2011 Sonata Limited Oil Filter Location - Hyundai Forums : Hyundai Forum
post #1 of 11 (permalink) Old 05-02-2010, 08:38 PM Thread Starter
Sonata_Guy's Avatar
Drives 2008 Sonata NF Limited
Sonata_Guy
I found an informative video on the location of the oil filter on the 2011 Sonata Limited. It looks like a spinoff and I wonder if you need a certain wrench other than a generic band filter wrench. Anyone done these?
http://www.youtube.com/watch?v=AzMCT3Jv_aM
Sonata_Guy is offline
post #2 of 11 (permalink) Old 05-02-2010, 11:51 PM
omegaweapon1985's Avatar
omegaweapon1985
From my past experience of changing the oil on my 02 Ford Explorer the oil filter is mostly hand tightened. I'm pretty sure this is the same and if its tighter and you can't do it by hand then you'll definitely need a tool to loosen it up a bit. After that hand tightened is the way to go.
omegaweapon1985 is offline
post #3 of 11 (permalink) Old 06-10-2011, 11:51 PM
Phan-Tom's Avatar
2011 Sonata Limited 2.0T
Quoted: 2 Post(s)
Phan-Tom
QUOTE (Sonata_Guy @ May 2 2010, 07:38 PM)
Harbor Freight $5 nice reach, works great on a tight filter.
[attachment=27046:IMAG1051.jpg]
Phan-Tom is offline
post #4 of 11 (permalink) Old 06-11-2011, 12:01 AM
13SonataScott's Avatar
Quoted: 14 Post(s)
QUOTE (Sonata_Guy @ May 2 2010, 04:38 PM)
Since it is recessed and you reach through a hole in the lower cowling to reach it, might I suggest what I use; an 80MM 15 flute end cap oil filter wrench. Harbor Frieght sells them online for 6 bucks. It's actually a four pack of assorted sizes. All are cast aluminum. They aren't exactly heavy duty, but they don't need to be.
http://www.harborfreight.com/4-piece-end-c...ches-94096.html
13SonataScott is offline
post #5 of 11 (permalink) Old 06-11-2011, 08:14 AM
Drives 2011 Sonata Limited Turbo, 1997 Jeep Wrangler
jared 2.0
QUOTE (Scott2011 @ Jun 10 2011, 11:01 PM)
+1. You should also be able to get this from your local auto parts store. Just make sure to get the correct size.
jared 2.0 is offline
post #6 of 11 (permalink) Old 06-11-2011, 11:58 AM
Xsolara's Avatar
drives Black 2015 Genesis 3.8L AWD Sig. pkg....2013 Elantra GT
Quoted: 164 Post(s)
Xsolara is an unknown quantity at this point
I did my first oil change and if you like an oil mess you will like this car. Because of the plastic under belly cover it makes removing the filter a little difficult. Removing the filter is not the problem....... it's the oil that spills out and runs down your arm and gets stuck under the plastic pan.
You will notice oil spots on the garage floor for several days. On the next change I'm going to punch a hole in the bottom of the filter hoping
to drain the filter and avoid the mess.......
"Act on what you know not what you think"
Xsolara is offline
post #7 of 11 (permalink) Old 06-14-2011, 07:42 AM
tonytony24
QUOTE (Xsolara @ Jun 11 2011, 10:58 AM)
I am planning my oil change as well on my sonata. i did this to my friend's car which also has a car with a filter pointing down with a plastic cover over. First, loosen the filter with your usual wrench just slightly. Then I put a plastic produce plastic bag over the filter to remove. I tend to avoid plastic grocery bags because most have holes on the bottom. I put the bag all the way into the filter so that there are no space for the oil to leak out. I get two things as a result of this:
1. No plastic cover mess.
2. Tie the bag after the filter is remove and the oil has dripped out enough to not make a mess. Ready for the filter for disposal! =)
2.0T SE
tonytony24 is offline
post #8 of 11 (permalink) Old 06-14-2011, 08:34 AM
Foolish_Mortal's Avatar
2x2013 Sonata Limited 2.0t 2013 Porsche Turbo Cabriolet Too many others to mention.
Foolish_Mortal is an unknown quantity at this point
QUOTE (tonytony24 @ Jun 14 2011, 06:42 AM)
Great idea! Thanks!
Foolish_Mortal is offline
post #9 of 11 (permalink) Old 06-14-2011, 09:58 AM
Xsolara's Avatar
Quoted: 164 Post(s)
QUOTE (tonytony24 @ Jun 14 2011, 05:42 AM)
Not a bad idea but I'm not sure it would work if you leave that large under belly plastic cover on......I took my time while unscrewing the filter because I knew oil filter was full of oil
and oil still gushed out ??? I don't know if the bag would of helped much in that case
Xsolara is offline
post #10 of 11 (permalink) Old 06-14-2011, 10:05 AM
2011 Sonata 2.0T
jspires85@gmail.com
Thanks for saving me the headache I didn't know was coming! Great Idea!
jspires85@gmail.com is offline
