Oil Change Question 1.6T - Hyundai Forums : Hyundai Forum
 1Likes
post #1 of 15 (permalink) Old 03-18-2019, 11:01 AM Thread Starter
Kozman's Avatar
Quoted: 6 Post(s)
Kozman is an unknown quantity at this point
Hi all. I'm about to get my 1st oil change in my 16 1.6T Sport. Should I go synthetic??
Kozman is offline
post #2 of 15 (permalink) Old 03-18-2019, 11:06 AM
solman98's Avatar
Drives 2014 Elantra Sport 2.0 6M 2016 Tucson Sport 1.6T
Quoted: 1000 Post(s)
solman98 is an unknown quantity at this point
You will get many answers. I started using full synthetic on the first oil change.
2014 Elantra Sport 2.0 6M Shimmering Silver. LED interior lights, cargo mat and net. 35/20% tint. LED tag and back up lights. LED fogs. LED headlights, homelink, 225/45R17 91V PureContacts.
2016 Tucson Sport 1.6T 7A Caribbean Blue. Hitch, tint, mudguards, homelink, cargo cover, LED back up and tag lights, power pass seat lumbar installed, LED fogs, aftermarket crossbars for the roof. LED direct fit headlights.
solman98 is online now
post #3 of 15 (permalink) Old 03-18-2019, 11:32 AM
Drives 2013 Elantra GT, MT, Style/Tech, 1.8L MPI Nu
Quoted: 211 Post(s)
CyprusCorner is an unknown quantity at this point
You're only required to use what meets the standards listed out in your owners manual, and doing so will make your car last a long time. That's likely a synthetic blend or a full synthetic based on the fact that you're asking the question here. If you want your engine components to last forever, worry a little less about the exact type of oil your using and simply:
1) don't drive the car hard until 2-3 minutes after the t-stat gauge has showed that it's warmed up.
2) do not turn off your engine immediately after spooling up your turbo, wait at least 30 seconds.
CyprusCorner is offline
post #4 of 15 (permalink) Old 03-18-2019, 12:39 PM
wallyjay's Avatar
Drives 2016 Tuscon Limited/Ultimate AWD 2017 SantaFe Sport 2.4 FWD
Quoted: 181 Post(s)
wallyjay is an unknown quantity at this point
With direct injection and turbo I recommend synthetic. It can handle hot turbos and DI byproducts better than conventional oil. And on sale it is about the same price as regular dino. Also most synthetic products are now formulated to deal with the potential low speed pre ignition problems that could occur under certain conditions in these engines.
wallyjay is offline
post #5 of 15 (permalink) Old 03-18-2019, 01:07 PM
Tucson Tony's Avatar
Drives 2016 Hyundai Tucson LTD, Ultimate AWD, 2013 Mini Cooper S R56 Rides 2013 Triumph Tiger Ex
Quoted: 341 Post(s)
Tucson Tony is an unknown quantity at this point
I've heard that once you have enough miles to have properly broken in your engine, (seated the rings etc). Then after, it's ok to go with synthetic oils.
Tucson Tony is offline
post #6 of 15 (permalink) Old 03-18-2019, 02:15 PM
2011 Sonata 2.4GDI
Quoted: 767 Post(s)
deadrx7conv is an unknown quantity at this point
Various engines come factory filled with synthetic. Engines will break in on synthetic.
Since its a turbo, and a Hyundai, my recommendation is a 5w40.
Motto for advice giving on a forum: You can lead a horse to water, but you can't make it drink.
Sad country is where most neutered men can't change a tire or use a tire PSI gauge, can't check their engine oil or even pop their hood.
TrollBots are everywhere. Paid trolls are easy to spot in the 'off topic' forums everywhere.
Those who say it cannot be done, should not interrupt the person doing it.
deadrx7conv is offline
post #7 of 15 (permalink) Old 03-21-2019, 05:36 AM
Quoted: 78 Post(s)
HSpeed is an unknown quantity at this point
Hyundai manual recommends using ACEA A5 or above IF ACEA A5 or above is not available, use ACEA A3 or above;
Pennzoil Ultra Platinum 5W-30
ACEA A1/B1-10, , A1/B1-12 , A5/B5-10, , A5/B5-12
https://www.pennzoil.com/en_us/produ...inum-5W-30.pdf
Mobil 1 0W-40
ACEA A3/B3, A3/B4
https://www.mobil.com/English-AU/Pas...XXMobil-1-0W40
Have been using Pennzoil Ultra Platinum 5W-30 however, may use Mobil 1 0W-40 upcomming oil change. Believe using 0W-40 may cut down on gas mileage however, better at keeping turbo cooler.
HSpeed is offline
post #8 of 15 (permalink) Old 04-11-2019, 09:54 AM
Quoted: 78 Post(s)
Just a follow up if any member has used Mobil 1 0W-40 oil instead of 5W-30?
HSpeed is offline
post #9 of 15 (permalink) Old 04-11-2019, 10:19 AM
Red Raspberry's Avatar
Quoted: 1633 Post(s)
I have used M1 5w30, 0w30 and 0w40 in my Gen Coupe. Fuel dilution is an issue with my engine though so I go with the 0w40 all the time now. Camshafts are clean as can be at 97k miles.
OvrLord likes this.
Borrow money from pessimists -- they don't expect it back.
Red Raspberry is offline
post #10 of 15 (permalink) Old 04-11-2019, 10:59 AM
Quoted: 78 Post(s)
Red Raspberry, thanks for the reply and posting the photo, much appreciated!
Were any noticeable changes observed when you switched from the 5w30 to 0w40 (slight decrease in MPG etc.?
I understand engine you have is the 2.0 GDI turbo (2010 Genesis Coupe), so if the recommended oil requirements / specs are similar to the 2016 1.6 GDI turbo engine.
HSpeed is offline
