Error code C1627 (SANTA FE 2011) - Hyundai Forums : Hyundai Forum
post #1 of 6 (permalink) Old 09-22-2012, 04:18 AM Thread Starter
santa fe 2011
mammous is an unknown quantity at this point
Dear All
I have an issue in my car (Santa fe 2011) and it occurred since it was new (ODO 3000 KM , ESP light is on and the 4WD Blinking) . the agency could not resolve the issue. and my car up to now been in and out from the workshop for more than 6 times . and more the error code ( C1627 ) that appears in the GDS(Global Diagnostic System) does not exist in the system (trobleshoot manual) .
any body experianced the same issue
please provide me with the contact to Hyundai HQ to complain. I am suffering sice two years now .
mammous is offline
post #2 of 6 (permalink) Old 09-22-2012, 02:40 PM
canderson's Avatar
2008 Limited
Quoted: 563 Post(s)
More specifically, the C1627 problem is a CAN comm error between the HECU (Hydraulic and Electronic Control Unit) for the brakes and the the ECU on an AWD vehicle. Either one of these units, or the wiring between them, is faulty.
Bad news ... when this happens, you have no ABS or ESC, and that's what is lighting the dash lights. They MUST fix this for you.
canderson is offline
post #3 of 6 (permalink) Old 09-22-2012, 04:09 PM
2001 Atos Prime's Avatar
i20 / 86 hp 2013my SsangYong Rodius AWD also collectible cars & motorcoach
2001 Atos Prime is an unknown quantity at this point
Hi,
DTC C1627 is a manufacturer specific code for the chassis, this according to the first letter :
  • B = Body,
  • C = Chassis,
  • P = Powertrain and
  • U = Network.
The 6 stands for some computer output circuit or missing/wrong signal similar to what Canderson wrote about.
You wrote this C1627 doesn't exist on Hyundai's GDS... it could be worth checking on the carbon copy car of Hyundai's subsidiary KIA, i.e. the Kia Sorento :
  • With this DTC C1627, a technical service bulletin (KIA TRA 034) recommends replacing the transfer case motor.
It could be wise to have a special look on this area, connectors and harness going to the transfer case.
BTW, as far as I know directly from Continental Teves and BOSCH, if the ESP light is on or blinking, there is no more ESP, no more ESC or other optional functions (Overroll protection, emergency braking, trailer programm a.s.o.).
The ABS which is the basic function, should still be working !
It's only if the ABS light is ON, alone or with the ESP light, that you only have the brakes working without any electronic helper... like 40 years ago
Anyway, your dealer have to solve and fix this issue a.s.a.p. it's a safety one !
Hope this could help you little bit further on.
Regards
Roland
i20 - 1.25 l - 2013 my - 86 HP - full options
2001 Atos Prime is offline
post #4 of 6 (permalink) Old 09-22-2012, 08:30 PM
canderson's Avatar
2008 Limited
Quoted: 563 Post(s)
Actually, the detail I provided came directly from Hyundai, and applies to the CM Santa Fe owned by the OP.
* With this DTC C1627, a technical service bulletin (KIA TRA 034) recommends replacing the transfer case motor. It could be wise to have a special look on this area, connectors and harness going to the transfer case.
Not a good to try to cross Kia DTCs to a Hyundai. These manufacturer specific codes don't all have the same meaning across these vehicles, similar though some of the components may be.
post #5 of 6 (permalink) Old 09-23-2012, 04:19 PM Thread Starter
santa fe 2011
Thank you all for the information you provided . I am going to the dealer and show them the comments since they have no information about the case.
I really appreciate it
Mutasem
mammous is offline
post #6 of 6 (permalink) Old 02-14-2016, 01:24 PM
toastdoom is an unknown quantity at this point
Mutasem
Hi! Did you fix that error C1627?
toastdoom is offline
