Hyundai Getz 2009 radio LCD just says HYUNDAI - Hyundai Forums : Hyundai Forum
 2Likes
post #1 of 12 (permalink) Old 11-04-2018, 02:29 AM Thread Starter
Quoted: 6 Post(s)
antoniecmalan is an unknown quantity at this point
Smile Hyundai Getz 2009 radio LCD just says HYUNDAI
Hyundai Getz 2009 radio LCD just says HYUNDAI when switching on and stays like that. I've removed to fuse to reset the thing but it's still the same. Looks like the thing doesn't even know the fuse was removed although the clock and radio LCD were dead on switching on with the fuse removed. Any ideas?
antoniecmalan is offline
post #2 of 12 (permalink) Old 11-04-2018, 02:33 AM
Old's Cool's Avatar
2005 Scion tC; 1988 Toyota Supra; 2009 Hyundai Accent Wheezer 1.6; 96 Subaru Outback (soon)
Quoted: 3747 Post(s)
Old's Cool is an unknown quantity at this point
How long? Should be at least 30 seconds, more likely a minute. Also there are two fuses, one for the Power and one for the "hold up" that maintains station entries and settings. You have to remove this one, too, tho on the Getz I don't know where it would be. Maybe @AUTOSPARK could help you out...
Do you know any satisfying profanity?!
It's all fun and games until someone loses his mind-Fred C. Dobbs
<<click...
2009 Accent Hatch
I find it works well enough to get me from one planet to another.
Old's Cool is offline
post #3 of 12 (permalink) Old 11-04-2018, 02:44 AM Thread Starter
Quoted: 6 Post(s)
Smile That was quick
I'm an oldy, too. 67 and not getting any younger. It was much more than a minute. I'll go hunting for the 'hold up' fuse now. Thanks for the help.
post #4 of 12 (permalink) Old 11-04-2018, 04:20 AM
AUTOSPARK's Avatar
Quoted: 2338 Post(s)
The 'hold up' fuse (AKA memory or transport fuse) is the one in the yellow carrier on the dashboard fusebox. Pull the carrier towards you will disconnect the fuse. Once the memory has been erased, push the carrier back in towards the fusebox, which will reconnect the fuse.
Your radio might be waiting for you to enter the security code. Have you tried pressing any of the preset buttons to see if that changes what's shown on the display?
AUTOSPARK is offline
post #5 of 12 (permalink) Old 11-04-2018, 05:04 AM Thread Starter
Quoted: 6 Post(s)
Again, a quick reply
Thanks for this. Trying to enter the security code does nothing. This happened after coming from the archery club this afternoon. The last bit off the tar-sealed road is very washed out, but I always take it very slowly.
Please see the attached two photos. Is the 'yellow carrier' the wide yellow thing at the lower left end of the fuse box? On the lid it's marked as a 15Amp fuse labelled Power Conn & R/LP.
BTW, the radio still swallows a CD but does not play it. It also ejects it and the LCD then says something like eject. It does not seem irrevocably broken.
Thanks.
post #6 of 12 (permalink) Old 11-04-2018, 06:29 AM
AUTOSPARK's Avatar
Yes, that's it. The fuse in that carrier powers the interior lights, that's what R/LP means (Room Lamp) but it also powers the memory for the radio and the clock.
When the car comes to the dealership from the factory that yellow carrier is pulled out so that if a door is left ajar the interior lamp wont drain the battery. It's pushed in by the dealership technician when he does the pre-delivery inspection on the car.
post #7 of 12 (permalink) Old 11-04-2018, 09:34 AM
Old's Cool's Avatar
Thanks.
You want to pull two at once. According to your fuse panel legend, you want to pull the one in the yellow carrier, and also the 15A one in the topmost right spot labeled "Audio". Pulling both of these should completely reset the radio. You would think, with the key OFF, the 15A fuse would have any effect, but stranger things have happened!
ALso, check and see if the radio itself has a RESET somewhere. It's usually a little pinhole generally located near the CD slot on most car radios. In some cases it is on the back. With both fuses pulled, take a paper clip or needle, etc and press and hold the reset for about 1 minute. Then plug the fuses back in and we'll see what happens!
Good luck.
<<click...
2009 Accent Hatch
post #8 of 12 (permalink) Old 11-04-2018, 10:28 PM Thread Starter
Quoted: 6 Post(s)
Smile Thanks
Good luck.
Hi Old Cool,
Did that and the LCD came up blank. Then I noticed the reset button just below the clock. Pushed that and it asked for the code. Entered that and all was hunky dory. Set up only one FM station - the classical one.
You want colourful invective. Try calling someone a scrofulous poltroon. Scrofulous may refer either to the disease, scrofula, or to a pig - sus scrofa. You will be calling your adversary a coward and a pig.
Thanks again.
Old's Cool likes this.
post #9 of 12 (permalink) Old 11-06-2018, 01:01 AM
Old's Cool's Avatar
Hi Old Cool,
Thanks again.
I'm sitting here laughing my @$$ off! I know what a poltroon is, but Scrofulous...thank you!
I usually use scurrilous, myself.
Glad your radio came back!
<<click...
2009 Accent Hatch
post #10 of 12 (permalink) Old 11-06-2018, 01:06 AM
Old's Cool's Avatar
Hi Old Cool,
Thanks again.
PS: I always considered myself a cunning linguist, but I believe I have been bested!
<<click...
2009 Accent Hatch
