A Wired Problem When Adding Coolant - Hyundai Forums : Hyundai Forum
post #1 of 6 (permalink) Old 05-19-2012, 12:52 PM Thread Starter
04 elantra gls
scilib is an unknown quantity at this point
Hey Guys,
I checked the coolant level on the reservoir and it was low.
I decided to add coolant by removing the radiator pressure cap, however, the coolant fluid is full under this cap.
So my question is where should I add coolant? through this cap or the reservoir?
thanks a lot~~~
scilib is offline
post #2 of 6 (permalink) Old 05-19-2012, 01:28 PM
swduncan's Avatar
2012 5dr Accent SE, 6spd M/T, 2011 dr 650 Suzuki, 1976 BMW R75/6, 1978 Yamaha SR500
Quoted: 68 Post(s)
swduncan is an unknown quantity at this point
Add to the reservoir, cold level should be between the two lines on the bottle. If the system needs more coolant it will suck it out of the bottle and if it expands and needs to push a bit out it will do so back in the bottle, hence the name reservoir. Hope that helps. Cheers.
swduncan is offline
post #3 of 6 (permalink) Old 05-19-2012, 10:25 PM Thread Starter
04 elantra gls
Thanks a lot for your reply. So you mean I should just simply open the reservoir and add more coolant to the proper level? should I worry about any thing about the pressure cap and should i add coolant while the engine is on?
scilib is offline
post #4 of 6 (permalink) Old 05-19-2012, 10:26 PM Thread Starter
04 elantra gls
Thanks a lot for your reply. So you mean I should just simply open the reservoir and add more coolant to the proper level? should I worry any thing about the pressure cap and should i add coolant while the engine is on?
scilib is offline
post #5 of 6 (permalink) Old 05-19-2012, 10:47 PM
2010 Subaru 3.6R Limited
Quoted: 3 Post(s)
C6Shortimer is an unknown quantity at this point
You can always check your radiator level, when the engine is cold, by removing the cap. You add coolant, as needed, via the plastic holding tank. As mentioned above, there is a "cold" line and a "hot line." If your engine is cold and the car is parked on level ground just check the level of the holding tank and add coolant to get you to the "cold" line if it's low. Make a habit of checking all your engine fluids at least once a month, more often if you do a lot of driving. It's safer if you add fluid with the engine off. There's no need to have the engine running to add coolant. Hope this helps.
C6Shortimer is offline
post #6 of 6 (permalink) Old 05-19-2012, 11:29 PM Thread Starter
04 elantra gls
thank you, it really helps. but what is the role of the pressure cap?
scilib is offline
