Low battery voltage - Hyundai Forums : Hyundai Forum
post #1 of 16 (permalink) Old 11-20-2012, 10:29 AM Thread Starter
2012 Sonata SE 2.4L - Traded in on a 2014 Ford Fusion 2000 Camaro SS
Quoted: 41 Post(s)
Low battery voltage
When I checked the battery voltage on my car with my digital meter, it registered only 11.5 volts. This measurement was taken with the car's engine turned off. When the car is running the reading is right around 13 volts which I assume is normal hen it is being charged by the alternator. But as soon as you turn off the engine, the voltage starts to drop when you look at it with the multi-meter.
Right now I am charging it up with my battery charger. Once it is fully charged, I will continue to keep an eye on it. But I am wondering if there is enough parasitic drain from the electronic components to discharge a battery if the car sits idle for 2-3 days?
Traded in for a 2014 Ford Fusion
Dave-S is offline
post #2 of 16 (permalink) Old 11-20-2012, 11:05 AM
2011 Sonata GLS MT (gone)
Quoted: 24 Post(s)
Fox Mulder is an unknown quantity at this point
No not in just a few days. It would take a lot longer than that. The battery should be tested to see if it is failing, the charging system can be checked as well to make sure it is functioning properly. 13V with the engine running and no accessories turned on is actually a bit on the low side, I'd expect to see closer to 14V.
Fox Mulder is online now
post #3 of 16 (permalink) Old 11-20-2012, 11:14 AM
Quoted: 3 Post(s)
Zebodog is an unknown quantity at this point
I wouldn't worry about it unless you're having specific battery related issues.
Zebodog is offline
post #4 of 16 (permalink) Old 11-20-2012, 12:21 PM
Drives 2013 Sonata SE!
Quoted: 4 Post(s)
Smutty is an unknown quantity at this point
Multimeter won't really tell you much unless you have an amp-clamp that you can hook up to see the draw when the engine is off. You need to load test your battery to get a better idea of it's true condition. Somewhat low voltage isn't necessarily a problem unless it's accompanied by a draw or low CCA.
Smutty is offline
post #5 of 16 (permalink) Old 11-20-2012, 01:14 PM Thread Starter
Quoted: 41 Post(s)
So far I have had no starting problems or other electrical issues I can attribute to the battery. Just to be on the safe side, the car is going into the dealer next week to have the battery and charging system checked.
Does anyone know if the voltage regulators for our cars is built into the alternator or is it a separate component?
Dave
Dave-S is offline
post #6 of 16 (permalink) Old 11-20-2012, 01:19 PM
RBD
2012 Sonata Limited 2.0T Loaded
Quoted: 45 Post(s)
RBD is an unknown quantity at this point
Each cell should be 2.1 volts when fully charged. Thus, 6 cells would equal 12.6V. If your reading 11.5V, either you have a battery going out, or it sat for a long time with something drawing it down.
RBD is offline
post #7 of 16 (permalink) Old 11-20-2012, 02:04 PM
titaniumskull's Avatar
3.8 Grand Touring
titaniumskull is an unknown quantity at this point
Cold weather has an effect on the battery.
Least you can do is take it to the dealer so they can do a load test. If there is an issue the load test will tell.
titaniumskull is offline
post #8 of 16 (permalink) Old 11-20-2012, 02:17 PM
2011 Sonata SE
nickpapa is an unknown quantity at this point
if there is an autozone or advance autoparts close by, they do free battery and alternator tests. worth a shot if you dont want to waste a day at the dealer
nickpapa is offline
post #9 of 16 (permalink) Old 11-20-2012, 03:21 PM
MikeyTG's Avatar
Quoted: 24 Post(s)
MikeyTG
Are you sure your meter is accurate?
MikeyTG is offline
post #10 of 16 (permalink) Old 11-20-2012, 03:25 PM
Quoted: 24 Post(s)
The alternator is internally regulated. However there is also external control of charging behavior by the PCM through an external sensor at the battery, so if you suspect any issues with the battery or charging system it would probably be best to have it checked at a dealer. Any problems should be covered under warranty, including a bad battery if it's within the full warranty or prorate period.
