Removing Crankshaft Pulley Bolt - Hyundai Forums : Hyundai Forum
 1Likes
post #1 of 13 (permalink) Old 06-23-2006, 03:27 PM Thread Starter
hyundaistepdad
I tried in vain to remove the crankshaft pulley bolt and wondered if there are any tricks to removing it?
It isn't left hand thread, right?
hyundaistepdad is offline
post #2 of 13 (permalink) Old 06-23-2006, 05:21 PM
ADMINISTRATOR
Montego's Avatar
Quoted: 97 Post(s)
this bolt can be very tight, it's not a left hand thread. the best method is to use an air wrench (3/4 drive if you can) but if you do not have acsess to this try a socket on a long swing bar, fit it on the crankshaft pulley bolt at around four a clock position and flick the starter switch so that the swing bar hits the ground and with luck the inpact will losen the bolt (make sure the swing bar hits something solid when it hits the ground) or you could remove the starter motor and have a pal jam a large screwdriver in the flywheel ring gear while you loosen the bolt (don't try this on vehicles with auto trans. or you could damage the drive plate)
MONTEGO
Montego is offline
post #3 of 13 (permalink) Old 07-03-2006, 02:06 PM Thread Starter
hyundaistepdad
I have successfully removed the crankshaft bolt by the following method:
1) I bought a piece of "c" channel from home depot and drilled three holes the same pattern as the ones that hold the pulley on. I cut a slot for the crank bolt. This is 36 inches long and heavy duty. I propped it against the front frame rail. Tightened the bolts very tight to avoid damage.
2) I then put a 22MM 6 sided socket (actually 7/8") on the bolt, a short extension, and a 3/4 inch breaker bar (round). I made an extender with a piece of 3/4 black iron pipe. I jacked the car up taller and put in on a heavy duty jack stand. The piece of pipe I could fit under the car was 21". I braced myself on the steering knuckle and pulled very hard and it finally came loose.
Air impact wrench, and starter method did not work. Good ideas, but alas a BFW was the solution.
If anyone is interested, I'll post pics of the bar.
Cheers.
post #4 of 13 (permalink) Old 02-27-2011, 05:44 PM
mariestanley40@yahoo.com
Send a message via Yahoo to mariestanley40@yahoo.com
HEY !!!!!!!!!!!!!!!!!!!!
HYUNDAISTEPDAD------------I NEED YOUR HELP. IM HAVING A HELLOVA TIME TRYING TO GET THIS CRANKSHAFT BOLT OFF SO I CAN GET TO THE CRANKSHAFT POSIONTIONING SENSOR AND THE BALANCE SHAFT BELT. THE COMPUTER CODE SAYS ITS THE SENSOR, BUT SINCE WE HAVE GOTTEN DOWN TO THAT BOLT, HAVE RELIZED THAT THE SMALL BELT IS BROKE, AS WELL. NOT SURE IF THE DIAGNOSTIC IS READING CORRECTLY BUT EITHER WAY I NEED TO REMOVE THAT BOLT. YOU MENTIONED A TOOL THAT YOU HAD BUILT AND DO HAVE SOMEWHAT OF A VISUALIZATION. BUT CAN YOU AND WUD YOU PLEASE POST SUM PIX, SO I CAN GET MY CAR BACK ON THE ROAD. I KNOW ONCE BEFORE WE HAVE HAD TO MAKE AND FABRICATE A TOOL FOR THE REAR BRAKES. WHY ARENT HYUNDAI RELEASING THESE TOOLS TO US SO WE DONT HAVE TO GO THRU THIS. IT HAS TAKEN ME 6 YRS TO FIND JUST A HAYNES MANUAL FOR THIS 2001 SONATA AND IT WAS BY PURE LUCK. ALSO...WHEN UNTIGHTNING THE NUT ARE WE GOING LEFTY LOOSY AS USUAL, OR IS THIS THING BACKWARDS?????
THANKS FOR ALL YOUR HELP...YOU CAN ALSO EMAIL ME DIRECT PIX OF THE TOOL AT......mariestanley40@yahoo.com................DU DE IM DESPERATE HERE...NEED HELP....CANT BE WITHOUT MY VEHICLE
Sonata Momma
mariestanley40@yahoo.com is offline
post #5 of 13 (permalink) Old 02-27-2011, 08:13 PM
jsinton's Avatar
Quoted: 69 Post(s)
Counter clockwise to loosen.
I never had a problem using the starter crank method. Did you try that? Always works easy for me, never seen it fail.
jsinton is offline
post #6 of 13 (permalink) Old 04-16-2011, 04:11 AM
mga123's Avatar
mga123
Hyundaistepdad;
I was wondering since I wanted to make a tool for my Hyundai Accent (since I cant Crankshaft get pulley nut off) does the Sonata Pulley look like Accent pulley see image
But I was afraid to use a piece of metal and three prongs to insert in between spokes of pulley
mga123 is offline
post #7 of 13 (permalink) Old 04-26-2011, 03:09 AM
mga123's Avatar
mga123
Again anyone have experience making pulley tool for 2002 accent?
I am afraid the "spokes" in the pulley will bend if I make a tool?
mga123 is offline
post #8 of 13 (permalink) Old 08-25-2016, 09:59 PM
mccoje01 is an unknown quantity at this point
Can not get this bolt loose on my 2000 Elantra. I have a chain wrench that I'm using to immobilize the pulley and a long socket wrench, but while the pulley isn't moving (I put a chalk mark on it to make sure), the nut is turning slowly and I can see the timing belt moving if I look up through the engine. It's like the nut is turning inside the pulley.
mccoje01 is offline
post #9 of 13 (permalink) Old 08-26-2016, 11:43 AM
Red Raspberry's Avatar
Quoted: 850 Post(s)
Hyundai crank pulleys have separated in the past into two pieces.
"Imagine a world in which we are all enlightened by objective truths rather than offended by them." Neil deGrasse Tyson
Red Raspberry is offline
post #10 of 13 (permalink) Old 08-26-2016, 03:17 PM
Not good to hear. Any ideas on what i can do?
mccoje01 is offline
