dears, I just bought a Sonata SE Limited 2014 equipped with BlueLink Multimedia 8" screen, I tried to change the executing MAPs installed in the SD card with no success it alway's showing me an MSG "Please check that the SD card is inserted. Some features will not work if the data does not exist or if a DIFFERENT VERSION IS BEING USED".
am sure that the reason of showing this cause of changing the version!:crying2:
Where did you get your version that you are installing?
The only authorized seller is MnSoft or your dealer. The updates are locked to your VIN and radio serial # so if you are attempting to upgrade the version which was not authorized for your vehicle it won't work.
I start to have the same issue. I own Sonata Se 2014 with navigation. Never had issue before. Couple months ago I decided to update maps to 10.5 version. After that I started to have issues. First navigation most of the time loads maps on screen instead main screen menu or where i left it. (before usually showed main screen or where i left it before turning off the screen).no big deal but annoying. I got the same message on my screen 2 or 3 times. I just remove the sd card put it back and at this point system will restart then it should work. If I will get this message again I will contact to mapnsoft customer service.
410K members
