Intermittent low voltage while running - Page 3 - Hyundai Forums : Hyundai Forum
 1Likes
post #21 of 30 (permalink) Old 03-06-2019, 01:57 PM
Drives 2013 Elantra GT, MT, Style/Tech, 1.8L MPI Nu
Quoted: 214 Post(s)
CyprusCorner is an unknown quantity at this point
I've never heard of an alternator getting up to 19 volts before! How long does it stay up that high? I'm surprised it hasn't burnt out all your light bulbs.
Voltage is controlled by the alternator regulator, which is directed by the ECU as a result of input received from the battery sensor. You've replaced 2 of those 3 parts already. You've somewhat tackled possible grounding issues. Tricky problem you've got for sure! I applaud you on how much troubleshooting you've been able to do on your own.
CyprusCorner is offline
post #22 of 30 (permalink) Old 03-06-2019, 08:04 PM Thread Starter
2012 Santa Fe V6 FWD Limited
Quoted: 5 Post(s)
tylerwal is an unknown quantity at this point
Originally Posted by MaddMaverick View Post
Look on your negative battery terminal. Is there a little box with wires plugged into it? Mine is an 11 w/2.4l and has it.
Yes, the dealership replaced that sensor when I took it to them. I assumed it was that sensor as well but it didn't solve the issue.
tylerwal is offline
post #23 of 30 (permalink) Old 03-06-2019, 08:10 PM Thread Starter
Quoted: 5 Post(s)
It's been at high voltages twice, both times I was on the interstate (at rush hour) so I didn't feel comfortable pulling over immediately. First time it was high for maybe 7 minutes, second time maybe 2 minutes.
I don't know the exact mechanics of the voltage/alternator regulator that you mention, but I wouldn't think it would output 18-20 volts even if the ECU was calling for it. Which makes me wonder if it's a on/off switch (from the ECU) or is the ECU passing an exact voltage that should be attained. I don't know - and it's honestly hard to find information about the smart charging system.
I'm hoping it's not a bad ECU...
tylerwal is offline
post #24 of 30 (permalink) Old 03-07-2019, 11:54 AM
Quoted: 214 Post(s)
An alternator can output quite a lot of power. It's not really voltage limited per say, as an alternator is a current generating device. it will generate current based on its duty cycle and RPM's to maintain a a voltage managed by the ECU/voltage regulator. Next time it happens, can you try turning on your rear defrosters? Those will use a lot of current, and should help bring your voltage down. I don't think it will help you diagnose the problem, but it will help save your other electronics!
Does anyone who knows more about cars know what other part of the car would measure the voltage of the vehicle? I presumed the voltage regulator both regulated and measured voltage, but I could be wrong!
post #25 of 30 (permalink) Old 03-25-2019, 07:18 PM Thread Starter
Quoted: 5 Post(s)
I wanted to give an update to this in case anyone runs into the same problem.
So I had the alternator replaced ~2-3 weeks ago. A couple of days later, I used my remote start to start the car (this is the OEM Hyundai Remote Start) - it didn't start so I knew something was up again. Now this behavior had been seen before along with the voltage issues that caused me to create this thread.
I had always written this off as the remote start using voltage to determine when the car had started or some fail safe, but the voltage on the battery was good at this point. Then I started to think about this post:
Originally Posted by AUTOSPARK View Post
High resistance/open circuit on the alternator output.
What if the Remote Starter was the open circuit? The Remote Starter being a cause didn't even register as a cause for me but the more I thought about it, the timings of when the remote start didn't work and the voltage issues always seemed to match up.
After disconnecting/reconnecting the battery (the reset), I've been mainly just avoiding the remote start and the car has been working perfectly. I still want to cause the issue to happen again so I can find out what exactly on the remote start is to blame (the larger module or the DNA card/thingy) but the weather is getting better so I've been fine without it.
Another thing I noticed when the last issue came about (post-alternator), the voltage was dropping very slowly - like the new alternator had more power to overcome the open circuit.
If I find out what exactly is the culprit, I'll update this thread again but I'm almost positive it was something in the remote start circuitry. Thanks everyone!
tylerwal is offline
post #26 of 30 (permalink) Old 04-04-2019, 12:01 AM
Santa fe
Quoted: 4 Post(s)
lafetoo is an unknown quantity at this point
How reliable is your USB volt meter? Is it Made in China from ebay or something?
lafetoo is offline
post #27 of 30 (permalink) Old 04-04-2019, 08:01 AM
07 Santa fe ltd 07 Dodge 1500 std. cab 8 ft bed.
Quoted: 74 Post(s)
Mycrossover is an unknown quantity at this point
Huundai battery cable clamps are really poor and have trouble tightening enough to make good contact on a lot of batteries. I know this is very basic. but make sure they are tight.The nut gets tight before the ckamp is tight enough. Wiggle the clamp by hand to check I have the auto store lead caps on my posts to get a tight fit. When you read high voltage it made me think the alternator was running without a battery across the output, as in bad connection. That and the bad ground contacts to the car body are well known priblems. It looks like the dealer took care of the grounding problem.
Sent from my SM-G900V using Tapatalk
Mycrossover is offline
post #28 of 30 (permalink) Old 04-04-2019, 08:26 AM
2007 Santa Fe Ltd 3.3L AWD new, now 300,000km-190,000 mi. 2010 KIA Soul 4U new, now 42,000km-26,000m
Quoted: 20 Post(s)
M in Toronto is an unknown quantity at this point
North American Battery Posts are Smaller
After I replaced my battery, I too found that I could not get a tight clamp on the positive battery post.
The batteries available here have a slightly smaller post diameter than the original Korean posts, so you can't tighten the clamp enough.
I removed the nut from the positive clamp, and added 2 small washers under the nut.
That provided enough additional force to tighten the clamp to the post and make the connection solid.
Worth a try.
M in Toronto is offline
post #29 of 30 (permalink) Old 04-04-2019, 08:55 AM
DSHornet's Avatar
Location: Surburbs of Birmingham, Alabama, Southeastern USA
Me - 2012 SF Limited 3.5L AWD, ~64K miles; The Bride - 2007 Tucson Limited 2.7L FWD, ~89K miles.
Quoted: 152 Post(s)
DSHornet is an unknown quantity at this point
I have taken a large socket, put it on top of the clamps, and lightly tapped the clamps down on the battery posts before tightening the hardware. Make sure there isn't stray material at the top of the opening on the clamps that might make it harder to get them fully seated on the posts.
PLEASE HELP US HELP YOU! Click on your screen name, go to your personal page, and fill in all the fields marked by a yellow pencil icon. The information you enter will show up in the left margin.
__________________________________________________ __
Grandpap Don, y'all, as we say in Dixie
DSHornet is offline
post #30 of 30 (permalink) Old 04-23-2019, 09:05 PM Thread Starter
Quoted: 5 Post(s)
I assume the battery warning light is remaining off which suggests the alternator is actually generating voltage. That voltage just isn't getting to the battery. When the fault is present measure the voltage right at the alternator output and compare the voltage there to what's displayed on your USB charger. If the voltage at the alternator is significantly higher than that displayed on the USB charger that confirms there is a problem somewhere in the alternator output circuit.
It was from amazon so fairly cheap but the low voltage was verified with a external battery charger, not to mention the car dying because of insufficient power. The USB meter may be inaccurate but it's just backing up feedback that I already know existed.
I stopped using the remote starter and the issue is completely gone. From 1-2 times per week (towards the end) to a completely fixed car.
tylerwal is offline
