hey all just picked up a set of led switchbacks for the front turn signals. i was wondering where on earth is the drivers and pass. side harness so i can install the hyperblink resistors.
I do not know if the 2014 is the same as my 2013, but this photo shows the pinouts for the headlights. You need only put the resistor between the turn signal wire and a ground-- there are grounds connections very close to each headlight.
I grounded my resistors to the BODY using a factory ground connection-- I did not connect the resistor to a headlight ground wire.
The pinout diagram is of no use to you . . . however, if you have a non-contact voltage tester (very inexpensive, $2-$20)-- with all the lights off and the turn signal on, you should be able to identify the "flashing" voltage in the correct wire-- if you do not find a proper diagram.
I might not buy one this cheap-- but you do not need a $20 Fluke either. This is a VERY useful tool to own.
