Flashing Immob light - Hyundai Forums : Hyundai Forum
 7Likes
post #1 of 17 (permalink) Old 03-25-2019, 05:00 AM Thread Starter
Quoted: 11 Post(s)
mrhr33 is an unknown quantity at this point
Hi all,
I have a 2005 Getz 1.5L DOHC
Went to start it the other morning and no go....
Noticed the immob light flashing (5 times) then out.
Done my research and found a potential issue with the antenna coil around the ign coil.
Cut the plug off and solder the wires straight through.... No change in engine start
Grabbed another smartra box from a wreck, installed and still no go ( 5 flashes then out)....
Before i started i had a code P1690 Smartra fault... but this is not identified in the workshop manual?
Any ideas where to from here please? We are remote NT and cannot access a dealer, or even a mechanic for that matter
PR
mrhr33 is offline
post #2 of 17 (permalink) Old 03-25-2019, 12:19 PM
grcauto's Avatar
Quoted: 1044 Post(s)
Originally Posted by mrhr33 View Post
Hi all,
PR
A scan tool is you friend.
Best practices for requesting help:If you haven't done so fill in your vehicle info and profile page. At upper right corner under the search box click on user cp (it's your control panel)
This info will show up to the left under your user name and is very helpful.
BE SURE TO ADD YOUR LOCATION SO WE KNOW WHAT MARKET YOU ARE IN.
  • Be sure you are in the correct forum for your vehicle.
  • Do a search for your problem. A lot of stuff has been asked and answered.
  • Do not double post for the same problem.
  • Give the model year....Engine size...transmission type (auto or standard)
  • Take a single issue at a time. Posting multiple issues at once will get convoluted very quickly
  • VIN number can be very helpful
  • Vehicle history can be good. How many miles. If not bought new, how many have you put on it.
  • Describe the problem best you can. If a noise can you get a sound or video file
  • Tell us what has been done, if anything, thus far. If tests have been performed give actual results not OK or passed. If scanned for codes the actual code(s) not O2 sensor or MAF, Etc.
  • If the vehicle has been to a repair facility it would be nice if you could post a picture of that invoice/bill
  • If your vehicle is under warranty you should have the dealer check it out. If it's a problem they see many times they will generate a safety recall of TSB. This is how they know of the problem.
This information can save a lot of time and get you the answers you need much faster.
Thanks,
Welcome aboard.
mrhr33 likes this.
grcauto is offline
post #3 of 17 (permalink) Old 03-25-2019, 06:54 PM
AUTOSPARK's Avatar
Quoted: 2367 Post(s)
The 1690 code means there is a problem with the communications link between the SMARTRA and the engine PCM.
The first thing I would do is check the SMARTRA module power supply and ground (pinout shown below). It obviously can't talk to the PCM if it isn't being powered up.
The colours don't represent the colours of the car wiring.
mrhr33 likes this.
AUTOSPARK is offline
post #4 of 17 (permalink) Old 03-26-2019, 04:32 AM Thread Starter
Quoted: 11 Post(s)
Thanks, i will check.
Would you have a pin out of the ECM/PCM?
Maybe i can check continuity between the two after checking the above....
PR
mrhr33 is offline
post #5 of 17 (permalink) Old 03-26-2019, 06:57 AM
AUTOSPARK's Avatar
PCM connector pinout below. According to my info the immobilizer comms wire is on terminal 52.
ECU harness connector. Not the module this time
mrhr33 likes this.
post #6 of 17 (permalink) Old 03-26-2019, 08:14 PM Thread Starter
Quoted: 11 Post(s)
Thanks mate.
The scan tool said i was not getting key learnt within the immob circuit-
*1st issue was a bad Main relay (under bonnet), when i connected power to it, all contacts had continuity- replaced it with another i had, now good.
I now have key learnt on scan tool and the immob symbol on the dash has stopped flashing and stays on solid.
Engine still cranking- no start
re scanning the system and no fault codes?
Scan tool shows live data-
Fuel pump on when cranking
Crankshaft position sensor on when cranking
Anyone think of anything else please?
PR
mrhr33 is offline
post #7 of 17 (permalink) Old 03-26-2019, 09:42 PM
grcauto's Avatar
Thanks mate.
PR
Try starting using alternative fuel source. Carb cleaner etc.
mrhr33 likes this.
grcauto is offline
post #8 of 17 (permalink) Old 03-27-2019, 01:16 AM Thread Starter
Quoted: 11 Post(s)
Yep it runs on fumes, then stops once you stop spraying....
mrhr33 is offline
post #9 of 17 (permalink) Old 03-27-2019, 01:52 AM
AUTOSPARK's Avatar
If the main relay was bad there would be no power supplied to the SMARTRA. There wouldn't be any power supplied to the PCM either though, which means your scan tool wouldn't communicate with it to read the code.
Anyway, glad you've now got a good key status.
Your new problem appears to be with the fuel supply to the engine in that case. The scan tool says the PCM is switching the pump on but have you actually checked that it is running? The first thing I would do is check there is power being supplied to the fuel pump check terminal DURING CRANK. It's located on the engine bay fusebox, marked F/P CHK on the inside of the lid.
mrhr33 likes this.
post #10 of 17 (permalink) Old 03-27-2019, 02:38 AM Thread Starter
Quoted: 11 Post(s)
Yes it has power when cranking (battery equivalent).
I then checked power at the in tank pump- ok
I pulled the pump out and powered it to compare with another i have here- it seemed lazy / slower than the other one.
I have installed the second hand one now, and i can here it running when i crank now....
Still no start!
mrhr33 is offline
