Rear Wheel Bearings On A 99 Accent.... Hard To Do? - Hyundai Forums : Hyundai Forum
post #1 of 15 (permalink) Old 12-20-2007, 09:55 AM Thread Starter
registrationsucks
I really don't know much about working on cars but I am pretty handy with other stuff. Would an average person like me be able to replace the rear bearings in a 99 Accent? I don't want to get slammed at the stupid repair place.
Thanks for your time.
registrationsucks is offline
post #2 of 15 (permalink) Old 12-20-2007, 12:54 PM
byronguidry3732's Avatar
Quoted: 2 Post(s)
Dear registrationsucks<
Was registration really that hard?
go to hmaservice.com and register.
Click Shop
Enter Accent, 1999, your engine
Click Suspension System
Click Rear Suspension System
Click Rear Axle/Hub
Click Components
this is an 'exploded' view of the parts you will be working with.
Click Disassembly.
Steps to remove the hub. The rear hub assembly is a sealed unit. Buy new, remove the old, replace with new, torque to 130-159 lbs feet, easy. Should take you less than an hour using two jack stands and replacing both left and right rear hubs. I am not sure of the hub nut size, but should be between 22mm and 27 mm.
Byron
Where's my bailout?
byronguidry3732 is offline
post #3 of 15 (permalink) Old 12-21-2007, 11:25 AM Thread Starter
registrationsucks
Thanks for the reply. I guess I will have to take it in, because I have no way of tightening to a specific torque... Thanks anyway.
post #4 of 15 (permalink) Old 04-23-2008, 07:49 PM
AccentEd001's Avatar
AccentEd001
Hi Byron,
What do you use to tighten to a specific torque?
TIA
Ed
AccentEd001 is offline
post #5 of 15 (permalink) Old 05-23-2008, 10:07 AM
WOT
WOT's Avatar
WOT
Originally posted by AccentEd001@Apr 23 2008, 07:49 PM
[b]What do you use to tighten to a specific torque?
You need a torque wrench. They typically come in two flavors: (1) Beam and (2) "Click Stop". A click stop torque wrench will be more expensive, but much nicer.
WOT - Another "shade tree mechanic"; a.k.a. A Do-it-Yourself'er
WOT is offline
post #6 of 15 (permalink) Old 05-24-2008, 04:31 AM
gerald2003r
Post
Originally posted by AccentEd001@Apr 23 2008, 06:49 PM
[b]Hi Byron,
TIA
Ed
[snapback]155648[/snapback]
A Torque wrench is juch like your socket wrench, the only differance is that it will make a sound (Click) when it gets to the specified force or normally foot poundage here in the U.S. that you have set it to.
A Torque wrench, simple tool about 30 to 40$ at sears. You can set it from 5 foot pounds to 150 at least on the one I have. Some Hyundai info is expressed in the Newton scale so you will have to convert it online. If you have a hard time doing that write to me and I'll help you out with the conversion.
You don't have to go crazy with the digital tool they sell, the mechanical tool has been around since the caveman and works as well or better then any they sell.
I hope this helps...
Gerald
gerald2003r is offline
post #7 of 15 (permalink) Old 09-25-2010, 02:56 PM
Ambrose
Today, 09/25/2010 I tried to register at hmaservice.com. I filled-in all info and saw
HMAService Privacy Policy and Usage Agreement Link.
I click on it and nuthin happened. I look below and see
Problem with the above link? See NOTE below:
NOTE: If your computer has Windows XP operating system, you may have an automatic
Pop-up Blocker running which can prevent these links from opening. To bypass the Pop-up
Blocker, hold the "Ctrl" key (lower left corner of keyboard) while you click on the link, and
do not release the "Ctrl" key until the download window fully appears.
I DO have that, so I try their solution and get an empty screen.
The link location is: java script:OpenNewWindow('/privacy_Policy.html',%20'full',%20'full',%20'priva cy',%20'yes');
What the hey, I paste /privacy_Policy.html on the end of hmaservice.com and get a privacy policy page with a little checkbox at the bottom to ensure folks have read the policy. I check the box but when I try hitting ENTER, again nothing.
Soooo, yes, registration is IMPOSSIBLE, until either: 1. They figure out their JavaScript (or whutever) mistake.
OR 2. I figure out if & why my Firefox is messed up.
I am not complaining, just giving info. As it stands I can't send this to Hyundai so that they know.
Ambrose is offline
post #8 of 15 (permalink) Old 09-25-2010, 04:42 PM
jsinton's Avatar
Quoted: 69 Post(s)
QUOTE (OtterRose @ Sep 25 2010, 02:56 PM)
Firefox is a no-no with that site, it's always been that way for whatever reason. Suggest you use Chrome or IE. I've been using Chrome with no issues myself.
jsinton is offline
post #9 of 15 (permalink) Old 08-15-2012, 10:56 AM
mfeltenberger's Avatar
Driving a 2009 Sonata GLS 3.3L
mfeltenberger is an unknown quantity at this point
I use Chrome and had the same issue as above with the Terms popup not coming up. I just switched to IE to register, and everything worked fine.
mfeltenberger is offline
post #10 of 15 (permalink) Old 06-28-2013, 03:06 AM
2001 Hyundai Accent GS 1.6L 5-spd
ASUBSEEstudent is an unknown quantity at this point
I believe you need internet explorer. I have same issue, so i tried to d/l it and it tells me i have a more recent version when it is most certain NOT installed on my system, used to have it but now its gone. wtf, fun stuff
ASUBSEEstudent is offline
