Eyebrow Lights - Hyundai Forums : Hyundai Forum
 1Likes
post #1 of 13 (permalink) Old 09-19-2018, 12:34 PM Thread Starter
Ewoklovefest's Avatar
Drives 2018 Tucson SE
Quoted: 2 Post(s)
Ewoklovefest is an unknown quantity at this point
Question Eyebrow Lights
I purchased a NA 2018 Tucson SE with Standard Eq. Was wondering if the eyebrow is actually a light on my model or just the white screen with nothing inside. Owner's manual isn't really all that helpful. I see plenty of models where the eyebrow is actually a light and I kind of like the way it looks. I would like to either upgrade the lights themselves to get the eyebrow light or possibly retro fit. Just have no clue if the proper wiring is there or not. Sorry if there's a previous thread regarding the same question.
Ewoklovefest is offline
post #2 of 13 (permalink) Old 09-19-2018, 12:48 PM
mmahamm's Avatar
2017 Elantra Limited; 2016 Tucson SE AWD (Daughter's)
Quoted: 200 Post(s)
mmahamm
Dumb question: Have you tried turning on the lights in all different modes, and then stepping out of the vehicle to observe which lights are on (or doing this in front of a glass storefront or mirror)? Seems like you would know pretty quickly that way if the eyebrows are actually lit. On my daughter's 2016 SE, the eyebrows are indeed lights.
Some have complained here that the LED daytime running lights turn off when the headlights are on, and that when they do, the eyebrow lights turn on.
Michael
Northern Virginia, U. S.
2017 Hyunda Elantra Limited, Mineral Beige, purchased Sept, 2017.
mmahamm is offline
post #3 of 13 (permalink) Old 09-19-2018, 01:06 PM
solman98's Avatar
Drives 2014 Elantra Sport 2.0 6M 2016 Tucson Sport 1.6T
Quoted: 1033 Post(s)
solman98 is an unknown quantity at this point
Agreed, turn on your headlights. The eyebrow light acts like the parking light. If the amber running lights turn on, your brows won't.
2014 Elantra Sport 2.0 6M Shimmering Silver. LED interior lights, cargo mat and net. 35/20% tint. LED tag and back up lights. LED fogs. LED headlights, homelink, 225/45R17 91V PureContacts.
2016 Tucson Sport 1.6T 7A Caribbean Blue. Hitch, tint, mudguards, homelink, cargo cover, LED back up and tag lights, power pass seat lumbar installed, LED fogs, aftermarket crossbars for the roof. LED direct fit headlights.
solman98 is offline
post #4 of 13 (permalink) Old 09-19-2018, 01:26 PM Thread Starter
Quoted: 2 Post(s)
Yes. Its not a question if they work or not. Sorry for being unclear. What I wanted to know is if the headlamp assembly has a physical bulb that I could just wire up to come on or if its empty space. I am assuming it is empty space but with out cracking open the assembly I wont know for sure unless someone here has already cracked thier's open.
The amber lights act as the parking lights on my model
post #5 of 13 (permalink) Old 09-19-2018, 01:55 PM Thread Starter
Quoted: 2 Post(s)
Think I figured it out. Looks from pictures online there is a bulb holder that can be removed. ON mine however there is a blank slot where the bulb holder would be inserted(Its not even drilled out). So unless I modify the existing headlamp holder and wiring I am assuming I would have to go either the aftermarket route or find OEM style upgrades.
post #6 of 13 (permalink) Old 09-19-2018, 05:43 PM
His: 2017 Tucson SE Plus Hers: 2017 Tucson SE
Quoted: 326 Post(s)
tenergy is an unknown quantity at this point
Pretty sure those are built in LED strips, so you wouldn't have a bulb anyways.
Traded the Elantra... starting over!
tenergy is offline
post #7 of 13 (permalink) Old 09-19-2018, 05:48 PM Thread Starter
Quoted: 2 Post(s)
I believe you are right it looks like the SE comes without the LED Accents which are standard on every other model. I wonder if they can be switched out for the upgraded SEL headlights with out any extra wiring....I'll see what else I can find out online. I have no problem with the mechanical aspect of installing new lights, but i don't trust my electrical skills (if its even possible electronically). Thanks all
post #8 of 13 (permalink) Old 09-19-2018, 07:02 PM
INASTY's Avatar
Drives 2015 Hyundai Tucson Active X
Quoted: 19 Post(s)
INASTY is an unknown quantity at this point
I had a specialist take a look at mine. Apparently the "eyebrow" light is lit with a small LED at the top part. It just reflects through the entire panel. You can't fit LED strips underneath as it sits flush on the headlight housing. I ended up having the panel painted black and a new LED tube installed instead. Here is a day/night pic as an idea
Dredd likes this.
INASTY is offline
post #9 of 13 (permalink) Old 09-21-2018, 06:57 PM
MIKESPORT's Avatar
Hyundai Tucson Limited 2016
Quoted: 3 Post(s)
MIKESPORT is an unknown quantity at this point
I guess you crack open the housing of the lights to install the mods angel eyes and turn signal ..Niceeeee
MIKESPORT is offline
post #10 of 13 (permalink) Old 09-24-2018, 11:42 PM
Drives 2018 Tucson Limited 1.6t AWD with Ultimate package.
Quoted: 9 Post(s)
Mall1953 is an unknown quantity at this point
Mmahamm how can you call another member dumb? It was a question. That's what the forum is for. Coming from a senior member no less.
Mall1953 is offline
