Random misfire on #2, 4 ,6 - Hyundai Forums : Hyundai Forum
 1Likes
  • 1 Post By Nightstalker2160
post #1 of 10 (permalink) Old 10-01-2012, 06:33 PM Thread Starter
Nightstalker2160's Avatar
2004 Sonata, 2.7L auto 2005 Santa Fe, 2.7L auto
Quoted: 17 Post(s)
Nightstalker2160 is an unknown quantity at this point
Question Random misfire on #2, 4 ,6
My sonata 2.7L
It's running a little rough, check engine light comes on. I run the scanner and get a P302 code showing random misfire on the # 2, 4, 6 cylinder.
In the last 2 months I've replaced:
-Plugs
-Plug wires
-all three coil packs
-crank sensor
-cam sensor
I'm at a lose on where to go next. I just can't believe this is a spark problem with all those new parts.
Thanks in advance for any help,
2004 Sonata 2.7L, over 170k miles
2005 Santa Fe 2.7L, over 200K miles
Nightstalker2160 is offline
post #2 of 10 (permalink) Old 10-03-2012, 11:13 PM
Family has 08 Accent, 08 Sonata SE Limited.. 2 KIA Spectras (06, 07SX)
Quoted: 5 Post(s)
MyKids04Sonata is an unknown quantity at this point
Low fuel pressure in rail causing injectors not to fire correctly. No/low fuel can cause misfires (or no fires). Plugs not correctly gapped (I believe that is .044) will cause mis-fires and out of the box they are usually wrong...
Tonight I replaced 4 Champion plugs (real junk) in my wife's Kia Spectra and found every single NGK pre-gapped plug wrong out of the box. A worn timing belt will cause timing to shift and plugs to fire at the wrong time. You made no mention of "if" the timing belt has ever been replaced and this is a critical item...If the belt slips or breaks you will trash the engine.
Dave
MyKids04Sonata is offline
post #3 of 10 (permalink) Old 10-04-2012, 09:57 AM Thread Starter
Quoted: 17 Post(s)
Dave
Thanks Dave,
I replaced the timing belt about 4 months ago at the same time I did the plugs and wires. I gapped the plugs when installing them, but did not use the NGKs. I've been wondering if that is my problem.
How do you check the pressure at the rails?
post #4 of 10 (permalink) Old 10-04-2012, 10:41 PM
SONATA EF 2.7l
JohnnyCakes is an unknown quantity at this point
Dave
I'm pretty sure that most NGK plugs do not come pre-gapped.
JohnnyCakes is offline
post #5 of 10 (permalink) Old 10-05-2012, 12:47 AM
cubawashere's Avatar
05 Accent 1.6 automatic POS
Quoted: 3 Post(s)
cubawashere is an unknown quantity at this point
I totally agree that Champion 4 are junk along with the Bosch 4s.... always stick to import parts when it comes to the imports.... Denso, NGK, BeckArnley are some of the import brands. I noticed you said you replaced 3 coil packs... make sure that these packs are also import part -it does make a huge difference or reuse the old packs which probably weren't bad to begin with. Also never have I seen 3 packs go all at the same time. They usually only go 1 at a time...2 is even kinda rare. Just mentioning for future use.
Good luck
cubawashere is offline
post #6 of 10 (permalink) Old 10-30-2014, 12:43 AM
Tubig is an unknown quantity at this point
Unhappy
Originally Posted by Nightstalker2160 View Post
My sonata 2.7L
-Plugs
-Plug wires
-crank sensor
-cam sensor
I'm having the exact same problem. Same cylinders misfiring. Funny that they're all on bank 2.
Changed all plugs OEM Iridium, all coils. Checked TPS, OCV's, all 4 O2 sensors (very $$),
Tubig is offline
post #7 of 10 (permalink) Old 10-30-2014, 06:11 AM
2001 Trajet FO 2.7 GLS comfort 1996 Sonata Y3 3.0 GLS and others ...
Quoted: 83 Post(s)
e3tom is an unknown quantity at this point
Usually they are. From all good manufacturers.
NGK platinum and iridium plugs for sure 100%. The gap is even part of the plug's part number/code: xxxyyy11 means 1.1mm then.
If you buy the right ones for your particular engine, no regapping is needed.
NGK explicitly not recommends regapping due to the high risk of damaging the tiny center electrode.
BTT:
If there's something wrong with one bank, you have to look for stuff that's unique for each bank and not shared (like the fuel rail is - and coils, each one serves one cylinder on each bank)
Cams would be a candidate -> T-belt jumped on that bank ??? Tensioner bad ???
e3tom is offline
post #8 of 10 (permalink) Old 01-13-2016, 08:27 PM
mlongo35 is an unknown quantity at this point
have you found the problem yet with the engine?
mlongo35 is offline
post #9 of 10 (permalink) Old 01-13-2016, 08:39 PM
Quoted: 1288 Post(s)
Biased Ox sensor on that bank stuck, and PCM leaning fuel way down,, making for lean misfire (more air than fuel).. ??
sbr711 is offline
post #10 of 10 (permalink) Old 01-14-2016, 08:40 AM Thread Starter
Quoted: 17 Post(s)
I caused and fixed the problem, lol
I tried to save money during the timing belt replacement and only did the pump and belt. The result was that the belt jumped (twice I think) and the last time, valves were bent.
I found a used 2.7l out of a Tiberon with 40k miles and put that in. The car has been back on the road for about 10K miles now and is running great.
It was an expensive lesson to learn.
Karaoke Kop likes this.
