Looking for advice in buying used 2014 Santa Fe Sport 2.0T - Page 2 - Hyundai Forums : Hyundai Forum
 1Likes
post #11 of 22 (permalink) Old 04-02-2018, 10:23 AM
Adogg9626's Avatar
'13 Hyundai Santa Fe Sport (Copper Top) '13 GMC Terrain (Mama's)
Quoted: 263 Post(s)
Adogg9626 is an unknown quantity at this point
Send a message via AIM to Adogg9626 Send a message via Yahoo to Adogg9626
OP
Looking at the pictures most of this stuff is common on any used car but very common on used sfs. Will address the standouts
The windshield is not original and was replaced. Good news is that the glass brand is good (Pilkington I think) so no worries.
Oil on dipstick looks ok and as commented before, it has been through the engine recall process. Search it out on the forums but long story short all of the 2.0 and 2.4 engines across Hyundai and Kia were subject. Low replacement rate as well...keep calm.
Plastic cladding was probably hit with wax residue at dealer prep. Use tire wet to nullify...not sure how to remove. It will get dirtier with time and it's hard to get back black. As a rural driver I stopped trying a long time ago.
Battery screw is for the hold down so at least u know the battery got replaced. IIRC it's a 14mm screw. Battery will hold itself so not really needed.
Interior dirt will find it's way into the console crevices. Use putty and elbow grease to remove. Also I do not have my door thingy on the driver side either and have no idea how to get one since it's not listed in the parts catalog..
Things to check pre purchase
13 and 14 sfs have known issues with the gas tank and filler neck. Basically there is a valve that will stop the pump when tank is getting full. I had to have my whole tank replaced under warranty and it was like pulling teeth
Hood and hatch struts are another issue and are influenced by cold weather. I had to replace my hatch struts out of my own pocket but they are cheap...50 bucks a pair. Hood is getting weak but its much lighter so not a real issue there but I almost koed myself on the hatch.
Backup camera they are prone to failure. Only warranted to 36k as part of audio system...if past that just budget for a replacement soon. Indicators are a blue screen when going into reverse or distortions in the radio display. Also noticed it has nav. Some have reported issues but usually a reset fixes it. Upgrade for map is pricey too.
Should have heated rear seats. Check functionality before purchase. Modules are not cheap and hard to find at boneyards
Not sure if HID but if so they are auto leveling. Have someone bounce the rear with them on...the projectors should move.
Also most of the grey surfaces are painted and the quality is not good. It will chip or rub...not covered under warranty.
Those are the majors in my opinion. Hope it drives nice and price is good.
DINO2K likes this.
=="The Copper Top"==
3D Maxpider Floor Liners==XenonSupply 4300K HIDS==Compustar SliceJR 2-Way Remote Start==Curt Class III Hitch==Infinity Basslink 200W (jonk in da tronk)
Adogg9626 is offline
post #12 of 22 (permalink) Old 04-03-2018, 05:16 PM
2007 santa fe 3.3l awd 2015 santa fe sport 2.0t awd limited
Quoted: 22 Post(s)
santy007 is an unknown quantity at this point
If possible, buy 2015 SFS instead. Much improved SUV than previous 2 years.
santy007 is offline
post #13 of 22 (permalink) Old 04-03-2018, 09:30 PM
SVTfocusO3's Avatar
13' SantaFe 2.4
Quoted: 173 Post(s)
SVTfocusO3 is an unknown quantity at this point
35000 miles, your buying a used car and want a compression / leak down check already? Please don't let me be your technician! ha. You are very thorough for sure. As stringent as you are, put that bolt to hold the battery! 10/100 Powertrain warranties on these are only transferable to family from 1st owner, buy extended for sure! Not sure about the recalls. Car sounds good though. good luck
J.C.D.
SVTfocusO3 is offline
post #14 of 22 (permalink) Old 04-03-2018, 11:58 PM Thread Starter
2019 Santa Fe 2.0T LTD
Quoted: 28 Post(s)
Adv Vantage is an unknown quantity at this point
Thanks everyone! Your advice is very valuable.
Interestingly, when I run my Sonata VIN through
https://autoservice.hyundaiusa.com/C...Campaign/Index
I get Campaign132 "Engine recall" and TXX3 "Extended engine warranty".
For this Santa Fe I get just Campaign163 "Hood latch recall".
NHTSA gives 3 possible recalls including Campaign132 and Campaign162 "noise inspection"
https://www.nhtsa.gov/vehicle/2014/H...UV/AWD#recalls
Both
https://autoservice.hyundaiusa.com/Campaign132
and
https://autoservice.hyundaiusa.com/Campaign162
tell "Your Vehicle is NOT affected."
Why the dipstick is orange then? Or Hyundai just started installing orange on factory.
Regarding extended warranty, it's definitely desirable, however Nissan dealer sells the car AS-IS with NO additional warranty.
Bottom line, from my experience owning Sonata with 150k miles on the clock and current 1q per 500 miles oil consumption, I am prepared for the most probable cause of engine seizure, however would like to prolong its life as much as possible.
Adv Vantage is offline
post #15 of 22 (permalink) Old 04-04-2018, 02:45 PM
Drives 2018 Hyundai Santa Fe Sport Unlimited 2.0T 2008 Dodge Charger Daytona R/T Rides 2014 Harley
Quoted: 37 Post(s)
Rocket67 is an unknown quantity at this point
All this trouble, why not just get a new one? The price can't be that different.
Rocket67 is offline
post #16 of 22 (permalink) Old 04-04-2018, 03:10 PM
2017 Santa Fe Sport 2.0 Turbo Ultimate AWD
Quoted: 182 Post(s)
mjonis is an unknown quantity at this point
Both
and
You can always get an extended warranty direct from someone else.
I used carchex for my old 2005 Chevy Equinox.
Granted, the pricing may not be to your liking, but you can negotiate.
mjonis is offline
post #17 of 22 (permalink) Old 04-04-2018, 03:16 PM
Quoted: 182 Post(s)
Well a $10,000 price difference is not trivial, IMO.
At least around here.
2014 SFS 2.0T (2nd highest trim level) is about $22,000-23,000 here.
Brand new 2017 SFS 2.0 T (same trim level) was closer to $33,000 here.
At least last year when my roomate checked around. Obviously things will vary a bit. A 2018 now (none of our local places have a 2017 SFS 2.0 T any more) may be a tad more.
But I'd agree that a 2015 would be better (at least in terms of the engine recall), but I've not looked up the reliability of that model year compared to others (although unfortunately the SFS and Sante Fe both get lumped in the aggregate data, so it's hard to tell sometimes).
mjonis is offline
post #18 of 22 (permalink) Old 04-04-2018, 04:29 PM
Adogg9626's Avatar
Quoted: 263 Post(s)
[email protected] tootin on the price...that's why I bought used as well.
One thing in favor of the older years is that the packages were more generous in terms of equipment. For example the 13s and 14s have heated rear seats as part of the popular equipment without nav where in later years it is now part of the Ultimate Package.
Also turbo engines seem to be a bit less powerful on paper in later years. Of course the butt dyno is the real judge, right? Tow ratings didn't change throughout the years (2000lbs for the 2.4 and 3500 for the 2.0t) so torque should still be the same as well.
Curious why reliability data is mixed for the two body styles since the big Santa Fe has the v6 as the sole engine whereas the sport models are only 4cyl...
post #19 of 22 (permalink) Old 04-04-2018, 07:35 PM
Location: Hiding from those who might be looking for me
Quoted: 2556 Post(s)
Both
and
I beleive I covered you Recalls and Warranty Claims in message the other night..
My info is straight off Hyundai Service site that aiale fella looks at when he / she writes service ticket when car show up in service aisle.. NHTSA or others sites is just propaganda,, want truth,, Hyundai Service site using dealer login.
That is why I ask you all for VIN,, so I can give you up to minute proper info as seen on Hyundai Service site
sbr711 is offline
post #20 of 22 (permalink) Old 04-05-2018, 12:49 AM Thread Starter
Quoted: 28 Post(s)
Yup, thanks!
Was just wondering why the dipstick is orange but no engine recall is shown up on "official" sites.
