Driver's Door Fix - Hyundai Forums : Hyundai Forum
post #1 of 18 (permalink) Old 05-28-2011, 07:19 PM Thread Starter
sp4772
Just unscrew the "U" clamp, use a Dremel to make an oval hole. That way, you will be able to move the "U" inward and make you door close fermly. Remove material little by little with the Dremel and try to fit the screw frequently to achieve perfect fit together. When done, put blue Loctite on the screws and adjust carefully before tighting. Voilà!
So easy.
Pictures on their way....
sp4772 is offline
post #2 of 18 (permalink) Old 05-28-2011, 07:22 PM
jsmit86's Avatar
Drives 2015 Genesis 3.8 AWD
Quoted: 49 Post(s)
jsmit86 is an unknown quantity at this point
QUOTE (sp4772 @ May 28 2011, 05:19 PM)
Just unscrew the "U" clamp, use a dremel to make an oval hole. That way, you will be able to move the "U" inward and make you door close fermly. Remove material little by little with the Dremel and try to fit the screw frequently to achieve perfect fit together. When done, put blue Loctite on the screws and adjust carefully before tighting. Voilà!
So easy.
What exactly does this fix?
Montecito Blue
Beige Interior
Signature Package
jsmit86 is offline
post #3 of 18 (permalink) Old 05-28-2011, 07:27 PM Thread Starter
sp4772
QUOTE (jsmit86 @ May 28 2011, 06:22 PM)
The bad sound many of us complained when closing the driver's door...
Now mine just give the same solid feeling as the three others.
sp4772 is offline
post #4 of 18 (permalink) Old 05-28-2011, 07:38 PM Thread Starter
sp4772
Here we go...
sp4772 is offline
post #5 of 18 (permalink) Old 05-29-2011, 12:25 PM
Smoke1991's Avatar
11 Sonata 2.4
Quoted: 31 Post(s)
Smoke1991 is an unknown quantity at this point
doing that modification to the striker plate accomplishes nothing, if anything your able to slightly adjust the striker position a bit more and that's it.
2011 Sonata Limited Silver/Black leather with Nav.
To many mods to list...
(I don't know what I am talking about, so listen to the other guy.... he knows better)
Smoke1991 is offline
post #6 of 18 (permalink) Old 05-29-2011, 02:54 PM
snapper41's Avatar
2011 Sonata YF Limited 2016 Tucson Limited
Quoted: 12 Post(s)
snapper41
The striker plate bolts into the B post and that plate has the required adjustment movement, up/down, in/out, to properly adjust the door.
snapper41 is offline
post #7 of 18 (permalink) Old 05-29-2011, 03:03 PM
2011 Sonata GLS MT (gone)
Quoted: 25 Post(s)
Fox Mulder is an unknown quantity at this point
Yep all you've done is weaken the striker plate and make it more likely to loosen up in the future. You've also given the dealer a reason to refuse any warranty work to align the door.
Fox Mulder is offline
post #8 of 18 (permalink) Old 05-29-2011, 07:29 PM
Smoke1991's Avatar
11 Sonata 2.4
Quoted: 31 Post(s)
QUOTE (Fox Mulder @ May 29 2011, 02:03 PM)
+1
post #9 of 18 (permalink) Old 05-31-2011, 11:22 AM Thread Starter
sp4772
QUOTE (Smoke1991 @ May 29 2011, 11:25 AM)
Why then my door close fermly now without bouncing?
sp4772 is offline
post #10 of 18 (permalink) Old 05-31-2011, 11:25 AM Thread Starter
sp4772
QUOTE (snapper41 @ May 29 2011, 01:54 PM)
Well, show me a pic of that because mine had NO PLAY at all!!
sp4772 is offline
