Any ideas on removing this screw? - Hyundai Forums : Hyundai Forum
 14Likes
post #1 of 21 (permalink) Old 04-20-2017, 05:23 PM Thread Starter
Aye-Bird's Avatar
Drives 2011 YF Sonata GLS
Quoted: 25 Post(s)
Aye-Bird is an unknown quantity at this point
Old's Cool tried to help me out with removing this pesky bolt (thank you for the help!) but to no avail... This screw is for the compartment in the fender liner to replace the turn signal bulb. My assumption is that someone at the dealership that I used to take the car to somehow managed to deform the teeth to where instead of a phillips, it's just a circle (see picture attached.) I tried pulling/twisting it off but, no dice. Plus, pulling it felt like I was pulling the fender liner along with the screw. I would like to keep the screw intact to reuse but, if worse comes to worse, I could buy another one. Any ideas/suggestions?
@WhateverAyeBird
Current:
2011 YF Sonata/Silver (Daily Driven)
2016 Tuscon/White (Family Car)
Previous:
2004 Santa Fe LX/Maroon (2006-2012)
Aye-Bird is offline
post #2 of 21 (permalink) Old 04-20-2017, 06:15 PM
Old's Cool's Avatar
2005 Scion tC; 1988 Toyota Supra; 2009 Hyundai Accent Wheezer 1.6; 96 Subaru Outback (soon)
Quoted: 2921 Post(s)
Old's Cool is an unknown quantity at this point
OK then try this. You might actually have to buy something!
Next thing I would do would be to get something like this
Hook it under either the screw head or the 'bulge' below it and try turning it with a straight screwdriver.
If you were out here I'd get the damm thing out!
Can you get a better picture so I can see how much room you have?
One of these might work better
Wedge it under the clip, right up against the panel so you can try to get it on the threads and then turn it out.
Failing that, you may just have to drill it out...
Do you know any satisfying profanity?!
There are two ways to slide easily through life: believe everything, or doubt everything. Both ways save us from thinking-Fred C. Dobbs
<<click...
2009 Accent Hatch
I find it works well enough to get me from one planet to another.
Old's Cool is offline
post #3 of 21 (permalink) Old 04-20-2017, 06:18 PM
2011 Sonata SE
Quoted: 19 Post(s)
Mr. P is an unknown quantity at this point
It's just a plastic screw rivet which are pretty cheap to get anywhere. Just take a pair of straight cut pliers, razor or something and cut the head off and put a new one in.
Tiger-Heli likes this.
Mr. P is offline
post #4 of 21 (permalink) Old 04-20-2017, 06:26 PM
2011 Sonata GLS MT (gone)
Quoted: 26 Post(s)
Fox Mulder is an unknown quantity at this point
That's not really a screw, it's a pop-out fastener. If you treat it like a screw and apply pressure while trying to unscrew it with a screwdriver, the result is what you have now.
The proper way to release it is by turning it GENTLY with a small screwdriver without applying any pressure. The center part will then pop out and you can remove the fastener. This may still be possible if you have a small flat-blade screwdriver that fits snugly in the now-rounded head and can grab it so it turns. These are generally considered single-use fasteners, for obvious reasons. Most parts stores have these.
Fox Mulder is offline
post #5 of 21 (permalink) Old 04-20-2017, 07:42 PM
Old's Cool's Avatar
Indeed...applying pressure defeats the purpose.
But these things are dastardly. They hold in my grille and even putting no pressure on the screw they don't want to back out. Luckily mine are where I can get a fingernail or a tool under them and put enough pressure to back the screw out. I haven't had to snap one off yet...yet...
<<click...
2009 Accent Hatch
post #6 of 21 (permalink) Old 04-20-2017, 09:20 PM
Airforce1's Avatar
'98 Taurus-Sold '08 GMC '08 GX460 '12 Hayabusa-Sold '14 Kawasaki ZX14R-Sold '17 Sonata Limited w/
Quoted: 1265 Post(s)
Airforce1 is an unknown quantity at this point
Cut it off with a razor blade or take a grinder to the head.
He has the most who is most content with the least"
20% Solar Guard Tint excluding front windows
Dash Cam & Blackvue Power Magic Pro Timer
De-badged
Fumoto Valve
Precision Leds- 8000K License plat
Ultra Racing Front Strut Bar
UPR catch can
Airforce1 is offline
post #7 of 21 (permalink) Old 04-20-2017, 09:26 PM
Quoted: 1332 Post(s)
Putty knife with very sharp edge,, 1 firm whack with hammer will cut top off.. replacements is like $0.48 at Hyundai-Kia dealer,, but that same retainer used by lots of car makers
sbr711 is offline
post #8 of 21 (permalink) Old 04-20-2017, 09:37 PM
Old's Cool's Avatar
OK, Aye...you got some good suggestions here...get cracking!
Haven't you been arrested yet? In Mass they would have impounded the thing by now! (j/k...but you'd have a pile of tickets for "Faulty Equipment")
<<click...
2009 Accent Hatch
post #9 of 21 (permalink) Old 04-20-2017, 09:54 PM
someguy's Avatar
Quoted: 897 Post(s)
Put a small flathead under the rim to pry it up slightly while you unscrew it with a philips.
flemmons and Tiger-Heli like this.
someguy is offline
post #10 of 21 (permalink) Old 04-20-2017, 11:36 PM
Drives 2011 Sonata YF Limited 2.0T
Quoted: 22 Post(s)
brusty is an unknown quantity at this point
First, hold the outer rim from turning with needle-nose pliers.
Turn the interior gently with the Philips head screwdriver.
Once you've formed a slight separation between the inner "screw" and outer surrounding ring that you're holding from turning, put a standard blade between the "screw" head and outer ring and continue to turn with the Philips while prying outward. Easy.
I have to deal with those when ripping my trunk apart messing with my audio/lighting setups. Once you have the technique, it takes a matter of seconds.
tl;dr - turn lightly until you get a gap, then pry apart while turning
black 2011 Sonata YF Ltd 2.0T - "Baxter"
Nameless SRI, K&N panel filter
Nameless FSTB, stiff rings, Optima RSB
LAP3 Uncle, ADD W1 V2 OCC, HKS M45XL plugs
12.6" StopTech slotted, XG350 calipers, Hawk HPS
Q5 bixenon, Matsushita Gen V, Osram CBIs
LED: Hi-Lux DRLs, Noble tails, cupholders/interiors, Oznium puddle lights
35% tint
Dynamat/MLV/CCF
Frt: stock Infinity midbasses, Perfect 300m mids, JBL P26T tweets
Side: JBL P662 coaxes
Sub: AE SBP15, IB
Amps/DSP: JBL MS-8, R-F R500X1D
brusty is offline
