Auto Door Lock/unlock - Page 2 - Hyundai Forums : Hyundai Forum
post #11 of 15 (permalink) Old 06-05-2011, 09:06 PM
jsmit86's Avatar
Drives 2015 Genesis 3.8 AWD
Quoted: 49 Post(s)
jsmit86 is an unknown quantity at this point
QUOTE (Sporky @ Jun 5 2011, 12:55 PM)
On the trip computer it allows you to set it for shift or for speed. I set mine for speed but I haven't tried it out yet to see if it works.
I have a 2011 Sonata Limited. I can confirm that my car UNLOCKS the doors when the gear selector is put in PARK.
Once the car is in gear, my door LOCK when the speed reaches approximately 10 MPH.
[b]The following is excerpted from the Owner's Manual
You can activate or deactivate some auto
door lock/unlock features in the vehicle
setting as follows;
• Speed sensing auto door lock
• Auto door unlock by unlocking the
driver's door
• Auto door unlock when the ignition
key is removed from the ignition
switch or the smart key is removed
from the smart key holder.
• Auto door lock/unlock by shifting the
transmission shift lever out of P
(Park) or into P (Park)
If you want to activate or deactivate
some door lock/unlock feature, refer to
the “vehicle setting” in this chapter.
[b]The following section begins on page 4-53:
Vehicle setting
When the vehicle is at a standstill, pressing
the TRIP button for more than 2 seconds
with the engine start/stop button in
the ON position or engine running, the
LCD screen on the cluster will change to
the vehicle setting mode.
You can change the item by pressing the
TRIP button and choose the item by
pressing the RESET button.
Auto door lock
Off - The auto door lock operation will be
canceled.
Speed - All doors will be automatically
locked when the vehicle speed
exceeds 9.3mph (15km/h).
Shift Lever (if equipped) -
All doors will be automatically locked if
the shift lever is shifted from the P(Park)
position to the R(Reverse), N(Neutral) or
D(Drive) position.
Auto door unlock
Off - The auto door unlock operation will
be canceled.
Key Out - All doors will be automatically
unlocked when the ignition
key is removed from ignition
switch (or smart key is
removed from the smart key
holder).
Door - All doors will be automatically
unlocked if the driver's door is
unlocked inside.
All doors will be automatically unlocked if
the shift lever is shifted to the P(Park)
position.
[b]
and continues on 4-54:
Two-press unlock
Driver Door 1st Press - The driver's
door will unlock when pressing the
unlock button on the transmitter or smart
key, pressing the button of the driver's
outside door handle with the smart key,
or inserting the key into the key hole of
the driver's outside door and turning the
key toward the rear of the vehicle. All
doors will unlock when pressing the
key toward the rear of the vehicle within
4 seconds.
All Doors 1st Press - All doors will
unlock when pressing the unlock button
on the transmitter or smart key, pressing
the button of the driver's outside door
handle with the smart key, or inserting
the key into the key hole of the driver's
outside door and turning the key toward
Montecito Blue
Beige Interior
Signature Package
jsmit86 is offline
post #12 of 15 (permalink) Old 06-06-2011, 03:42 AM Thread Starter
zubair
QUOTE (jsmit86 @ Jun 6 2011, 06:06 AM)
setting as follows;
driver's door
Vehicle setting
Auto door lock
canceled.
D(Drive) position.
Auto door unlock
be canceled.
holder).
unlocked inside.
position.
[b]
Two-press unlock
4 seconds.
i have gone through the owner's manual and you have rightly mentioned the excerpts from the manual. However, the moment I try and access the Auto Lock and Unlock options in the trip computer I am shown a (!) mark and not allowed to customize the settings. To be honest with you it is quite baffling to have the options in the computer but not be able to customize the same according to your needs. The dealer here isn't much help either. They have just brushed it off saying that the option is not available in this particular lot. My bone of contention is that if the trip computer has the options, then I should be able to activate them if the dealer programs it for me, but I don't think I'll have any luck on that front.
zubair is offline
post #13 of 15 (permalink) Old 06-06-2011, 04:02 AM
pentone
Dear,
Please find below these my posts in face book- http://www.facebook.com/hyundaiuae.
Sameer Kh
I have the new Sonata 2011(Type12). I was s trying to set auto door lock. But the menu is not possible to change for the Door lock and unlock as per in the manual, Page 4/50. Please advice me how to set up the door autolock.
February 22 at 8:07pm · Like ·
Hyundai UAE Dear Sameer
Will reply to your query once we get the required information for you. So bear with us till then. Cheers.
February 23 at 6:47am · Like
Sameer Kh Waiting for your reply.
February 28 at 11:50am · Like
Sameer Kh
Sameer Kh
I have the new Sonata 2011(Type12). I was s trying to set auto door lock with the trip key. But the menu is not possible to change for the Door lock and unlock as per in the manual, Page 4/50. Please advice me how to set up the doo...See More
March 13 at 2:56pm · Like
Sameer Kh
I have checked with the Hyundai dealer, Juma Al Majid.Ras Al Khor,UAE. The technician informed that for Sonata 2011(Type12), this auto lock function is not available. How this possible? I can see the menu in the display.From the manual it i...See More
March 13 at 3:26pm · Like
Hyundai UAE We are also forwarding this to someone responsible to help you in a day or 2. So bear with us.
March 13 at 4:28pm · Like
Sameer Kh
I have visited Juma Al Majid, Hyundai dealer on 15.03.2011. The engineer checked my Sonata. Also there was two more sonata of the same model and make present at that time.One of that has auto lock function but the other one doesn't.So The...See More
March 15 at 3:28pm · Like
Sameer Kh After make a test drive Sonata 2011 (Type 12) sold by Juma al majid,I have decided to buy Sonata 2011 (Type 12).
I trust the quality of Hyundai product.If this happened by mistake, should be fixed immediately.
March 19 at 1:13pm · Unlike · 1 person
Sameer Kh
As a prestigious Hyundai user I am kindly requesting for the advise from the Hyundai Korea, how this happened to my car and also for some other cars in that batch. Whether it is manufacturing defect? I think this may be the defect of the lock unit supplied by external supplier to Hyundai.I wish to add this option to my Sonata.
Please note that MAY2010 and OCT2010 makes has auto lock feature.
The Chasis no: of my Sonata 2011 is Make DEC2010.
March 20 at 4:27pm · Unlike · 1 person
Sameer Kh
The dealer in UAE, Juma Al Majid is helpless because still they could not find why some cars is missing of the feature(Door Auto lock) in the same batch & category of sonata 2011 Type 12. They told they will contact Korea HQ. Still no answer. That is the reason I am posting my request in available Hyundai chats.As an prestigious Hyundai user, I need to know why this kind of mistake happens for Hyundai, even having the high quality control standards.I wish to fix this problem at any cost.
April 6 at 11:17am · Like
I under stood that the production after may 2010 doesn't have this option, either by mistake or by purpose as cost cutting.
Please from details below
HYUNDAI SONATA 2011- UAE MARKET
TYPE MONTH YEAR CHASIS NO: COLOR DOOR OPTION
14 FL OPTN,AMP360W MAR 2010 KMHEB41C1BA110402 BLUE YES
12 BASIC MAY 2010 KMHEB41C9BA149001 WHITE YES
12 BASIC OCT 2010 KMHEB416BA231672 GREY METAL NO
12 BASIC DEC 2010 KMHEB41C9BA266156 BLACK NO
13 SUN ROOF, ABS FEB 2011 KMHEB41C9CA288000 WHITE NO
Kindly add your car deatils
Sameer.
pentone is offline
post #14 of 15 (permalink) Old 12-19-2011, 01:47 AM
2011 Sonata GL
shkamran is an unknown quantity at this point
Hi Zubair,
I am facing the same problem with the auto lock feature. Did anyone from Hyundai get back to you on how to solve it?
shkamran is offline
post #15 of 15 (permalink) Old 03-28-2012, 03:34 AM
Drives 2010 Sonata YF 2.0 MPi
Shah1661 is an unknown quantity at this point
Hi Zubir, FYI this auto lock/unlock features only available if your car have the side/curtain airbags as standard.
Shah1661 is offline
