Dash cluster swap - Hyundai Forums : Hyundai Forum
post #1 of 5 (permalink) Old 03-16-2019, 06:08 AM Thread Starter
Drives Hyundai Tucson Highlander Drives Hyundai I30 SR Drives Hyundai Getz SX
Quoted: 6 Post(s)
HyundaiTucson is an unknown quantity at this point
Dash cluster swap
In a 1998 excel base model with no tacho, can you straight swap the instrument cluster to one with a tacho? Is the wiring all there ready to go?
HyundaiTucson is offline
post #2 of 5 (permalink) Old 03-16-2019, 11:24 AM
grcauto's Avatar
Quoted: 1036 Post(s)
I'm not sure about that. Someone will chime in.
Best practices for requesting help:If you haven't done so fill in your vehicle info and profile page. At upper right corner under the search box click on user cp (it's your control panel)
This info will show up to the left under your user name and is very helpful.
BE SURE TO ADD YOUR LOCATION SO WE KNOW WHAT MARKET YOU ARE IN.
  • Be sure you are in the correct forum for your vehicle.
  • Do a search for your problem. A lot of stuff has been asked and answered.
  • Do not double post for the same problem.
  • Give the model year....Engine size...transmission type (auto or standard)
  • Take a single issue at a time. Posting multiple issues at once will get convoluted very quickly
  • VIN number can be very helpful
  • Vehicle history can be good. How many miles. If not bought new, how many have you put on it.
  • Describe the problem best you can. If a noise can you get a sound or video file
  • Tell us what has been done, if anything, thus far. If tests have been performed give actual results not OK or passed. If scanned for codes the actual code(s) not O2 sensor or MAF, Etc.
  • If the vehicle has been to a repair facility it would be nice if you could post a picture of that invoice/bill
  • If your vehicle is under warranty you should have the dealer check it out. If it's a problem they see many times they will generate a safety recall of TSB. This is how they know of the problem.
This information can save a lot of time and get you the answers you need much faster.
Thanks,
Welcome aboard.
grcauto is offline
post #3 of 5 (permalink) Old 03-17-2019, 01:14 AM
Drive 2009 Azera TG, 2007 Accent MC, 2009 Sonata NF, 2010 Genesis BH,
Quoted: 183 Post(s)
wongpfh is an unknown quantity at this point
Only for the Deluxe(DLX) model, not the Standard(STD).
wongpfh is offline
post #4 of 5 (permalink) Old 03-17-2019, 01:19 AM
Quoted: 183 Post(s)
Diagram attached.
wongpfh is offline
post #5 of 5 (permalink) Old 04-17-2019, 08:16 PM
Dman446 is an unknown quantity at this point
I'm sure you can. The tach works off the signal sent from the crank position sensor. So all you have to do is find a place to tap into the tach signal at the ECU and run a wire to pin into the cluster connector(if that connector pin is empty).
+/- power should already be supplied in the cluster, you just need to signal to run it.
Dman446 is offline
