Blackout ideas? - Hyundai Forums : Hyundai Forum
 7Likes
post #1 of 15 (permalink) Old 08-18-2018, 11:56 PM Thread Starter
Quoted: 23 Post(s)
int23 is an unknown quantity at this point
Blackout ideas?
I have an 18 Black Tucson Limited which I've pretty much fully murdered out.
The only pieces I have to deal with are the door handles (no clue how to go black on those) and the grey trim at the bottom of the doors/back.
Any thoughts on how I can black these out? I'm dipping the grille/badges in the morning but I'm doubting dip will adhere/cure properly on the side areas.
Thoughts?
int23 is offline
post #2 of 15 (permalink) Old 08-19-2018, 12:45 AM
TooGqForYou's Avatar
2017 Hyundai Tucson Night Edition 1.6T 2016 Hyundai Veloster Turbo DCT 2011 John Cooper Works Mini
Quoted: 71 Post(s)
TooGqForYou is an unknown quantity at this point
I actually bought oem black door handles for my tucson to piano/accent my Tucson Night edition Dazzling white.
Do not do a wrap, do not do plasti-dip, due to the heavy use on gripping and pulling the door handle. as for the grey trim i would grt that professionally painted.
2017 Tucson Night Edition Dazzling White 7-Speed DCT 1.6T
Res-Delete Pipe| PUP 5W-30 | Breather & PCV Venting-to-Atmosphere
2016 Veloster Turbo Elite White 7-Speed DCT Tech Package 1.6T
Turbosocks 3.5' SRI | 3' Straight Pipe Catback Exhaust | Res-Delete Pipe | Motors Line Front Strut Bar | XE 3TBS | XE ORCP | XE XWEK | XE XPVS | 60mm TB | TB Bypass | HKS M45XL Plugs | MAP Sensor 39300-84400 | PUP 5W-30 | Breather & PCV Venting-to-Atmosphere
2011 John Cooper Works Mini Cooper S
Stock
TooGqForYou is offline
post #3 of 15 (permalink) Old 08-19-2018, 05:25 AM
Tucson Tony's Avatar
Drives 2016 Hyundai Tucson LTD, Ultimate AWD, 2013 Mini Cooper S R56 Rides 2013 Triumph Tiger Ex
Quoted: 342 Post(s)
Tucson Tony is an unknown quantity at this point
I've always wanted to change my chrome door handles to blue to match the color. Only issue is that the Limited's chrome handles have the sensors and LED's in the front doors and the color matched one's don't.
tucsonstackz likes this.
Tucson Tony is offline
post #4 of 15 (permalink) Old 08-19-2018, 07:58 AM
hall0069's Avatar
Quoted: 7 Post(s)
hall0069 is an unknown quantity at this point
Actually I have he SE Plus in Caribbean Blue and it does have the color matched door handles with the sensors and LED accent lights. So the are available
2017 SE PLUS
Caribbean Blue
Diode Dynamics HID lows
LED Fogs
Diode Dynamics full LED interior Bulbs
hall0069 is offline
post #5 of 15 (permalink) Old 08-19-2018, 09:26 AM Thread Starter
Quoted: 23 Post(s)
Any idea where I can get a set for my Tucson?
int23 is offline
post #6 of 15 (permalink) Old 08-19-2018, 09:27 AM Thread Starter
Quoted: 23 Post(s)
Oh I'll never wrap/dip a door a handle. Been there, done that. Can you tell me where you you found the OEM? Also note I have the limited with the led sensors in them.
As for the grey trim I'll likely have someone I know spray it for me at their shop.
Thanks in advance your help!
int23 is offline
post #7 of 15 (permalink) Old 08-19-2018, 05:42 PM
INASTY's Avatar
Drives 2015 Hyundai Tucson Active X
Quoted: 19 Post(s)
INASTY is an unknown quantity at this point
Thoughts?
I would definitely recommend getting the plastic trim professionally painted. I picked up my car last week after having this done and looks so much better. I do have to take it back tomorrow though, as they forgot to do the fog light surrounds.
Once that is done, I will be getting the foggies and DRL's tinted to match the headlights, but can't get my tail lights tinted until they have been customised first.
Jason14227 and Dreedo like this.
INASTY is offline
post #8 of 15 (permalink) Old 08-20-2018, 01:15 PM
Quoted: 33 Post(s)
Rem234 is an unknown quantity at this point
I used paint for plastic trim on the grey panels on the front, rear, and sides. I believe I purchased it from Summit Racing. I think it is made by VHT? It has held up really well for two years of driving, hitting bugs, rocks, etc.
I recently painted my chrome door handles. I scuffed them with scotch brite and sprayed them with adhesion promoter. Then a couple coats of black followed by a few coats of clear. Then wet sand/ polish. I was able to remove all but the drivers door handle to do this which makes it a fairly easy job.
2017 Tucson Limited - Tint 20%-35% - Ebay Korea Grill - Custom K&N Filter Warm Air Intake - Torq Tube - Flowmaster 80 Series Exhaust w/Dual 4" Stainless Tips - Oil Catch Can - LED LP Bubs - Painted rear reflectors, Roof rails, Front lower and Side lower trim - Husky Floor liners.
Rem234 is offline
post #9 of 15 (permalink) Old 09-04-2018, 08:29 AM
Quoted: 4 Post(s)
bcrosby51 is an unknown quantity at this point
Headlights
Did you just add Halos to your headlights? Did you do it yourself?
bcrosby51 is offline
post #10 of 15 (permalink) Old 09-04-2018, 05:54 PM
INASTY's Avatar
Quoted: 19 Post(s)
I have halos, HID upgrade, new eyebrow and LED sequential turn signals. I had the glass piece that covers the original eyebrow blacked out too. I was not confident doing it myself and had them custom made. Here is a better shot of them
INASTY is offline
