2011 Sonata And Homelink - Hyundai Forums : Hyundai Forum
post #1 of 14 (permalink) Old 06-22-2010, 10:40 PM Thread Starter
uscfsu23
OK I have spent the past 2 hours trying to get my Craftsmen 1/2HP Garage Door opener to work with my new Sonata's homelink. I have looked through the various post concerning this and tried all the suggestions with no luck. I am extremely tech savvy so I do not feel I am doing anything wrong, but I am at my wits end. Any suggestions on getting this to work would be great!
uscfsu23 is offline
post #2 of 14 (permalink) Old 06-22-2010, 10:42 PM
Bingo Steve's Avatar
Bingo Steve
If your door opener has rolling codes you must go to the opener and hit the learning button and then go to the car within 30 seconds and hit the button you programmed already then it should work.
After all was said and done, more was said than done.
Bingo Steve is offline
post #3 of 14 (permalink) Old 06-22-2010, 10:50 PM
millk18
I suggest going to homelink.com. We have a Chamberlain WhisperDrive belt drive door opener. The website told us that we had to "pair" up the remote with the HomeLink button by holding the opener remote about one inch from the HomeLink button, pressing both the remote and the car button at the same time until you see a rapid blinking light on your HomeLink button. Then press LEARN on your door opener. This should do it.
millk18 is offline
post #4 of 14 (permalink) Old 06-22-2010, 11:50 PM Thread Starter
uscfsu23
QUOTE (Bingo Steve @ Jun 22 2010, 10:42 PM)
So are you saying to program with the garage door opener remote first and then do the learn for the rolling codes on the actual motor part? I will have to give that a try if that is what you are saying.
THANKS
uscfsu23 is offline
post #5 of 14 (permalink) Old 06-23-2010, 12:54 AM
snapper41's Avatar
2011 Sonata YF Limited 2016 Tucson Limited
Quoted: 12 Post(s)
snapper41
.. Note:
We run into this allot, NOT all opener systems work, like older Stanley systems with two button remotes.
snapper41 is offline
post #6 of 14 (permalink) Old 06-23-2010, 02:58 AM
RamKat's Avatar
Quoted: 13 Post(s)
RamKat
RamKat is offline
post #7 of 14 (permalink) Old 06-23-2010, 06:45 AM
Bingo Steve
QUOTE (uscfsu23 @ Jun 22 2010, 11:50 PM)
THANKS
That is EXACTLY what I am saying. It explains it in the manual to program normally and if it doesn't work to then go to your garage door opener unit and hit the learn button and I believe the only thing to do after that is hit the homelink button you just programmed and BAM the garage door actually starts to go up or down depending on what position the door is already in.
This has been SOP for me in every car I have had in the last ten years or so that had homelink.
post #8 of 14 (permalink) Old 06-23-2010, 07:16 AM
2015 Sonata Limited
Quoted: 111 Post(s)
midas69 is an unknown quantity at this point
When I first got my Sonata I had an old opener that didn't have the rolling codes. Then my door decided to break and when I replaced it decided to replace the opener at the same time. This was the first I've ever had to deal with rolling codes. It as frustrating at first but eventually got it to work by reading the post RamKat linked to. Or follow the instructions that Bingo Steve laid out.
Into every man's life a time comes when he must get up and make something of himself. And when that time comes, I'm going to be well rested.
midas69 is offline
post #9 of 14 (permalink) Old 06-23-2010, 01:10 PM
HYUNDAIS: 2013 Azera Tech, 2013 Accent, 2012 Tucson
Quoted: 17 Post(s)
elp_jc is an unknown quantity at this point
First, clear the system by holding the 2 outward buttons for over 20 seconds... until light starts blinking rapidly. You should do this when selling the car as well.
Second, program the remote into Homelink. This is the main trick: use the LARGE remote (not a little one), AND TOUCH THE MIRROR WITH THE REMOTE. Don't know why, but 1" hasn't been close enough on most of my cars.
And finally, program Homelink into the opener following manufacturer's instructions. And yes, it's going to be a button on the opener (get a ladder), then you need to click Homelink once until a 'click' is heard, then again to operate door, all within 30 seconds. Have a good one folks. Will be back in a few more weeks .
2013 Azera Tech, white/chestnut. MODS: Spoiler, full rear LEDs, 3M window tint, radiator screen, cargo mat/net, wheel locks (travel car)
2013 Accent Premium, white/beige (daughter 1)
2012 Tucson Limited w/nav, silver/black. MODS: Window tint, cargo mat, wheel locks, radiator screen, dual horns (daughter 2)
elp_jc is offline
post #10 of 14 (permalink) Old 06-23-2010, 01:29 PM Thread Starter
uscfsu23
QUOTE (Bingo Steve @ Jun 23 2010, 06:45 AM)
Sounds good! I will try that tonight. For some reason I understood the steps to be separate... either you do the steps using the remote control or you use the learn button on the actual garage door opener.... So I reseting the homelink after every try.
THANKS GUYS!
uscfsu23 is offline
