Leaky Oil Pan. - Hyundai Forums : Hyundai Forum
post #1 of 12 (permalink) Old 11-22-2010, 12:32 PM Thread Starter
morenar
Yesterday I went to pull the car out of the garage and notice a small oil stain right under the oil filter accessible hole. So i reach in and feel the oil filter and it felt greasy.Checked the oil level and it was ok. I already have an appt today to get the oil change so I had the dealer check it. Come to find out the oil pan had to be resealed. Anyone else seen this on their's or was it just a bad sealant job at the factory?
morenar is offline
post #2 of 12 (permalink) Old 11-23-2010, 12:16 AM
xm8
xm8
The bolts on the oil pan have to be torqued in a criss cross pattern and torqued to the correct spec with a quarter inch torque wrench otherwise you will have leaks. The honda bond/gasket maker is applied on specific areas of the oil pan. I have changed out oil pan gaskets on hondas and nissans.
xm8 is offline
post #3 of 12 (permalink) Old 11-23-2010, 02:31 PM
Bearcats's Avatar
Quoted: 297 Post(s)
Have you had your oil changed prior to this? If so I suspect sloppy oil change or an incorrectly torqued oil drain bolt.
KDM YF LED tails | Llumar 30% Ceramic Tint | Precision LED 5K Interior lighting | XenonSupply 4300K Slimline HID's | The "cup" mod
Bearcats is offline
post #4 of 12 (permalink) Old 11-23-2010, 05:11 PM Thread Starter
morenar
Had it changed once before.
morenar is offline
post #5 of 12 (permalink) Old 11-24-2010, 03:01 AM
xm8
xm8
To eliminate the possibility of a drain bolt that is not tightened enough, jack up the car and torque the drain bolt with a 3/8" torque wrench to the manufacturer's torque spec. To eliminate the possibility of oil coming from the oil filter, jack up the car and wipe down all excess oil with simple green cleaner, then make sure the oil filter is tight by grabbing it with your hand and tighten it. After you do all of this drive it around and jack up the car to look for leaks.
xm8 is offline
post #6 of 12 (permalink) Old 11-24-2010, 11:00 PM
Bearcats's Avatar
Quoted: 297 Post(s)
QUOTE (morenar @ Nov 23 2010, 05:11 PM)
My guess, and that's all it is, that they blew smoke up yer behind to cover up a crappy oil change. I am also guessing they changed the oil too.
Bearcats is offline
post #7 of 12 (permalink) Old 11-26-2010, 01:15 AM
HYUNDAIS: 2013 Azera Tech, 2013 Accent, 2012 Tucson
Quoted: 18 Post(s)
elp_jc is an unknown quantity at this point
QUOTE (Bearcats @ Nov 23 2010, 02:31 PM)
Probably that. When I changed the oil, noticed by the deformed crush washer that the surface where the washer touches is not perfectly flat. Tightened the bolt by hand like I've done it for decades without a drop leaked, but noticed a small puddle under the car. Long story short, only spec torque got rid of the leak. Factory torque specs are ridiculously high for a flimsy aluminum pan IMO, but had to do it. As a comment, Hyundai's washer seemed like steel. Next time will install a Honda one, which are softer, and deform easier. Hopefully I don't have to torque it that high. Don't want to strip that darn pan after a few times.
2016 Optima SX-L, white/white Nappa. MODS: Chromed wheels, wheel locks, mud guards, cargo mat, cargo hook, 35% window tint (travel car)
2013 Accent Premium, white/beige (daughter 1)
2012 Tucson Limited w/nav, silver/black. MODS: Window tint, cargo mat, wheel locks, radiator screen, dual horns (daughter 2)
elp_jc is offline
post #8 of 12 (permalink) Old 11-26-2010, 08:18 PM
xm8
xm8
What is the torque spec in lb. ft. for the Sonata's oil drain bolt? I am planning of purchasing a SE turbo.
Torque spec is 33 lb. ft. for most Honda/Acuras.
xm8 is offline
post #9 of 12 (permalink) Old 12-11-2010, 01:39 PM
bulwnkl
Guest
Posts: n/a
Quoted: Post(s)
I'd also like to know Hyundai's torque spec for the engine oil drain bolt. And the torque specs for the A/T drain and fill/check bolts. Anyone?
post #10 of 12 (permalink) Old 12-11-2010, 02:55 PM
T-Rex
As far as the actual drain plug goes, if you do your own oil changes you should really take a look at the Fumoto Valve. I have them on both current cars and will put one on any car I own. You install it once and then never have to grab the wrench again for your oil changes.
T-Rex is offline
