Getz power window problem - Hyundai Forums : Hyundai Forum
 1Likes
  • 1 Post By AUTOSPARK
post #1 of 6 (permalink) Old 05-07-2019, 11:32 AM Thread Starter
Hyundai Getz
Quoted: 2 Post(s)
postolis is an unknown quantity at this point
Hello everyone ,
i have a hyundai getz 1100cc 2002 model and recently the passenger power window stopped working properly.It can go down but sometimes it doesnt go up either from passengers switch or the drivers.i checked the connections on the switch with a multimeter and seemed fine i also connected the motor directly to 12 volts and worked without a problem . Any ideas what is the problem?
postolis is offline
post #2 of 6 (permalink) Old 05-07-2019, 02:33 PM
grcauto's Avatar
Quoted: 1042 Post(s)
Originally Posted by postolis View Post
Hello everyone ,
You need to check the wiring and find the common area that will effect both switches.
Best practices for requesting help:If you haven't done so fill in your vehicle info and profile page. At upper right corner under the search box click on user cp (it's your control panel)
This info will show up to the left under your user name and is very helpful.
BE SURE TO ADD YOUR LOCATION SO WE KNOW WHAT MARKET YOU ARE IN.
  • Be sure you are in the correct forum for your vehicle.
  • Do a search for your problem. A lot of stuff has been asked and answered.
  • Do not double post for the same problem.
  • Give the model year....Engine size...transmission type (auto or standard)
  • Take a single issue at a time. Posting multiple issues at once will get convoluted very quickly
  • VIN number can be very helpful
  • Vehicle history can be good. How many miles. If not bought new, how many have you put on it.
  • Describe the problem best you can. If a noise can you get a sound or video file
  • Tell us what has been done, if anything, thus far. If tests have been performed give actual results not OK or passed. If scanned for codes the actual code(s) not O2 sensor or MAF, Etc.
  • If the vehicle has been to a repair facility it would be nice if you could post a picture of that invoice/bill
  • If your vehicle is under warranty you should have the dealer check it out. If it's a problem they see many times they will generate a safety recall or TSB. This is how they know of the problem.
This information can save a lot of time and get you the answers you need much faster.
Thanks,
Welcome aboard.
grcauto is offline
post #3 of 6 (permalink) Old 05-07-2019, 02:44 PM Thread Starter
Hyundai Getz
Quoted: 2 Post(s)
Thank you for your answer i will check the connection and hope the problem is there
postolis is offline
post #4 of 6 (permalink) Old 05-07-2019, 05:45 PM
Hyundai Getz
Quoted: 21 Post(s)
childishgambino6899 is an unknown quantity at this point
Hello everyone ,
I would try swapping out the switch if the power seems ok those switches are in series and I think the passenger side is the last in the line. I hope this helps
Sent from my Pixel 3 XL using Tapatalk
childishgambino6899 is offline
post #5 of 6 (permalink) Old 05-08-2019, 03:58 AM
2011 Getz SX 3dr Man. 1.6L
Quoted: 6 Post(s)
Eggy is an unknown quantity at this point
I had a similar problem with my Mazda. I just replaced the motor, it didn't have the torque to wind the window up.
Worked fine with no load but unable to move the window.
Had the capacitor blown? (gcauto)
Eggy is offline
post #6 of 6 (permalink) Old 05-08-2019, 05:42 AM
AUTOSPARK's Avatar
Quoted: 2359 Post(s)
I'd say one of the switches failing is the most likely cause, assuming the window doesn't even try to move up. As above, the two switches are connected in series, so it could be either the driver's door switch or the one on the passenger door.
FWIW, in my experience, it's more often the one on the driver's door that causes the problems. But I always do a bypass test to confirm before replacing anything.
No, I doubt that.
Eggy likes this.
AUTOSPARK is online now
