone:
kocyk123 is offline
post #10 of 29 (permalink) Old 12-20-2017, 08:02 PM Thread Starter
Quoted: 95 Post(s)
Mine does not do that. I'm going to visit my dealer Hyundai Tech and show him the video. (BTW, I know the video is correct because I see the black spots at the top of the cutoff area.)
Ctrcbob is offline
