Car Alarm Keeps Going Off--checked Hood Switches - Hyundai Forums : Hyundai Forum
post #1 of 7 (permalink) Old 02-25-2008, 02:03 PM Thread Starter
taradenise22
I just drove my 2005 Hyundai Elantra from California to Pennsylvania without a problem. Once I arrived in Pennsylvania I took my car in for a state inspection. About 24 hours later my car alarm kept repeatedly going off. Eventually it stopped. When I tried to start the car it was dead. About 3 days later I had the car jumped. It ran fine. About 3 days later the car alarm randomly went off. I turned the alarm off and ran the car for 30 minutes and it was fine. About 24 hours later the car alarm randomly went off again. I turned it off and started the car. It ran fine. I checked the hood switches which was suggested in another post and they appear to be okay. There also doesn't appear to be any water around the battery.
What else could be causing this problem? Do you think the mechanic who performed the inspection could have hit something--my mother has had problems with them causing new problems after fixing old ones? Could it be the alternator? Could drastic temperature changes cause the problem--it does seem to happen when it goes from bitter cold to warmer, or is that just a coincedence?
Thanks!
taradenise22 is offline
post #2 of 7 (permalink) Old 02-25-2008, 06:36 PM
HyundaiLvr87's Avatar
ME: 2005 Black Obsidian Santa Fe GLS 4WD MOM: 12 Shimmering Silver Elantra GLS with pref. pkg. DAD
HyundaiLvr87
Send a message via AIM to HyundaiLvr87
Have you checked to make sure all of the doors are closed? This may seem obvious but this happened to my dad and it has happened to others.
Previous cars:
2005 Steel Blue Santa Fe GLS 4WD
2006 Black Obsidian Santa Fe GLS FWD
2007 Steel Gray Sonata GLS
2008 Slate Blue Santa Fe SE FWD
2011 Phantom Black Sonata Limited
HyundaiLvr87 is offline
post #3 of 7 (permalink) Old 03-23-2008, 03:33 PM
wnd
wnd
My daughter has the same problem,took it in checked battery,load, amp. volt, told us battery ok ,over a year now still at totally random times it goes off most times at 2-3 AM checked again said the dome light was shorting out the system,ok replaced assembly for dome light .Less than 2 years the battery dies no reason hard time wanted to prorate it not happy about that.
wnd is offline
post #4 of 7 (permalink) Old 06-29-2011, 07:18 AM
n3os
QUOTE (wnd @ Mar 23 2008, 02:33 PM)
i googling and found to solve the problem. check here
n3os is offline
post #5 of 7 (permalink) Old 06-30-2011, 09:34 AM
crewieboy
i had the same problem on my elantra ,i fixed my problem as follows ,when you open the drivers door there was a little black push in switch on the door column which when the door is closed pushes in ,on mine it wasnt pushing right in with door closed so my alarm kept going off ,on the inside door lip which presses against switch i stuck a piece of rubber and hey presto when the door closes now it pushes the switch right in and no more alarms going off
crewieboy is offline
post #6 of 7 (permalink) Old 11-28-2012, 07:02 PM
Drives Tucson
Bob001 is an unknown quantity at this point
How do you reset alarm on a 2008 Tucson hook up battary alarm going off car won't start
Bob001 is offline
post #7 of 7 (permalink) Old 11-29-2012, 02:10 AM
Em-squared's Avatar
Bob001. Feel free to keep your question here, but you also may want to present the question in the Tuscon subforum so as to get responses from other Tuscon drivers.
Fashionista.
Em-squared is offline
