UNAVI - $120 LED DRL kit ... INSTALLED WITH PICS! - Hyundai Forums : Hyundai Forum
post #1 of 55 (permalink) Old 05-25-2012, 11:36 AM Thread Starter
RedTurbo's Avatar
2011 Sonata 2.0 SE Turbo
RedTurbo is on a distinguished road
Stay tuned, I will upload the full D.I.Y. a little bit later on!
- Red
MODS (in order of appearance): rebadged "Tigris" kit, black horizon badgeless grille, gloss black powdercoated 18's, Midnight Black OEM lip spoiler, 38% Johnson's tint on everything but windshield, painted calipers gloss black, UNAVI - X2 (8" Factory Integrated Multinavigation system), 18-LED H7 bulbs in high/DRL's, 6000K low's from XS, Lamin-X fog film (yellow), and EuroExport BOV spacer
RedTurbo is offline
post #2 of 55 (permalink) Old 05-25-2012, 11:42 AM
RedPrez87's Avatar
Drove 2011 Sonata GLS --Upgraded to 2014 Limited Turbo-- ----The rest is history----
RedPrez87 is an unknown quantity at this point
- Red
Nice man, Hey do you have HIDs on you're car or regular bulbs?
2014 Sonata Limited Turbo (
--35% all around tint--
RedPrez87 is offline
post #3 of 55 (permalink) Old 05-25-2012, 12:20 PM Thread Starter
RedTurbo's Avatar
LED bulbs in high's/DRL's
6000k in low's
RedTurbo is offline
post #4 of 55 (permalink) Old 05-25-2012, 01:33 PM
Quoted: 19 Post(s)
eriffic
- Red
Are your LED's on? Looks like your low beams are..... looks dim.
eriffic is offline
post #5 of 55 (permalink) Old 05-25-2012, 02:15 PM
stunt101's Avatar
Drives Sonata YF 2011 GLS
stunt101
Looks great. at $120 that's a good deal
stunt101 is offline
post #6 of 55 (permalink) Old 05-25-2012, 03:25 PM Thread Starter
RedTurbo's Avatar
it was 9am lol
they are all quite bright
RedTurbo is offline
post #7 of 55 (permalink) Old 05-25-2012, 03:35 PM
Stevaroo01's Avatar
2012 Sonata SE in Harbor Gray
Stevaroo01 is an unknown quantity at this point
Nice bro! I'd like to see the night shots now!! Also, how did you end up wiring them up? Ignition, DRL, lows?
Good work!
Sent from my Autoguide iPhone app
2012 Sonata 2.4 SE in Harbor Gray (DOB 2/29/12),
, rear LED's,
, etc... and more to come!
Stevaroo01 is offline
post #8 of 55 (permalink) Old 05-25-2012, 06:17 PM
brunosonata's Avatar
2011 Sonata
brunosonata is an unknown quantity at this point
red give us a glimpse of a night shottttt!!!!
brunosonata is offline
post #9 of 55 (permalink) Old 05-25-2012, 06:19 PM Thread Starter
RedTurbo's Avatar
D.I.Y. Time ... FOR YF WITH FOGLIGHTS!
( this is only meant to document how it works with my car I am not responsible for any decisions you make about your own car)
1) clean the bumper around the fogs thoroughly (I used microfiber and rubbing alcohol)
2) unscrew the two trim brackets holding in each splashguard
3) feed the white/positive and black/negative wires connected to the back of the LED DRL housings, through the space between the foglight and bumper ... (stick your hand up through the splash guard and pull the wires down and out of the area) ...
3.5) it is time to peel back just a little of the inner and outer tape backing to line-up the LED DRL housings - as they are lined up, maintain pressure to keep in place and gently pull the tape backing off ... hold for a minute so the tape can bond ... *note - the tape makes them stick out a couple MM ...
4) tie the other segment of wiring (that has a capacitor) to a string with a weight on it, and feed the shorter section through the splashguard ...
5) either solder, crimp butt connectors, or twist the pos./pos. and neg./neg. and use heat shtink tape or electrical tape to finish ...
6) on the passenger side, ziptie the capacitor as close to the grille as you can and run the wires over the radiator (there is foam to keep them in place if you.push back) ... on the driver's side you'll have some extra wiring, do zip tie everything below the capacitor ...
7) snip the wires coming off the driver's side capacitor just a few inches up from.the capacitor ...
8) twist, solder, or butt connect the wires coming from both capacitors together (pos./pos' and neg./.eg. ....
9) take the extra wires snipped off in step 7, and twist solder, or butt connect THAT pos. to pos. and neg. to neg.
10) put a spade connector on the pos. wire and secure it by crimping, etc. and then use a round connector on the neg. wire (secure it in the same fashion)
11) connect ground to neg. battery terminal, and then plug spade connector here
(be mindful to not damage the positive wire as you put the cap back on the block)
12) Enjoy!
RedTurbo is offline
post #10 of 55 (permalink) Old 05-25-2012, 06:25 PM
2011 Sonata
12) Enjoy!
dam bro this is awesome, thanks for the write up. night shots?? (off topic) where did u get the grill from?? and cut you nailsssssss lol jk
