Clean fuel injectors - Hyundai Forums : Hyundai Forum
post #1 of 9 (permalink) Old 11-18-2018, 05:43 PM Thread Starter
Hyundai Getz
Quoted: 21 Post(s)
childishgambino6899 is an unknown quantity at this point
Hi all, does anyone know how to remove the fuel injectors and know how to clean them. I believe they're dirty as I'm getting hesitation and jerking when I press on the the accelerator and let off, I've replaced the coil pack plugs and leads alright and I've cleaned the throttle body and adjusted the accelerator cable and still persists
Sent from my ONEPLUS A3000 using Tapatalk
childishgambino6899 is offline
post #2 of 9 (permalink) Old 11-18-2018, 06:02 PM
Johns2.0T's Avatar
2014 Sport Sante Fe 2.0T
Quoted: 49 Post(s)
Johns2.0T is an unknown quantity at this point
i would 1st run 1 tank of shell Vpower just because its got 5x times the cleaning detergent than any other fuel sold if that still dont do it then run a can of BG 44k in a full tank of fuel
Johns2.0T is offline
post #3 of 9 (permalink) Old 11-18-2018, 06:20 PM Thread Starter
Hyundai Getz
Quoted: 21 Post(s)
Oh ok I'll give that a shot then thanks. I did use the Valvoline fuel injector cleaner additive but it honestly hasn't done anything.
post #4 of 9 (permalink) Old 11-18-2018, 10:13 PM
grcauto's Avatar
Quoted: 1044 Post(s)
How many miles? Fuel additive is very likely not going to help if the problem is injectors. You'll want to run the proper cleaner right through the fuel rail.
grcauto is offline
post #5 of 9 (permalink) Old 11-18-2018, 10:32 PM Thread Starter
Hyundai Getz
Quoted: 21 Post(s)
It's 280,000 KMs so I think that's 174, 000 miles ish and what sort of cleaner am I looking for can this be done at home or is this something for my mechanic to look at ?
post #6 of 9 (permalink) Old 11-18-2018, 10:56 PM
grcauto's Avatar
It requires a special tool that is fitted into the fuel rail at a point where the line from the tank hooks into the fuel rail. The fuel pump is disabled and you run the engine on the cleaner. It does a far superior job than any additive you use in the tank. To bad they don't use a shrader valve on those. There a fairly inexpensive tool that you can use with one of those valves.
grcauto is offline
post #7 of 9 (permalink) Old 11-18-2018, 11:36 PM Thread Starter
Hyundai Getz
Quoted: 21 Post(s)
Well in that case I think it's better off that the mechanic does that, I wonder how much such a clean would cost ? Because I found all 4 genuine injectors for $500 would it be anywhere close to that ?
post #8 of 9 (permalink) Old 11-19-2018, 12:46 AM
grcauto's Avatar
Call around and ask. Shouldn't be over $150 to $200 at most. It's been a while but we did them for about $100 and that was maybe 4 or 5 years ago. We had a 3M system that worked real well and if it was a shrader valve it was never over $90 for a single clean. The cleaner was about $25 and a half hour labor for the most part.
grcauto is offline
post #9 of 9 (permalink) Old 11-19-2018, 12:53 AM Thread Starter
Hyundai Getz
Quoted: 21 Post(s)
Oh that's alright then If they're still around that price but I'll ask my mechanic when it goes in for its next service. Thanks for your expertise
