Load Resistor Question - Hyundai Forums : Hyundai Forum
post #1 of 7 (permalink) Old 01-21-2013, 10:54 AM Thread Starter
Torchbearer's Avatar
2012 Sonata SE, 2002 Ford F150 Pick up truck, 2000 Honda Accord, 1998 Honda Civic
Torchbearer is an unknown quantity at this point
I'm sure this question has been asked and answered a gazillion times, but please indulge me. I have installed LED turn signals without a load resistor. And I off course am experiencing the rapid flashing. I ordered a set of load resistors (6 ohm 50 watts) to take care of this little problem. Below is a schematic drawing I did showing the load resistor and the LED. The resistor is supposed to be parallel to the diode. Is what depicted in the drawing accurate? Thanks again!
Torchbearer is offline
post #2 of 7 (permalink) Old 01-21-2013, 11:53 AM
jglopic's Avatar
Drives YF Sonata Hybrid
jglopic is an unknown quantity at this point
Looks correct to me.
The hyperflashing is because the car thinks a bulb is blown based upon the fact that the current is less than designed (the LED uses very low current compared to an incandescent bulb). Adding the resister in parallel allows more current to pass through the control module, thereby "fooling" the computer into thinking that incandescent bulbs are installed and functional.
Touring the greater Houston area and trying to save a little gas doing it!
jglopic is offline
post #3 of 7 (permalink) Old 01-21-2013, 07:49 PM Thread Starter
Thanks so much for the input. I appreciate it.
post #4 of 7 (permalink) Old 02-07-2013, 12:18 PM
Thatguy_JZ's Avatar
2011 Hyundai Sonata SE - 2002 BMW 325CI
Thatguy_JZ is an unknown quantity at this point
Check superbrightleds.com, they have relays to replace OEM which they say fix the hyper-blink effect. I've never used them, just going off their advertising.
2011 Hyundai Sonata Installation Accessories LED Replacement Bulbs | LED Lights for Cars | 12v | Super Bright LEDs
Thatguy_JZ is offline
post #5 of 7 (permalink) Old 02-07-2013, 12:56 PM Thread Starter
Thanks for the reply everyone... installed and working great. I'm happy happy happy!
post #6 of 7 (permalink) Old 02-07-2013, 01:29 PM
jglopic's Avatar
Sonata's don't have an external flasher relay like this. Hyundai programs the flashing function into the BCM and uses the hyper-flash simply to alert the driver that a bulb is out. The hyper-flash function cannot be overriden in this type of design except by load resistors which make the car "think" that an incandescent bulb is installed.
jglopic is offline
post #7 of 7 (permalink) Old 02-07-2013, 01:44 PM
Thatguy_JZ's Avatar
Good to know, thanks!
