engine turns off but goes to acc and wont go off - Hyundai Forums : Hyundai Forum
post #1 of 4 (permalink) Old 03-22-2019, 09:25 PM Thread Starter
jordanajungman is an unknown quantity at this point
Exclamation engine turns off but goes to acc and wont go off
when I press the button to turn off my 2014 azera, it goes to acc instead of off. on the dash it says to put it in park but when you turn it back on it shows it is in park. moved it around a few times, then drove it home and still same problem. when you put it in drive, the doors lock and when you put it in park the doors unlock. I go out and push it to make sure it is in park, and it doesn't budge. no clue what to do and the dealership has never seen it before. Just wish I could lock my doors.... any ideas? I already took out the battery and made sure the shift cable was lined up in neutral and that it was going all the way into park.
jordanajungman is offline
post #2 of 4 (permalink) Old 03-22-2019, 10:23 PM
grcauto's Avatar
Quoted: 1012 Post(s)
Is this a US car?
Best practices for requesting help:If you haven't done so fill in your vehicle info and profile page. At upper right corner under the search box click on user cp (it's your control panel)
This info will show up to the left under your user name and is very helpful.
BE SURE TO ADD YOUR LOCATION SO WE KNOW WHAT MARKET YOU ARE IN.
  • Be sure you are in the correct forum for your vehicle.
  • Do a search for your problem. A lot of stuff has been asked and answered.
  • Do not double post for the same problem.
  • Give the model year....Engine size...transmission type (auto or standard)
  • Take a single issue at a time. Posting multiple issues at once will get convoluted very quickly
  • VIN number can be very helpful
  • Vehicle history can be good. How many miles. If not bought new, how many have you put on it.
  • Describe the problem best you can. If a noise can you get a sound or video file
  • Tell us what has been done, if anything, thus far. If tests have been performed give actual results not OK or passed. If scanned for codes the actual code(s) not O2 sensor or MAF, Etc.
  • If the vehicle has been to a repair facility it would be nice if you could post a picture of that invoice/bill
  • If your vehicle is under warranty you should have the dealer check it out. If it's a problem they see many times they will generate a safety recall of TSB. This is how they know of the problem.
This information can save a lot of time and get you the answers you need much faster.
Thanks,
Welcome aboard.
grcauto is offline
post #3 of 4 (permalink) Old 03-31-2019, 02:26 AM
MrVivona's Avatar
I drive a 2014 Azera Limited and my wife drives a 2012 Santa Fe Ltd.
Quoted: 279 Post(s)
MrVivona is an unknown quantity at this point
Start with the easy stuff.
1. Check the voltage across the battery with the car at idle to be sure it is at the correct range of 13.5-15v.
2. Check the alternator ripple voltage.
3. Look for a loose ground wire or harness under the hood or under the dash.
4. Connect a code reader that reads all the Hyundai system codes and see if any codes show up.
Beyond that, it gets more complicated and will require the factory service manual and a Hyundai diagnostic computer to check all the sensors and functions related to starting and stopping the engine. Cars have become much more complicated electronically and use a CAN bus to communicate between the various computers. It isn't a simple job of wire tracing with a meter anymore. You'll have to take it to the dealer.
MrVivona is offline
post #4 of 4 (permalink) Old 03-31-2019, 10:40 AM
MrVivona's Avatar
Quoted: 279 Post(s)
Here is a link to the online service manual section regarding the start stop push button - Hyundai Azera: Button Engine Start System - Body Electrical System - Hyundai Azera 2011-2019 Service Manual
You can look through other pages at that site for information on the shift lever and transaxle range switch.
MrVivona is offline
