Throttle And Idle Sensor Problem - Hyundai Forums : Hyundai Forum
post #1 of 4 (permalink) Old 11-14-2005, 02:31 AM Thread Starter
SuperAman
So I went into the dealer and got them to check out my car cause of the "CEL" and the idling erratically problem. They spent a hour and half and came back and told me it's the "throttle sensor and idle sensor" that was screwed. Is this common with the sonata 2.5 v6 1999 model? With the symptons could that really be it? oh they said most likely the throttle sensor was degraded by bad gas over time...true?false?
I've had a timing belt change, fuel injection cleaning and spark plugs changed already.
Any do it yourself type thing for this prob? When stopped at a light, rpm's idle about 1000 and then it dips down and up, down and up. Seems like it loses power/stalls and then unstalls. When I gas it after, it shutters a bit and goes
any help is appreciated
SuperAman is offline
post #2 of 4 (permalink) Old 11-14-2005, 06:22 AM
MODERATOR
trajetXG's Avatar
Drives: A 2008-7 Seaters Santa Fe CM, 2017 KIA Forte K3.
Quoted: 18 Post(s)
trajetXG is an unknown quantity at this point
Try checking if there's any vacuum leaks...look at the PCV system.
Hyundai...The Power to Suprised & Drive your way.
trajetXG is offline
post #3 of 4 (permalink) Old 11-14-2005, 02:33 PM
ADMINISTRATOR
Montego's Avatar
Quoted: 97 Post(s)
this is a classic sighn of a faulty TPS valve (throttle position sensor) and it is not uncommon
MONTEGO
Montego is offline
post #4 of 4 (permalink) Old 11-16-2005, 06:31 PM Thread Starter
SuperAman
well I found my recipet and the codes that they pulled out of the ecu was
P0500, P0507
ANy idea about what this are? some kinda sensor right,, throttle?
