Anti Theft (disabling) - Hyundai Forums : Hyundai Forum
post #1 of 14 (permalink) Old 04-18-2017, 10:16 PM Thread Starter
Quoted: 2 Post(s)
EDJR is an unknown quantity at this point
I'm in NY and my daughter is in Florida, she has a 2002 Hyundai Sonata that apparently has an intermittent VATS problem. The previous owner fitted it with an after market key fob. If she doesn't use the fob and unlocks the doors with the key it starts regularly...but occasionally the vats still kicks in and the car won't start.
Would like to look into have the VATS disabled and was wondering if any of you folks have experience with the Hyundai VATS? Is this a common flash, is the VATS it in the PCM or BCM in the Hyundai?
EDJR is offline
post #2 of 14 (permalink) Old 04-18-2017, 11:07 PM
Drives 2001 Elantra GLS 2.0L Auto
Quoted: 268 Post(s)
Depends on the vehicle anti-theft system
If it is tied up with the ECU then disabling it could potentially disable starting the engine
If it is an after market item then removing it could do it
May help if you give a little more information on the car
avisitor is online now
post #3 of 14 (permalink) Old 04-19-2017, 06:45 AM
AUTOSPARK's Avatar
Hyundai Getz 1.5 CRD (D4FA)
Quoted: 994 Post(s)
When the VATS kicks in, does the engine crank over but fail to start or does the starter not even engage?
Has your daughter had the car checked at a garage to confirm the VATS is the cause of the non start?
I assume this car has an automatic gearbox?
AUTOSPARK is offline
post #4 of 14 (permalink) Old 04-19-2017, 07:49 AM Thread Starter
Quoted: 2 Post(s)
The car won't even turn over. On one occasion a mechanic was in the area and used the key to open all of the doors and the car started. I assume he did a VATS relearn, he may have told her it had something to do with an aftermarket key fob she had.
I'm familiar with GM Passkey and how it works via the BCM. Have no idea how the Hyundai VATS works (PCM or BCM) and if it can be by-passed (resistor) or disabled via flashing.
BTW: The car is automatic.
EDJR is offline
post #5 of 14 (permalink) Old 04-19-2017, 01:20 PM
AUTOSPARK's Avatar
Quoted: 994 Post(s)
The Hyundai factory immobilizer used on US cars is a bit of a joke to be honest. It's so easy to bypass it's hardly worth having. Of course your daughter's car seems to have an aftermarket system so maybe there will be a bit more to bypassing that. Especially when we don't know what it is.
But it might not be a VATS/immobilizer fault at all. Maybe there is a problem with the park/neutral switch since the car has an automatic gearbox. That's not that uncommon on Hyundai cars.
post #6 of 14 (permalink) Old 04-19-2017, 04:03 PM Thread Starter
Quoted: 2 Post(s)
Where can I get some info on the immobilizer function, schematic or bypass procedure. I'll pass on the neutral safety switch concern.
EDJR is offline
post #7 of 14 (permalink) Old 04-19-2017, 06:56 PM
Sonata 2000, 2.5L V6
Quoted: 50 Post(s)
SoNic67 is an unknown quantity at this point
After market VATS - you can't get the schematic from Hyundai. You need to know what is installed there first. Most likely your daughter cannot do anything with a "schematic" anyway.
Diagrams for neutral switch or brake switch/lights is what you can get from Hyundai.
"Those with limited knowledge in a domain suffer from a dual burden: Not only do they reach mistaken conclusions and make regrettable errors, but their incompetence robs them of the ability to realize it."
Translation: Stupid doesn't know is stupid.
SoNic67 is offline
post #8 of 14 (permalink) Old 04-19-2017, 10:08 PM Thread Starter
Quoted: 2 Post(s)
I am asking for an OEM wiring diagram not an aftermarket one. I simply want to know if the car uses a BCM or a combination of BCM and PCM to control the security system so I can understand the system then take it from there.
This is one of the reasons I discouraged her from buying a Korean car in the first place..there really isn't any technical support for them online. Just went through a similar VATS (no start) situation with a 2003 Chevy Cavalier and with a supplied forum diagram was able to narrow it down to a power line break.
I can actually get wiring diagrams for most American cars on the Autozone web site in the help section.
Thanks anyway
EDJR is offline
post #9 of 14 (permalink) Old 04-19-2017, 10:30 PM Thread Starter
Quoted: 2 Post(s)
FYI: Autozone has the ETACS wiring diagram available..but since I am a new member..I can't post the link!
EDJR is offline
post #10 of 14 (permalink) Old 04-19-2017, 10:33 PM
Quoted: 268 Post(s)
Do they also have the wiring diagram for the VATS????
