work shop manual & electrical troubleshooting manual for 2003 accent - Page 10 - Hyundai Forums : Hyundai Forum
 7Likes
post #91 of 116 (permalink) Old 11-06-2018, 04:30 PM
Dives 2001 Accent, 2005 Honda CRV. 2009 Kia spectra
Quoted: 16 Post(s)
mike@720 is an unknown quantity at this point
Originally Posted by [email protected] View Post
Pin 5 has a constant 12 v
Rear lamps work normally, left, right and hazard, Left and right turn tell tales on dash too fast. Both hazard tell tales flash at normal speed. I am measuring on large yellow connector on driver's side
Can you send me the wiring diagram showing pin numbers and where they connect to.
I am on the female side of connector
post #92 of 116 (permalink) Old 11-06-2018, 04:36 PM
AUTOSPARK's Avatar
Quoted: 2366 Post(s)
What do you have on 6, 7 & 8 when the hazard lights are switched on?
AUTOSPARK is offline
post #93 of 116 (permalink) Old 11-06-2018, 06:27 PM
Quoted: 16 Post(s)
I discovered the convention is to read pins from right to left on the female connector. That is right to left on the top part of the EM02 Drawing.
With connector disconnected:
With hazards on, Pin 5 has alternating 12 V (flashes)
Pin 6 steady 12v
Pins 7 & 8 0v
Right tell tale only flashes
post #94 of 116 (permalink) Old 11-06-2018, 08:08 PM
Quoted: 16 Post(s)
I appreciate all the time you are putting in to help me.
Backing up a little:
My Accent is 2001
Rear turn signals work (but flash quickly)
Rear hazards work
Front turn signals /hazards do not work.
Changed front lamps though they looked ok
Checked fuse #7 in cabin
Swapped out flasher-no help
Reinstalled original flasher
EMO2 pin 5 flashes (12 v on and off). Steady 12 v on pin 6 ( counting right to left on female side)
Can we tell where flasher signal from pin 5 goes next?
post #95 of 116 (permalink) Old 11-07-2018, 04:22 AM
AUTOSPARK's Avatar
Sorry, I can't.
Referring back to the circuit diagram kindly supplied by wongpfh (post #77), the turn signal circuit should have no connection to pin 5 of EM02.
Ah, wait. I think I see where you've gone wrong....
You said the left tell tail wasn't working earlier when you had that connector unplugged. Looking at the diagram, the left hand turn signal circuit passes through connector MI04 on pin5. Could you perhaps be looking at the wrong connector?
Compare the connector your probing on your car carefully to the drawing I attached earlier. Does the connector on the car have capacity for 23 terminals as shown on the drawing (it won't necessarily have 23 terminals installed), or does it only have capacity for 15?
post #96 of 116 (permalink) Old 11-07-2018, 06:31 PM
Quoted: 16 Post(s)
Sorry, I can't.
I am pretty sure I am on EM02 large yellow connector held against wall on Driver's side, same number and layout of pins as drawing.
With connector disconnected left tell tale does not light when hazard switch is on. Works in all other modes.
Is it possible we have the wrong schematic? Maybe double check for vin KMHCG45C51U146385
Can I access Post #77 and see the schematic?
post #97 of 116 (permalink) Old 11-07-2018, 06:44 PM
Quoted: 16 Post(s)
My accent is 2001 while the thread is for 2003 Accent. Could that be the problem?
post #98 of 116 (permalink) Old 11-07-2018, 07:00 PM
AUTOSPARK's Avatar
If you look at the diagram you'll see why that is. Follow the line coming off terminal 9 of the hazard switch and you'll see that it passes through connector MI04 on terminal 5. With the connector unplugged power from the hazard switch can't reach the tell tale, or any of the other left hand lamps. But the power from the turn signal switch is directly connected to the left hand lamps, so the tell tale works when using the turn signal switch.
This seems to confirm you are probing MI04, not EM02.
Unlikely.
You mean you aren't already using the diagram attached to post #77?
I've attached it again below....
post #99 of 116 (permalink) Old 11-07-2018, 11:27 PM
Quoted: 16 Post(s)
Unlikely.
Thanks for the diagrams -I see now 7&8 on EM02 are where i want to be.
The connector I am on is yellow 23 pins below 10 on top.(gap between 5 and 6) Type EM02 (per the pinout drawing of EM01 ,EM02 and EM03
So I need to find another large yellow EM02
under the dash (is it possible there are two)?
post #100 of 116 (permalink) Old 11-08-2018, 06:29 AM
AUTOSPARK's Avatar
So I need to find another large yellow EM02 under the dash (is it possible there are two)?
Yes, there are two.
The photo below turned up in a quick google search. It shows the locations of EM02 and MI04, but according to the photo EM02 is a 23way yellow connector and MI04 is a 15way yellow connector.
