Starting after getting gas.... - Hyundai Forums : Hyundai Forum
post #1 of 7 (permalink) Old 01-20-2012, 08:21 PM Thread Starter
Elvis is an unknown quantity at this point
Send a message via Yahoo to Elvis
I replaced the fuel pressure regulator and another part mounted on the back side of the intake which solved the problem which you speak of.....
Elvis is offline
post #2 of 7 (permalink) Old 03-10-2012, 02:39 PM
Midnightz
2000 Hyundai Sonata GLS 2.5L V6, Automatic, All Power, 120K miles
Regardless of how much fuel I have or how much I put in, my Sonata has difficulty starting after refueling. If it does start, it will continuously stall UNLESS I rev the engine at 2,000+ RPMS for at least 1 minute before putting it in gear.
I have noticed that old filling stations with slower pumps do NOT cause this problem. It only occurs at modern filling stations that pump gas into my car FAST.
It appears my car is choking on fumes momentarily. I tried keeping the gas cap off while starting it but this did not lessen or resolve the problem.
I've had the car for 2 years and it's always done this. What is causing it?
Thanks in advance!
Midnightz is offline
post #3 of 7 (permalink) Old 03-10-2012, 02:53 PM
johnaauld's Avatar
2003 2.7 Santa Fe 2001 3.0 Z3 1996 Lexus ls400
Quoted: 267 Post(s)
Thanks in advance!
Have you replaced your purge valve yet? This is a classic purge valve problem.
johnaauld is offline
post #4 of 7 (permalink) Old 03-10-2012, 04:16 PM
Quoted: 1284 Post(s)
Purge valve.... you drawing in fuel vapors from the canister in an uncontrolled fashion, effectively flooding the engine untill the vapors clear the charchol bed and you hit fresh air.. cycle repeats itself nextime you re-fuel and displaced air from tank vents through the canister and charchol traps the vapors, and you start engine and draw vapors again in uncontrolled fashion until it clears and fresh air now drawn into engine again.. rinse, lather repeat... surprised you dont have a 0441 for incorrect purge flow.......
sbr711 is offline
post #5 of 7 (permalink) Old 03-13-2012, 02:58 PM
Midnightz
I've seen the posts for the purge valve but I've had 2 different mechanics tell me that is not the solution. Not that they offer another solution but 1 said it might be an EVAP problem instead. Very recently my check engine light did come on and the codes are:
P1166 - Heated Oxygen, Sensor (BANK 1)
P1167 - Heated Oxygen Sensor (BANK 2)
P0705 - Transmission Range Sensor A Circuit (Park/Reverse/Neutral/Drive/Low Input)
...but the refueling problem has been constant for 2 years, I don't think these codes have anything to do with it, right?
Anyway, ideas welcome and thanks for your posts.
post #6 of 7 (permalink) Old 03-15-2012, 09:21 PM
lanewbie
Purge valve...check part at auto zone, takes about 30 sec to change yourself....I had same problem, this was the fix..
lanewbie is offline
post #7 of 7 (permalink) Old 08-16-2016, 09:33 PM
Mhnavy is an unknown quantity at this point
2005 Sonata, 4 Dr 6 cyl 78000 miles, located in Roanoke Va.
Mhnavy is offline
