Completed pics of dual exhaust - Page 2 - Hyundai Forums : Hyundai Forum
 21Likes
post #11 of 21 (permalink) Old 07-09-2017, 11:07 AM
2017 Tucson SE, 2.0 GDI
Quoted: 53 Post(s)
ZombieHunter is an unknown quantity at this point
Originally Posted by solman98 View Post
Well, this is all true, but you stated you have a gutted cat. Which, not only carries a $10K fine, but the Magnuson Moss Act will not help you one bit......lol
Basically, if you have any emission related issues, they can very easily deny any claim.
DREAM CRUSHER
ZombieHunter is offline
post #12 of 21 (permalink) Old 06-13-2018, 06:20 PM
tucsonstackz's Avatar
2016 Tucson Ultimate 1.6T (Carribean Blue)
Quoted: 15 Post(s)
tucsonstackz is an unknown quantity at this point
Originally Posted by Rem234 View Post
Thanks!
On the LH side of the bumper I had to make an opening to match the RH side. The style line is there, so gauging off that I cut away all but about 1.5" of the plastic. Then I used a heat gun to heat up the remaining plastic and bend it up to match the stock side. It worked pretty well. The plastic did tear a little on the inside radius where I tried to bend it really tight. Once I was done I painted the whole thing black with some plastic bumper paint I bought from Summit Racing.
The grill I ordered off ebay. To install you have to remove the entire front bumper, but that is much easier than it sounds. (Chrome, Black Front Radiator Grill For Hyundai All New Tucson TL 2016~2017+ )
No modifications to your car can "void the warranty" that is an old wives tale. Thanks to the Magnoson Moss Act (I think that is the name, I don't remember exactly?) the manufacturer can only not cover something if they can prove that your modification was the direct cause of the damage. This is the equivalent of an "axle back" or "cat back" exhaust system so there is no possible way it could be proven to damage anything. And I still have the stock muffler and can bolt it back on in five minutes so no one would ever know i changed anything if I needed to.
you have one of the better looking Tucsons i've ever seen, props
im gonna have to look into the dual exhaust and that front grill
looks very clean and sleek
tucsonstackz is offline
post #13 of 21 (permalink) Old 06-19-2018, 07:18 AM
INASTY's Avatar
Drives 2015 Hyundai Tucson Active X
Quoted: 19 Post(s)
INASTY is an unknown quantity at this point
I finally got my new exhaust system installed. The sound with the Flowmaster muffler is just about right. It does resonate a little around 75-80 mph other than that the sound is deep and mellow and actually not that loud considering that i have the second cat gutted as well.
So I have just ordered a new lower rear bumper and the rear skid plate to allow the install of a dual exhaust. Mine does not have a rear skid plate (as per pic) and I need it before I can get my body kit installed.
Did you find it hard bending up the plastic after you cut it to match the side ?
INASTY is offline
post #14 of 21 (permalink) Old 01-17-2019, 09:27 PM
Saso's Avatar
Saso is an unknown quantity at this point
Hi everyone.You will see on the picture I have a Tucson Active X 2017 like a black one and I want to look like a blue one the 30th anniversary at the back,from one exhaust to change to two double exhaust.So can any one explain if with the change of lower bumper and the diffuser the exhaust going to fit perfectly or I have to do some changes in the brackets or so because how I am reading the 30th anniversary model is based on Active X.So if anyone know anything I appreciate.
Saso is offline
post #15 of 21 (permalink) Old 01-30-2019, 10:31 PM
INASTY's Avatar
Quoted: 19 Post(s)
Hi CHamp,
I have an Active X also. The lower rear bumper comes off as one piece and the brackets are exactly the same. Just don't break any of the little plugs that hold it to the rear bumper.
I upgraded my rear lower bumper/skid plate to the one on the Highlander (comes as 2 separate pieces) so I could fit a quad exhaust and rear skirt.
Here are before and after pics.
TucsonNotTuscon and Dredd like this.
INASTY is offline
post #16 of 21 (permalink) Old 01-31-2019, 09:03 AM
SuperHybrid101's Avatar
Drives 2018 Tucson Value Edition 1.6T with Night package
Quoted: 63 Post(s)
SuperHybrid101 is an unknown quantity at this point
I tried reach you out by inbox and you never respond since. . . to answer question relate with your exhausted system on your Night.
Originally Posted by BeerOnTap View Post
Correct me if I am wrong, but on my 2017 Tucson night, I have the single exhaust on the right side. It has two outlets, sure, but it's still single exhaust. So the left side sort of looks like it wants to have a cutout, but it is not the same as the right side. So my question is, how did you get that left side to look so symmetrical?
Also, how did you do the grill? And how did you paint the Hyundai logo on the back?
And finally, will your exhaust void your warranty?
Thank you in advance. Your Tucson looks epic.
Drives 2018 Hyundai Tucson Value w/ Night package
It's not about the how much power under the hood, it's about how you drive behind the wheels that's capable of.
SuperHybrid101 is offline
post #17 of 21 (permalink) Old 01-31-2019, 01:15 PM
grcauto's Avatar
Quoted: 1043 Post(s)
Originally Posted by twospirits View Post
Looks really good. I wish all Tucsons came with dual exhaust, that one exhaust setup on current Tucsons sets off my OCD. lol
Not true duel exhaust. Cosmetic only.
grcauto is offline
post #18 of 21 (permalink) Old 02-04-2019, 06:57 PM
Casaoui2019 is an unknown quantity at this point
Looks really good. I too wish all Tucsons came with dual exhaust!
Casaoui2019 is offline
post #19 of 21 (permalink) Old 02-11-2019, 12:15 AM
Abq 2018 Tucson is an unknown quantity at this point
Where did you get the muffler with the duel output
Abq 2018 Tucson is offline
post #20 of 21 (permalink) Old 02-11-2019, 12:10 PM Thread Starter
Quoted: 33 Post(s)
Rem234 is an unknown quantity at this point
I used a Flowmaster 80 series cross flow muffler. It has a single inlet and two outlets (one on each side). It is much louder than stock though.
2017 Tucson Limited - Tint 20%-35% - Ebay Korea Grill - Custom K&N Filter Warm Air Intake - Torq Tube - Flowmaster 80 Series Exhaust w/Dual 4" Stainless Tips - Oil Catch Can - LED LP Bubs - Painted rear reflectors, Roof rails, Front lower and Side lower trim - Husky Floor liners.
Rem234 is offline
