P0421 and hesitation hyundai sonata 2003 - Hyundai Forums : Hyundai Forum
post #1 of 5 (permalink) Old 06-25-2013, 02:47 PM Thread Starter
Drives sonata 2003 4 cyl
goldsonata2003 is an unknown quantity at this point
My 4 cylinder 2003 sonata has its check engine light on with the code p0421 and hesitates when I try to accelerate too fast but doesn't hesitate all time, sometimes it will and won't, I've read up that there are other things that can cause the code to read such as exhaust manifold leak, spark plugs and o2 sensors. How would I be able to check if these parts are the problem and need to be replaced before I dish out 800$ for a new catalytic converter? I recently installed an egr valve and solenoid if that could be the problem too, any help will be greatly appreciated, while at Sam swope today I got a diagnosis and the guy said it was the cat but I don't think he did any work other than read the codes since I had a coupon for a free diagnosis and tire rotation
goldsonata2003 is offline
post #2 of 5 (permalink) Old 06-25-2013, 04:54 PM
Nightstalker2160's Avatar
2004 Sonata, 2.7L auto 2005 Santa Fe, 2.7L auto
Quoted: 17 Post(s)
Nightstalker2160 is an unknown quantity at this point
What does that mean?
Basically this means that the oxygen sensor downstream of the catalytic converter on bank 1 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
Symptoms
You will likely not notice any drivability problems, although there may be symptoms. The code may be more likely to occur after the engine has had numerous cold starts in the past 1-2 days.
Causes
A code P0421 may mean that one or more of the following has happened:
  • The catalytic converter is no longer functioning properly
  • An oxygen sensor is not reading (functioning) properly
  • A sparkplug is fouled up
Possible Solutions
Measure the voltage at the oxygen sensor on Bank 1 (the rear sensor, or the sensor after the converter). In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
One thing to note is that many vehicle manufacturers offer a longer warranty on emissions-related parts. So if you have a newer car but it's out of it's bumper-to-bumper warranty, there still may be warranty on this type of problem. Many manufacturers give a five year, unlimited mileage warranty on these items. It's worth checking into.
Above is what I came across. I would start with checking the O2 sensors (there are two). It's the cheapest. If it's been a while since the plugs were changed I'd give them a look also.
EDIT+++++
More info straight from the Hyundai service site.
P0421
Main Catalyst Efficiency Deterioration (Bank 1)
a.Catalytic converter deteriorated
If any codes relating to HO2S sensor. MAFS, injectors, a P0171 or a P0172 are present, do all repairs associated with them before proceeding with this trouble area.
P0171
Fuel System Too Lean (Bank 1)
a.Faulty ignition system (Ignition coil/spark plug/Ignition cable)
b.Faulty fuel delivery system (Fuel tank/Pressure regulator/Canister purge valve)
c.Clogged fuel injectors
d.Faulty fuel injectors
e.Leak in intake system
f.Leak in exhaust system
g.Faulty MAFS
If any codes relating to injectors, HO2S, ECTS or MAFS are stored, do all repairs associated with those codes before proceeding with this trouble area.
P0172
Fuel System Too Rich (Bank 1)
a.Faulty fuel delivery system (Fuel tank/Pressure regulator/Canister purge valve)
b.Faulty fuel injectors
c.Faulty MAFS
2004 Sonata 2.7L, over 170k miles
2005 Santa Fe 2.7L, over 200K miles
Nightstalker2160 is offline
post #3 of 5 (permalink) Old 06-25-2013, 05:20 PM
Quoted: 17 Post(s)
Attached are the troubleshooting proceedures from Hyundai
post #4 of 5 (permalink) Old 06-26-2013, 04:46 PM Thread Starter
Wow thank you very much, how would I go about testing the oxygen sensors and spark plugs? I know that about 2 months ago I had to take the car in to get a tune up as it wouldn't go about 40 mph without causing the same thing that is happening right now, before I took it in though I had a check engine light that read that my exhaust o2 sensor was faulty yet I haven't seen that check engine light since the tune up
post #5 of 5 (permalink) Old 06-26-2013, 05:05 PM
jsinton's Avatar
Quoted: 69 Post(s)
If you installed a new egr valve and solenoid, and then the problem occured, I would suspect an intake leak. If you had spark plugs replaced, that could be your problem too. You need to verify exactly what type and brand of plugs were put in because OEM plugs are critical.
jsinton is offline
