Knocking noise - Hyundai Forums : Hyundai Forum
post #1 of 16 (permalink) Old 01-29-2013, 09:28 AM Thread Starter
2012 Sonata
lovoyl is an unknown quantity at this point
Knocking noise
Hi:
I have a 2011 Sonata. Recently, I have heard a faint knocking sound when I'm in reverse. It doesn't do it all the time. When I took it into the dealer, it would not make the sound while there. Does anyone know what causes that sound?
thanks.
lovoyl is offline
post #2 of 16 (permalink) Old 01-29-2013, 09:47 AM
Drives: 2013 Sonata GLS, 2009 Venza AWD V6, 2010 Toyota Corolla, 2008 Pontiac G5, 2010 Mazda 3 G
Quoted: 57 Post(s)
Danno is an unknown quantity at this point
First thought might be a loose/defective engine mount that only causes the noise when the drivetrain has different/reverse torque put through it.
Danno is offline
post #3 of 16 (permalink) Old 01-29-2013, 09:58 AM
Bearcats's Avatar
Quoted: 267 Post(s)
Vague description.
Also, where do you do your oil changes and what oil filter do you have?
KDM YF LED tails | Llumar 30% Ceramic Tint | Precision LED 5K Interior lighting | XenonSupply 4300K Slimline HID's | The "cup" mod
Bearcats is offline
post #4 of 16 (permalink) Old 01-29-2013, 12:03 PM
Knightro2's Avatar
'12 Sonata GLS Pop Package; '12 Elantra GLS Pref Package
Quoted: 80 Post(s)
Knightro2 is an unknown quantity at this point
Originally Posted by Bearcats View Post
Vague description.
+1 on the oil filter question. It has been known that third-party oil filters can cause knocking in our engines. I had that issue when using a STP filter once....once. I had one in my garage and needed to do the oil change that day and I had run out of the OEM filters I normally buy.
Best to stay with the OEM filters. Due to the tight tolerances of our engines because of every last MPG they squeezed out of it it can cause knocking.
Hyundai actually put out a service bulletin about this dating back to 2005. http://www.hyundai-forums.com/attach...20-002-pdf.pdf
Some people are like Slinkies....not really good for anything but bring a smile to your face when pushed down the stairs.
Last edited by Knightro2; 01-29-2013 at 12:16 PM. Reason: Added service bulletin info
Knightro2 is offline
post #5 of 16 (permalink) Old 01-29-2013, 01:25 PM
Bearcats's Avatar
Quoted: 267 Post(s)
Dont knock yourself. Mine did it with K&N and M1 as well. So there is something different about the OEM filter. That has me a tad concerned. I am wondering if the bypass spring kicks in earlier or something.
Given the pictures Smoke posted a while ago, there was no real differences between the filters without using scientific equipment.
Bearcats is offline
post #6 of 16 (permalink) Old 01-29-2013, 01:46 PM
Knightro2's Avatar
Quoted: 80 Post(s)
Actually, here is an updated one from September 2012. http://www.hyundai-forums.com/attach...-12-em-006.pdf
post #7 of 16 (permalink) Old 01-29-2013, 08:31 PM
Mikemu's Avatar
2014 Azera Limited with Premium - Porcelain White w/Black interior
Quoted: 367 Post(s)
Mikemu is an unknown quantity at this point
Vague description.
Knock only in reverse though.
Mikemu is offline
post #8 of 16 (permalink) Old 01-30-2013, 07:34 AM
Bearcats's Avatar
Quoted: 267 Post(s)
You dont discount anything when so little is given in regards to information. Mine only knocks when the car is in certain positions with non-OEM filters. It was most curious.
Bearcats is offline
post #9 of 16 (permalink) Old 01-30-2013, 07:42 PM
Mikemu's Avatar
Quoted: 367 Post(s)
Interesting. I keep reading about the non-OEM filters here and wonder. I've had my independent shop do only one change so far so I've driven roughly 4k of the 15k on the clock with a non-OEM. No knocks. They use Quaker St filters.
Mikemu is offline
post #10 of 16 (permalink) Old 01-31-2013, 09:20 AM
Bearcats's Avatar
Quoted: 267 Post(s)
I have used M1, K&N and Bosche Distance Plus. On SBR's recommendation (per the TS I switched to OEM filters and it has never done it again.
When it would do it is when I parked it at the end of the driveway where there was just the slightest incline so the rear was lower than the front...by like an inch. At the top of the driveway there was no issue.
Bearcats is offline
