My 2011 has just over 27K miles on it. On Saturday the Check Engine light came on. The next time I started the car, it cranked over for about 5 seconds before starting, which is unusual. Then multiple times Sunday and this morning, it seemed to take even longer to crank before starting. This morning, it barely would stay running. And there was a lot of hesitation driving down the road.
I scanned it with my OBD II scanner and got P0087 (Fuel Rail/System Pressure Low). I dropped it off at the dealer this morning and jut got a call that they are replacing the High Pressure Fuel Pump. But they had to special order it overnight and probably won't have it replaced for another day after that.
Has anyone else experienced this failure? Is it common? I couldn't find anything when I did a YF forum search.
Is the high pressure fuel pump the device sticking out the top of the valve cover on the back, driver side of the valve cover, with the multiple fuel lines going into/out of it?
I figured there was a typical electric pump and filter in the tank. But there's no way that pump will supply the 2,000+ psi the GDI system needs to function. And I read somewhere else on this forum how the Theta engine has a second pump on top of the engine for generating the high pressure fuel needed for the GDI system. I also saw a Theta engine video someone posted here that shows what looks like a mechanical fuel pump running off the top of the rear camshaft that was connected to the injectors. I'm trying to put the pieces together with the tidbits of information I've found so far.
I think you are in the right place. GDI is like a diesel engine - two fuel pumps - one to circulate out of the tank, one to pressurize the fuel rails so that fuel can be injected into a compressed cylinder. The high-pressure pump is on top of the engine.
I guess this isn't very common since nobody has responded. Who has had a failed fuel pump in the tank (lift pump) or clogged fuel filters in the tank? Are either of these common?
Even though the dealer claims the high pressure pump has failed, I am suspicious of the lift pump or filter in the tank. If they can't supply enough fuel to the high pressure pump, then the HPP can't generate enough flow and pressure. We'll see how the fix goes. In the meantime I get to drive a very stylish Ford Focus.
I did see that one but the impression I got was that the starter lever was the problem and they just replaced the high pressure pump for good measure. Maybe with a no-start condition it's standard to replace the starter lever and test the high pressure pump, which failed the pressure test. Did the dealer make it clear which repair was the immediate cause and which one they did just to be safe? I haven't really seen many other posts doing a search and going back a few months on this topic of failing fuel pumps.
Dealer replaced the High Pressure Pump and fuel tube going from it to the fuel rail. It seems to be all fixed now. Can anyone with this model vehicle tell me if there is a clamp/clip that secures the cable going to the High Pressure Pump to the top of the valve cover, next to the pump? My valve cover has a threaded boss with nothing threaded into it and there is no clip or clamp to secure the cables going into the connector on the side of the pump. I have not been able to find a good schematic or a close-up picture of this area to figure out if the tech left off a part (the clip/clamp).
Yup that would be mine! Lol mine went south on me... Hyundia had to replace the starter leaver and the fuel pump! Who would of thunk! Watched my baby drive away on a flatbed!
Just had my 2012 Kia Optima SX 51,000 miles taken to the dealership for MIL Code P0087. They Replaced the HPFP (High Pressure Fuel Pump). This is when i found out there is 2 pumps on the car one in the tank and one on top of the engine. I sure hope this isn't going to be a common occurrence.
Had to have my high pressure fuel pump changed also. Best of all still had 24 days left on the warranty. Got it done at fitzgerld in Clearwater FL. With no hassle. Thanks to Anthony and the service staff.
I have the EXACT issue described by the original poster. I purchased my 2013 Sonata 2.4 USED, so I believe it only has the 6/60k warranty. I am at 62k. Any chance Hyundai would budge on the warranty since it so close?
Anyone know the cost to have this replaced?
While I love my Sonata (I also had a 2008 Sonata Limited), I am disappointed that this seems to be an issue for many. Sounds like a defective part(s) were used.
My mechanic called me with more details on my fuel pump issue. He confirmed it was the high pressure fuel pump. He stated that he has had 8 instances of this happening with Sonata's exceeding 60k. Hyundai would not budge on the 60k warranty. The mechanic quoted $593 for the pump and $75 to install. I just purchased the Hyundai OEM pump on eBay for $400 and will get it installed at a different mechanic for $65.
While I had a crash course on many of the positive things high pressure fuel can accomplish in power and MPG, it seems they may have some kinks to work out. @rafciu123 - Dial it down Kemosabi.
Before you get it installed,ask your mechanic about the tube or fitting that connects to the fuel pump. I thought I read that if the seal is broken,its a 1 time thing meaning it should be replaced because it could leak otherwise.
Do not quote me on that,I read this quite some time ago.Would hate to see you get this replaced only to have gas leaking in your engine bay onto a hot exhaust. Double check that info....
My wife has a 2013 Sonata with 34,000 miles and has similar problems. A mechanic
told me that it was the high pressure fuel pump. Think that would be covered by
the warranty?
Well one might argue that NY is a very different region from CA.
But you're probably right, it's been a while since I actually had the car so I may be rusty on the specifics. But the main point, of which I am certain, is that the pump is not covered under powertrain.
High pressure fuel pump is a 5yr/60 item... they starting to drop like fly randomly. Neighbor just had 1 to replace, customer pay..
Pump in tank feeds GDI ppump with approx 65PSI via quick connect,, then GDI pump raise pressure to 500 - 17/1800 PSI for injection into cylinder,, deliver to fuel rail with steel tube (threaded fitting), and injectors are fired via 55V DC signal from PCM
could you explain your statement: "they starting to drop like fly randomly"
I am at 28k miles BUT one month away from 5 years of ownership and i am trying to add up the potential mx costs of common failure items (mainly read about on these forums):
1. starter lever 300
2. HPFP 600
3. battery 100
4. oil pan leak - covered by powertrain wty?
Changing the GDI pump is the easy part.. torque wrench to the delivery pipe' nuts is the fun part,, we have special socket from Hyundai (had to modify it as the wrench portion is too big to fit over nut at fuel rail and hit block/head)
I'll take pic if I can remember to.. I think it still sitting on top of my terminal..
I am sure this has come up before but:
How can the pump (HPFP) not be part of the powertrain warranty if this is a DIRECT INJECTION engine (GDI)? no pump, no power
where are the details of what is and isn't covered by the powertrain warranty?
It's quite simple really. Powertrain, as defined by Hyundai and most other manufacturers as well, refers to "internally lubricated parts" so basically all the oily spinning bits inside the engine and transmission. Stuff that is bolted on externally such as engine accessories and the HPFP would not fall under this coverage and is covered by the general vehicle warranty.
The conventional low-pressure pump in the tank isn't covered under powertrain either, and never was even when it was the only pump supplying fuel to the engine.
Not entirely, but most people don't understand what it does and doesn't cover (of course the marketing folks are counting on that).
410K members
