2001 Elantra Rear Brakes - Hyundai Forums : Hyundai Forum
post #1 of 14 (permalink) Old 11-17-2005, 01:30 PM Thread Starter
mrfrankd
Hi all was wondering if anyone had a fix for the rear brake noise I am getting on a 2001 Elantra.I pulled the drums off and inspected the drums and shoes all looks fine. Then I adjusted the brakes cleaned everything and still get noise .It occurs as the vehicle is comming to a stop last 10mph to stop. Any ideas?
mrfrankd is offline
post #2 of 14 (permalink) Old 11-17-2005, 01:35 PM
saugen48
Send a message via Yahoo to saugen48
What kind of noise are you talking about?? Is it a squeal or grinding?? Anything movement wise transfered through the brake pedal???
saugen48 is offline
post #3 of 14 (permalink) Old 11-17-2005, 03:34 PM Thread Starter
mrfrankd
no pedal pulsation sounds more rotational I guess a rotational creaking sound I looked over the springs and looked for maybe a ridge in the drum that was scraping along the side of the shoes,its got me puzzled I might just change out the shoes to see if it stops. Thanks
mrfrankd is offline
post #4 of 14 (permalink) Old 12-28-2007, 10:53 PM
shawn418
I too am having the same problem. Although the noise is only occasional. Any ideas? I thought that I may have gotten dirt in there but I can't find anything. The grinding noise just started happening. If the brakes are going bad, isn't there a warning signal? any help is appreciated.
shawn418 is offline
post #5 of 14 (permalink) Old 12-31-2007, 01:04 PM
shawn418
Originally posted by shawn418@Dec 28 2007, 10:53 PM
[b]I too am having the same problem.* Although the noise is only occasional.* Any ideas?* I thought that I may have gotten dirt in there but I can't find anything.* The grinding noise just started happening.* If the brakes are going bad, isn't there a warning signal?* any help is appreciated.
[snapback]126521[/snapback]
An update. As I was checking it out today, the noise went away but as my speed decreased to around 10 mph, the grind came back. Again any info is appreciated.
shawn418 is offline
post #6 of 14 (permalink) Old 12-31-2007, 01:13 PM
byronguidry3732's Avatar
Quoted: 2 Post(s)
Dear Mr Frank and Shawn,
Yes, I know exactly what is wrong with your rear brakes...the hold down springs are worn!! These are the springs that secure the brake shoes to the backing plate. Specifically, these hold the shoes at the right tension so you don't get chatter or squeal noises.
1) Replace those two hold down springs first
2) Did this fix the problem? If no, recommend you clean out all of the brake dust with a low VOC spray cleaner like this one: http://www.crcindustries.com/auto/content/...px?PN=05084&S=Y
3) did this fix the problem? If no, recommend that you get your brake drums turned to remove the hard glaze on the braking surface.
Byron
Where's my bailout?
byronguidry3732 is offline
post #7 of 14 (permalink) Old 01-01-2008, 07:38 PM
Hyundaiownersclub
Or modified Hyundai brake shoes as for 5 years they made faulty ones which caused noise -most models suffered this problem
HYUNDAI TECHNICIAN BASED IN ESSEX UK. ALL HYUNDAI REPAIRS/MODS UNDERTAKEN INCL ENGINE/GEARBOXES Hi Scan and GDS equipment...
Hyundaiownersclub is offline
post #8 of 14 (permalink) Old 05-16-2008, 12:47 PM
Sammi357
2002 Elantra, only 20k miles...does the same scratchy, rotational noise in rear brakes.
checked and adjusted them and the noise went away briefly, then came back.
Is there a possibility that these springs are worn out on a car that only has 20 k on it?
thanks
sammi
Sammi357 is offline
post #9 of 14 (permalink) Old 06-05-2008, 07:36 PM
njhyundaitech
Spray the whole drum brake assembly with brake clean, spray the drum out, and lube the contact points of the shoes at the part of the shoe where it rubs against the backing plate. report back.
njhyundaitech is offline
post #10 of 14 (permalink) Old 06-06-2008, 07:27 PM
Hyundaiownersclub
Originally posted by Hyundaiownersclub@Jan 2 2008, 12:38 AM
[b]Or modified Hyundai brake shoes as for 5 years they made faulty ones which caused noise -most models suffered this problem
[snapback]127129[/snapback]
Did anybody read this
