Today "Synthetic" (with respect to motor oil) is really a marketing term. There are some really very good Group III oils that are called "synthetic" here in the USA-- but are not labeled as synthetic in some other countries.
My commute is mostly highway driving 125 round trip (home to work/work to home.) I've been using what the dealer supplies. When I asked what (brand) oil they used. I could not get a answer. They had no clue... Which troubled me..
Dealer likely has bulk tanks with oil from local supplier. Possibly not a name brand at all. Most likely similar to what you get if you buy Supertech oil from Walmart.
While I don't doubt conventional oil is fine for 7500 miles I am personally more comfortable using synthetic. My last fill in Elantra was Meijer Synthetic 5w30, made by Warren oil, meets or exceeds various specs and under $20 a jug.
I hate Mobil1. Its the most overrated product in the auto industry. That stuff is nothing more than hydrocracked, rearranged oil molecules....derived from CRUDE! True story.
IF any off the shelf oil is real syn, its the natural gas derived Pennzoil platinum, but that's still hydrocarbons.
I contacted HMA. Ask if synthetic oil is recommended for the 2012 sonata 2.4. There response.. They do not recommended the use of synthetic motor oil. They recommended petroleum based oil.
Any reason as to why? I don't want to have an issue with a warranty claim.
Using an oil that meets the API star in manual will be fine. You cannot be denied warranty based on an oil that meets API specification changed within manual specifications. However be careful to read the manual as some criteria make it almost impossible to have a car qualify for 7500 changes. Wording lingo. QS, Penn, M1..etc, etc. Boutique oils are great but fall into a gray area as they are not always certified and that could cause a headache in the event something happens. A nit picky headache but one none-the-less.
I am a syn man as I can do OC myself on the cheap. Right now PPPO at Meijer is on sale for 22.15 ($3 off 5 qt jug). Plus you use your mPerks card they give you another $5 off purchases over $30. I still use OEM filters for the Sonata so I am just buying a few jugs at a time. I buy the OEM filter the day of the oil change for documentation purposes. This latest deal makes an oil change for me about 28 bucks.
Making sure your oil is full (check often) and not over run/used (TBN number only found in analysis) will be more important than worrying about using Penn or M1 or whatever.
Valvoline has a 300,000 mile engine warranty if you register your car with them and keep your receipts. I went to Valvoline with my Scion.
Used QS in an old Mazda because it was the only oil that would keep the lash adjusters quiet. Started at 160,000 and the car was still going at 260,000.
I always use Pennzoil Platinum or QS Ultimate Durability (both are made by Shell).
The reason Hyundai doesn't "recommend" synthetic is because if they did it would raise the question of why they don't use it from the beginning... and that reason is COST, nothing more.
I purchased the vehicle two months ago it's a CPO with 22,000 miles on the ODO. I don't have "oil" change/maintenance records/receipts prior to my purchasing the vehicle. Will I have issues with a warranty claim down the road?
I'm going to bring my own oil to the dealer have them change it. They will charge me for labor and a filter.
Carfax has a free maintenance tracking database (I'm a new member and not able to share the site address yet, but google "My Carfax"). When I got my car, I plugged the VIN in and was able to see all reported maintenance on the vehicle from date of service. It's a useful tool.
+1 on that. You can't control what maintenance the car received prior to your purchase of it. Hyundai certified it. So you are only responsible from now going forward.
Been using Mobil 1 EP since 70k on my 03 santa fe, Currently have 162k and I couldn't be happier with it. I replaced my oil pan last year and there was absolutely no sludge in there at all. I take lots of trips through Canada so put lots of miles on and I have bumped up to the yearly 15k limit several times in the last few years.
I use 5W-20 Penzoil Ultra Platinum, mostly because the black bottle looks cool. Some people say that this is an extremely clean oil. I really don't know if it makes a big difference, but the car sure does run pretty smooth with it.
I found a supply of QSUD. I'll be using that for oil.
