Rear Seat Removal - Hyundai Forums : Hyundai Forum
post #1 of 6 (permalink) Old 06-01-2005, 08:55 PM Thread Starter
bankston2207
i need to change my fuel filter in my 2001 elantra. In order to do this, i must remove the rear seat. i cant figure out how to remove it can anyone help??
bankston2207 is offline
post #2 of 6 (permalink) Old 06-02-2005, 11:42 AM
gordo
This is from an earlier post:
There are two spring clips that hold down the front of the rear seat cushion - the back of the cusion is bolted down.
If you had two rear passengers the clips would be between their legs.
Its a bit tricky to get them to release.
Lift up on the bottom front edge of the seat (not too hard) and then push against the bottom edge where the clips are located. You'll probabaly have to push it back about an inch or so
With some jiggling you should be able to get them to release. After that the seat will pivot up enough to let you get at the fuel filter. You'll need to prop it up with a block of wood or something
If you need more room the seat cussion can be removed altogether.
gordo is offline
post #3 of 6 (permalink) Old 06-06-2005, 10:10 PM
gyaeger123
Bankston,
I just had the dealer replace my fuel filters on my 2001 Elantra. There are actually 2 of them. Don't forget to depressurize the fuel system by disconnecting the fuel pump electrical connection (also under the rear seat) before opening the fuel lines.
I decided to let the dealer do it for $86 including parts since the webtech photos were not that good and even my local mechanic wasn't sure if the filter(s) were inside the gas tank or not. I also could not figure out how to get the seat out ;o).
Best Regards,
George
gyaeger123 is offline
post #4 of 6 (permalink) Old 06-09-2005, 02:11 PM
wanderingoak
The seats are confusing. The factory manual / chiltons says that there is a strap that you can pull on to remove the seat bottom. I was never able to find it. I wound up removing the seat backs to get at the mounting hardware for the cushion. After that, it came out easy.
wanderingoak is offline
post #5 of 6 (permalink) Old 01-13-2009, 03:43 PM
mlmayo
I'm inclined to agree that the rear seats are unnecessarily difficult to remove. I'm trying to follow the instructions in my Haynes manual, but there are no pictures and the text is nothing but a few simple lines; i.e., useless. I was able to remove a series of bolts after an hour and just noticed the clips at the front. They seem locked into place, but I will attempt to depress the bottom seat cushion back about an inch as suggested by a previous poster.
Does anyone know where there are some pictures of this process?
mlmayo is offline
post #6 of 6 (permalink) Old 01-13-2009, 03:47 PM
the munk's Avatar
the munk
Read this : http://www.elantraxd.com/DIY/fuel.php
crookedH.Com Administrator
the munk is offline
