Advices on Hyundai Getz problem - Hyundai Forums : Hyundai Forum
post #1 of 4 (permalink) Old 05-09-2019, 03:07 AM Thread Starter
joe77 is an unknown quantity at this point
Hi,
Recently, my car 9-years old Hyundai Getz have started to add new problems
Vibration - when in D or R, and hold the break will cause it
Heavy/Slow - the break LED appear and seems quite sensitive when breaking, acceleration is slow
I already changed the spark plug twice because it have misfiring problem previously, now new problems arise which not sure what's actually is. I heard it could be idling control but not so sure about it.
Can you suggest and advice what to check on? Thank you.
joe77 is offline
post #2 of 4 (permalink) Old 05-09-2019, 03:34 AM
Drives Hyundai I30 CRDI; 78 LB lancer heavily modified; Holden VR V8; Mitsubishi Starion; 67 Toyota
Quoted: 595 Post(s)
charlescrown is an unknown quantity at this point
Harsh vibration can be attributed to engine mounts. I am concerned abt the brake LED? Check the brake fluid level and post back then we can go from there.
charlescrown is offline
post #3 of 4 (permalink) Old 05-18-2019, 06:22 PM
Hyundai Getz
Quoted: 21 Post(s)
childishgambino6899 is an unknown quantity at this point
Originally Posted by joe77 View Post
Hi,
If it continues to misfire I would suggest replacing the plugs and leads and maybe even the coil to eliminate all of those components at once and it is quite common for the Getz engine mounts to fail especially the rubber (left side) and hydraulic (right side) especially that the car is 9 years old
Sent from my Pixel 3 XL using Tapatalk
childishgambino6899 is offline
post #4 of 4 (permalink) Old 05-25-2019, 06:24 AM
2003 Getz 1.3I
JFGoldfish is an unknown quantity at this point
I would clean the idle control valve to rule that out. They can get abit gummed up after years.
Did you gap the new plugs correctly? Sometimes a wide gap on new plugs can cause abit of roughness at idle.
Clean the MAF or map sensors if you suspect them, they can also cause a little roughness when old and dirty.
Check the intake air temperature sensor with an obd reader. If it is not reading correctly it will cause the ECU to deliver poor mixture (same with the MAF or map).
Don't just throw parts at it! Check the leads and ignition coils with a multimeter and visually before thinking about replacing them. Make sure all HT connections are tight and clean. A little silicon grease helps keep moisture out of the plug boots.
Good luck, shout if you need any help 🙂
Edit:
I agree with Charles though, the vibration could be engine mounts and the brake issue is a separate and more concerning issue that needs to be taken care of
JFGoldfish is offline
