Oil consumption test pass/fail criteria - Hyundai Forums : Hyundai Forum
 6Likes
post #1 of 26 (permalink) Old 08-08-2016, 10:42 AM Thread Starter
jpolinki's Avatar
2011 Sonata GL Red 2013 Sonata GL White
Quoted: 22 Post(s)
jpolinki is an unknown quantity at this point
Question Oil consumption test pass/fail criteria
I will be dropping my car off for oil consumption test at the dealer. Does anyone know what are the test steps and pass/fail criteria?
Some details about my 2011 Sonata:
1. 110000 miles on the odometer
2. Car uses at least 1qt of oil every 1000 miles
3. No smoke, no leaks or loss of power
4. Covered by engine recall and extended warranty
jpolinki is offline
post #2 of 26 (permalink) Old 08-08-2016, 11:42 AM
Carmine's Avatar
2014 Santa Fe Sport 2.0T AWD w/ Tech Package
Quoted: 11 Post(s)
Carmine is an unknown quantity at this point
You'll have to take it back to the dealer every 1000 miles for another 3 trips. Then they'll do the math with how much oil has been added for each time in. If they do it correctly, that is.
Carmine is offline
post #3 of 26 (permalink) Old 10-26-2016, 12:37 PM
mparker's Avatar
2011 Sonata SE 2.4L
Quoted: 2 Post(s)
mparker is an unknown quantity at this point
I have been going through the same struggle with my 2011 Sonata SE. Burns 1 quart of oil every 1000 miles. I'm on my 3rd oil consumption test. The dealer is saying this is normal consumption but I completely disagree. Manual says change the oil every 7500 miles. So with that recommendation I am changing my oil completely out every oil change.
Engine only holds 5 quarts of oil, burns 1 quart every 1000 miles = 7 quarts of oil in between every oil change.
118,000 miles and this has been happening since 55,000 miles when I first complained about it. This is my 2nd YF Sonata SE and my first one never had this issue. My wife's 2012 Santa Fe with the 2.4 doesn't burn a lick of oil in between changes.
And of course my car passed the Engine recall and received the Red Dip Stick so it doesn't qualify for a replacement.
NOT PLEASED.
2011 Sonata SE 2.4L
Phantom Black
Black Leather Interior
Dimension Stereo
NAV
Production Date: 9/15/2010
mparker is offline
post #4 of 26 (permalink) Old 10-26-2016, 01:15 PM
Quoted: 1424 Post(s)
Industry std is considered 1qt per 1000 mile
sbr711 is online now
post #5 of 26 (permalink) Old 10-26-2016, 09:49 PM
2013 Santa Fe Sport 2.0T Serrano Red Premium and Technology Packages 2001 Sonata 2.5 GLS
Quoted: 145 Post(s)
grandpaswagon is an unknown quantity at this point
That is a CYA statement that has been used for at least 60 years.
Modern cars should not be held to that standard.
100K on a car used to be considered worn out. A 12K warranty was it at most, usually less.
With advanced machining, parts, and other techniques, cars last much longer and should not burn oil at that rate.
grandpaswagon is offline
post #6 of 26 (permalink) Old 10-26-2016, 10:09 PM
yea, but essentially nothing really changed in engine operation too, crank go roundy round, pistons go up and down.. and oil still basically oil.. todays' trend seems to be low tension piston rings, short skirts, and oil seems to find it way past,, add the monkey who keeps old crapped out oil in the crankcase, rather than clean oil
C4RN1 likes this.
post #7 of 26 (permalink) Old 10-27-2016, 08:01 AM
Drives 2012 Kia Optima SX
Quoted: 77 Post(s)
williamhood
NOT PLEASED.
An OCI of 7.5K miles does NOT imply that no oil is to be added over that interval! The expectation by the car makers is that YOU keep the oil level FULL (with the rated oil) over that interval and then change it and the filter when the interval expires or sooner depending on driving conditions as outlined in your manual.
That being said, having to add 1qt of oil every 1K miles is vastly excessive to me (an Engineer) and indicates some other issue has happened. Do you have the dreaded turbo oil line leak? How about the oil pan? Does the car burn an oil (i.e., smokes)? How is the fuel mileage?
2012 Optima SX w/Premium Touring Pkg, "Spicy Red" | 61K miles
Purchased 7/2012, built 3/13/2012 at GA plant.
Mods: LAP3 UncleBoost tune (Stage 1.5+), Injen SRI w/hydro-shield, 3/8" Magnefine Trans filter, PIAA Sports Horns, Fumoto Qwik-Valve, Saikou Michi OCCs (PCV&Intake), HKS M40XL Plugs, Ultra Racing FSTB, Nameless MM,MP,CP w/Synapse SB V2 BOV, Theta2 TBS, CP-E CBE, UR Crank Pulley, Eibach Pro-Kit w/TruHart, Advanti Kudos rims, Conti PureContact tires, 38% tint.
williamhood is offline
post #8 of 26 (permalink) Old 10-27-2016, 09:56 AM
Red Raspberry's Avatar
Quoted: 1012 Post(s)
My Accent has always used some oil, with a a heavier weight and HM oil it is lessened. My Gen Coupe does not burn a drop of oil.
"Imagine a world in which we are all enlightened by objective truths rather than offended by them." Neil deGrasse Tyson
Red Raspberry is offline
post #9 of 26 (permalink) Old 10-27-2016, 01:12 PM
mparker's Avatar
2011 Sonata SE 2.4L
Quoted: 2 Post(s)
I feel it's excessive also, dealer says it's within normal range. It's not a turbo it's the SE and no visible oil leaks anywhere. I do notice a grey smoke when I step on it to pass a car on the freeway. I don't see this when taking off from a stand still. Only when I step on it to downshift and pass someone. I mainly notice this at night as I see the smoke in my rear view mirror in other cars headlights. I have reported this to the dealer. They still claim it's normal.
I have gone as far as to open a case with Hyundai directly so they are monitoring it, especially since they have been hit with the class action lawsuit in recent months regarding their engines. I'm just not pleased with the response that it's considered "Normal".
mparker is offline
post #10 of 26 (permalink) Old 10-28-2016, 01:54 PM
Drives 2012 Sonata Limited Turbo
Quoted: 131 Post(s)
error666 is an unknown quantity at this point
Do you have 118k on this car? If so - it should not be under a warranty and in that case why do you care what the dealer says? If you're sure that it burns oil and you want to pay for a fix - just go to any good engine specialist and pay for a fix. As far as engine seizure recall - I'm afraid it needs to knock or seize to qualify for engine replacement.
error666 is offline
